I Am Canadian!
I was at test and tune last night in preparation for today's street car shootout. I made 4 passes and am ultra happy with the results.
Setup currently is 125 shot, VP ms109 racegas, and drag radials. pass 1 rt:0.142 60:1.970 330:5.507 660:8.514 mph:81.74 990:11.041 1320:13.319 mph:102.07 Off the trailer was a pretty decent pass. I spun out of the hole as you can see by the 1.9 60'. pass 2 rt:0.081 60:1.866 330:5.393 660:8.419 mph:81.14 990:10.975 1320:13.286 mph:100.49 Was more happy with this pass, put a little more heat in the tires in the burnout but it still spun out of the hole. pass 3 rt:-0.078 60:1.851 330:5.367 660:8.363 mph:82.04 990:10.884 1320:13.159 mph:102.18 WOOOOHOOO new personal best and I still spun. So I decide to let a pound of air out of the drag radials for the last pass of the night. pass 4 rt:0.096 60:1.736 330:5.249 660:8.267 mph:81.34 990:10.813 1320:13.117 mph:100.58 Finally hooked up my junk and she ran it hard out the backdoor. Feels good to beat my personal best by over a tenth. It's getting so close to the 12's. I am so tempted to put a cam in it and just get a 12. But, I think I can do it on all the stock internals. I guess we will see ![]() |
got cones?
Re: NOSNOMA takes a V6, N2O and get's it done at the track!!
awesome times!
I Am Canadian!
Update from this morning
Rt:0.177 60:1.723 330:5.211 660:8.209 Mph:81.94 990:10.738 1320:13.023 Mph:101.67 So damn close should have farted after the burnout. |
I Am Canadian!
Absolutely robbed
Rt:0.126 60:1.728 330:5.220 660:8.212 Mph:82.19 990:10.733 1320:13.013 Mph:101.81 |
Nice job! I for some reason was expecting the traps to be higher.
Got boost?
Damn...very nice man.
you just need to take a healthy dump just before hopping in the truck and make sure you don't over-fill the gas tank, throw the passenger seat, the tailgate and your CD collection in the trailer and I bet you nail a 12.
I Am Canadian!
ur Stoked! |
damn this post really makes me want to finish up my direct port nitrous setup on my 94 SS. I will do my best to make time so Hopefully I will do it soon.
how does the 4000 rpm converter feel on the street?
I Am Canadian!
Nice numbers Jason!
Instead of losing weight, I'll drive it for ya. Give me a call next time you head out. |
those are some bad ass times for a basically stock 4.3. not hatin by any means, but i do believe w/ a smaller stall u'd be a bit faster than u are now
9.52@152.65
Good work Jason!!! Nice to see you getting closer to the ultimate goal!
I Am Canadian!
I call her: NIGHTMARE
I might have to agree on that stall, id have to say its hurting you with a stock cam. Wanna trade?
I Am Canadian!
not low, not gonna be...
but how about a V6 on spray???
would likely be closer to the V8 rated stall then. judging by your 60ft's, and traction issues on DR's, i would imagine you spray right after launch.. oh, BTW, congrats on the new E.T.'s... Last edited by Crew Cab Sonoma : 07-06-2009 at 04:00 PM. |
I Am Canadian!
Sprayed 4.3
I'll need human lives...
Ive always found my sweet spot to be around 4000.. But thats with a cam, 4wd and DRs... Keep with it though! Get those 60's down and its a sure thing
Sprayed 4.3
#24 |
I Am Canadian!
#25 |
your traction issues, either that, or a softer nitrous hit, if it only breaks loose after you hit the bottle. could make your truck more consistent. |
#26 |
I Am Canadian!
Are you saying I should have a 1.6 60ft or better?? |
#27 |
WICKED 6 RACING
1.7 60 is good. Need a cam to get the RPMs a little higher. To get the shift point around 5200 5300 RPMs. How high will the converter let you leave if you foot brake. If its a 4000 converter not sure hows yours it set up, but a 2500 2600 launch if the cam pushes hard sound right.
#28 |
Sprayed 4.3
What cam are you running?
My stock cam peaks around 4400, but is damn flat from 3900-4600. |
#29 |
#30 |
wow man awesome times! 12's are sooooooo close
#31 |
WICKED 6 RACING
#32 |
I Am Canadian!
definitely knocking on 12's doorLast edited by j_gor78 : 07-08-2009 at 12:48 PM. |
#33 |
no, your 60ft. is exellent, especially for your E.T. but it sounded like traction was an issue on many of your passes? perhaps it track prep? |
#34 |
I Am Canadian!
#35 |
glad you got it sorted out.
how much air seems to work best in your DR's? |
#36 |
I Am Canadian!
#37 |
wow, thats pretty low.
what pressure were you trying out before going back to this? i run 22-24 psi in my rear tires every day. they hook and ride better at this pressure than at 29-30 i used to run in them... my truck typically has just over 1300 lbs. on the rear wheels when unloaded. i only air them up if i'm going to be carrying a load in my truck. |
#38 |
I Am Canadian!
#39 |
2006 PBM GTO
I've run my DR's as low as 16lbs to get them to hook. That is flat out moving for a stock internal 4.3 - faster than some of the guys on the GTO forum run stock... hell, I only went 13.3 @ 106 on a stock LS2 (traction limited
