Built 4.3 turbo underway Pics will talk
LinkBack (1) Thread Tools
Old 10-16-2008, 11:32 PM   #351
meyers2211's Avatar
Re: Built 4.3 turbo underway Pics will talk
and on the other spectrum, big motor little turbo gets the wastegate welded shut
Old 10-17-2008, 12:32 AM   #352
Will work for turbo parts
Quote: Originally Posted by s10ls
it depends on the turbo. running a 70mm turbo at only 10 psi means the wastegate will have to bypass alot of exhaust gas. basically he needs a bigger gate at 10 psi.
i bet it would work fine at 25 psi
I also have the T70, but I was going to run a 10 PSI spring and 15 PSI on the boost controller.
Old 10-24-2008, 12:28 AM   #353
Quote: Originally Posted by King_Ice_Flash2
I think he meant his wastegate troubleshooting.
What wastegate were you using? I hope I don't run into that with the 38mm turbonetics I have.
x2
Old 10-30-2008, 05:19 PM   #354
meyers2211's Avatar
In response to the dilemma i believe you guys are right, 10psi on a open downpipe was too much for the wastegate. 10psi on a fully muffled motor it could handle but i guess i was right on the threshold. Would explain how i put a buslength on that new c6.
Well i took the mani off today. Cracked entire top plastic manifold. Ripped 1 fuel injector out and the rest of spider assembly was laying on top of my manifold. Ummm one comment, Earlier in the build i had a real tough time sealing the intake manifold, it would leak from the front and back. So after 3 different sealants, some1 recommended the GM stuff. After sanding the block and manifold and after 6months i went to take the manifold off and i couldn't. It was sealed so well i had to remove my hood and chain it to my hoist, lifted the truck 2 inches then i had to jump on my bumper to get her to pop off. WOW. I've never witnessed a tube of rubber do that.
So i began work on the new manifold. Rough porting to smooth the castings down and some polishing work. Depending on the gasket will determine whether gasket matching is necessary.
very little is worth saving off the old manifold and my 97 lower manifold is slightly different and dirtier so i will work will the fresh manifold.
I have to get more abrasives from my job and then i will be good to clean and start assembling
Old 10-30-2008, 07:01 PM   #355
Registered (Ab) User
Yogi's Avatar
What exactly is the "GM stuff" that you glued the manifold down with?
Old 10-30-2008, 08:31 PM   #356
I'm not sure, but he should have coated the manifold with it.
I always use the Permatex "Right Stuff" black RTV for the lower intake manifold. It handles not letting it dry completely before using better than anything else I have found.
Old 10-31-2008, 01:18 AM   #357
meyers2211's Avatar
Starting porting new manifold
Old 10-31-2008, 01:37 AM   #358
Glad to see it is going back together!
Do you remember what size clamp the T70 used for the v-band?
Old 10-31-2008, 01:39 AM   #359
meyers2211's Avatar
I now have a steel plate there, but to show the 2001 tranny shifter location
Old 10-31-2008, 02:24 AM   #360
Have a nice day!
ProTouring2.2's Avatar
You should try to grab a short throw for that trans
Old 11-02-2008, 01:59 PM   #361
meyers2211's Avatar
3" v band
Old 11-23-2008, 02:05 PM   #362
I play in the street
schlsux's Avatar
ya i'm curious how comfortable that would be to drive....
Old 11-23-2008, 06:17 PM   #363
Have a nice day!
What do you mean?
Old 11-24-2008, 09:10 PM   #364
omg another turbo 4.3
Old 11-28-2008, 04:07 PM   #365
schlsux's Avatar
What do you mean?
b\c the shifter is moved back. I didnt know if 2nd and 4th would feel weird b\c your elbow is closer to the back of the seat when u shift.... didn't know if there were manouverability issues lol
Old 11-29-2008, 05:29 PM   #366
Have a nice day!
All he did was swap in a nv3500 trans. That's where the shifter sits in any stock 98+ truck with a new venture transmission
Old 11-30-2008, 05:50 PM   #367
meyers2211's Avatar
If i was to keep the shifter for the 97 and put it on the 2000 tranny, yes it would be uncomfortable.
