how to run the gas when running the gas
so how do i tap into my gas line when running nitrous, i have the fitting to screw into the line near the manifold but how do i get that pin to go down
the youngest has been
Re: how to run the gas when running the gas
remove the schrader valve with a valve removal tool
I believe valve you're talking about is the fuel pressure test port. If so, I believe you can just remove the valve with a valve stem remover. It is similar to the valve on a bicycle tire.
Mother! lol
thats wut i thought thanks guys
ill report back one day w/ some kills and times |
Not so Avg
Thats where I have mine, Just an 4an line from the test port to the solenoid