The 96-97 shifter is slanted back at a 45 degree angle
the 98 is much closer to straight up and is way more comfortable to drive because u are shifting above the tranny.
Old 12-02-2008, 02:57 PM   #368
schlsux's Avatar
oh i completely must have missed a section, i thought you were swapping in a T56 trans. Interesting info though. I didn't realize the difference in the years.
Thanks!
Old 12-02-2008, 10:02 PM   #369
time for a sheetmetal upper intake?
Old 12-07-2008, 03:31 PM   #370
meyers2211's Avatar
yea if cost wasn't an issue and sheet metal or 2114 would be in the mail.
So i got to tickering with it again on my 1 day off a week.
Problems since manifold swap:
Blown fuse, then cam correlation (dizzy skipped a gear), then after that i was running on 4 cylinders. Scanner read 1 and 6 were my culprits. #6 had a boot that was loose and #1 ???????
#1 tested for spark and wow did that hurt when i let go.
120psi in cylinder
.......fuel nowhere to be found.
So the used mani setup has a stuck injector. Probably just get new MPFI injectors for 200
Old 06-03-2009, 04:50 AM   #371
jgwone21two's Avatar
Thumbs down Re: Built 4.3 turbo underway Pics will talk
So how did u get a 4.3l to mate up to ur trans. what did the car come with? ... wasnt a 2.8l?
Old 06-05-2009, 03:24 PM   #372
needs to be lower...
nimrod8560's Avatar
Hmmm, 6 months and still no progress?
Old 06-09-2009, 11:06 PM   #373
meyers2211's Avatar
Theres been lotsa progress ive just been slacking, senior year in college and my daily driver blew a timing belt which turned it into a junk car. So i've been the 400hp truck everyday for the last 2 months and man what a change. I bought a seat of corbeau race seats that wont be going in now that i drive it everyday (really stiff and uncomfortable). I took off the carbon fiber hood in exhange for the stock one, to deter attention with cops and so my 400 dollar hood stays nice. I've been running 87 octane and using it for a work truck doing side jobs. just working when i want or need and having fun my senior year.
I haven't done anything serious because i've been gearing up for the ford 8.8 swap which i have 98 percent of the parts ready to go. I have power, i weigh nothing, i need traction and gears
Ford 8.8, rebuilt with ford motorsports rear, $600 + $250 for the rear.
Caltracs and u bolts $360
Rear drag shocks $50
1" drop blocks $40
Slicks and skinnies$300 with no rear tires
So i need to finish two jobsites and then i can take the couple days and do the rear end, put on the step shavers and take her to shows and the dragstrip. and then i can die happy
although side note, i did run into a brand new z06 and while it beat me, i was impressed that i gave it a good run. Even got a wave and a thumbs up. I ran the zo6 with the straight dump which really feels like 40whp+ and spools 600rpm sooner. I ran a Audi R8 while i had my car and muffler on and i put a car on him from 40-110, guy waved me to pull over and bs'ed for awile and man was that a sweet ride, rear engine and a gorgeous interior with paddle shifters, lol made my nite.
I have a thread in trans and rearend section with all the pics of the 8.8
Old 06-14-2009, 10:10 AM   #374
nimrod8560's Avatar
Sounds like a blast. We need some video of this beast in the day light.
Old 06-14-2009, 10:39 PM   #375
meyers2211's Avatar
ty its coming don't worry, i finished up a jobsite this week so now i have the bills paid for the next few months and when i get back friday from ac i'm gonna rip the truck apart for the rearend and step shavers, after that intensive video shooting .... tty when i get bak
Old 07-30-2009, 05:08 AM   #376
Meyers! its been a while, just poped in to check up on the progress. truck looks good. hows that rear coming?
when you have a min. stop by and look at my thread
http://www.s10planet.com/forum/showthread.php?t=12595
this is zy by the way.
Old 08-20-2009, 04:15 AM   #377
meyers2211's Avatar
Ford 8.8 swap, cost close to 2k, stock 3.55 gears w/ new Ford motorsports cobra limited slip
here are some pics of how it sits.
I still need to purchase slicks and relearn how to drive it/launch it off the 2 step
Old 08-20-2009, 04:23 AM   #378
meyers2211's Avatar
i'll show off my boys rx7, 3rd gen single turbo at 10psi
Plans are to head to the 1/4mile come cooler weather in sept oct. Englishtown NJ at 57ft above sea level :-)
Old 08-21-2009, 04:58 AM   #379
looking good.
Old 08-21-2009, 05:25 PM   #380
TURBOS SUCK
sy-clone's Avatar
meyers, were you able to use the stock s10 rear sway bar with the 8.8 axle?
Old 08-22-2009, 09:07 PM   #381
meyers2211's Avatar
yea, i wound up cutting the stock ford 8.8 sway bar mounts off the axle for weight and more room, then using 3.5" exhaust clamps and widened the stock sway bar plates to fit the increase in tube diamete. Its not flawless but it worked great.
Old 10-17-2009, 10:04 PM   #382
draggin azz
livindalowlfe's Avatar
Quote: Originally Posted by meyers2211
I really appreciate the responses guys.
it looks the only way to solve the problem is to cut the mani up further and re work the piping. So i called my buddy matt and he said he will come out and weld her up
I'm looked into many dif ways to get me out of this jam. I emailed Unisteer about the R&P steering, As well as checked out the pics, unfortunately is would relocate the steering down to towards the crossover but inquired about possible sponsorship
I checked out manual boxes that will bolt in and it would be nice to get rid of power steering but i'm concerned about regretting it, i'm a strong guy but jus haven't heard anybody say they had manual steering idk how it will be.
I emailed RPM about their steering column and waiting for a response
manual steering... its all about the gas pedal.. the faster you go the easier it is to turn ... anyways i have a manual box in my sonoma with airride and an lt4 its not bad at all and im sporting a v8 so the stock 4.3 should b a breeze
Old 10-26-2009, 02:41 AM   #383
meyers2211's Avatar
good news, its been running great and its been my daily for the entire summer with the truck almost finished, new rearend and bumpers. So lately i've really been enjoying it and finally got the oppurtunity for a track rental.
November 9th at ATCO in New Jersey with svtsnake.com. Its a local mustang speed forum so i bought in a slip to represent the gm guys and more importantly get a good track day. Only 15 cars allowed so i'm gonna get a chance for a good amount of runs, allowing me to warm up to trying for 11's.
If any guys on the board wanna come out that day its an open invite for spectators since we rented the track.
Its pretty much there, just have some finishing touches on the dyno and final weight reduction and prep.
skinnies and draglites with new 275 60 15 MT et streets.
its been a long time coming and i'm hoping the weather is perfect
Old 10-31-2009, 01:54 AM   #384
nimrod8560's Avatar
NIIICCEE!! Better take some videos
Old 11-01-2009, 07:38 PM   #385
meyers2211's Avatar
http://www.goprocamera.com/hdheropreview/
a go pro will be riding shotie lol
Old 11-03-2009, 06:17 AM   #386
SDimeVortec43's Avatar
What size serp belt are you running with that set up
Old 11-03-2009, 12:59 PM   #387
Yogi's Avatar
Glad to hear that it's running good, Meyers! Wish I could attend but that's a long way from League City, TX. Best of luck at the track!
Old 11-08-2009, 10:15 PM   #388
meyers2211's Avatar
After 3 days and about 35 hours the truck is tucked away in a borrowed race trailer ready to head to the track.
4hrs on the dyno resulted in :-) :
404rwhp 490lb torque at 12.5psi with no air filter, and open downpipe. 21 degrees of max timing. (dynojet calibration 1.15)
we leave tmr at 5:30am for ATCO in jersey
i'll post up the results tmr
-Mark
Old 11-09-2009, 10:33 AM   #389
I call her: NIGHTMARE
98 SS's Avatar
-Mark
SWEET!
Old 11-09-2009, 03:51 PM   #390
got cones?
rentedmule's Avatar
Nice, especially for only 12.5 psi!
Old 11-10-2009, 12:59 AM   #391
Mr. Top Secret
DFitty's Avatar
fvckin nice man. im gonna turbo mine over winter. you have an estimated cost for you motor build?
Old 11-10-2009, 12:43 PM   #392
Klep
Super thread, I've enjoyed reading it while it's been slow here at work. Can't wait to hear the results from the track.
Old 11-11-2009, 01:35 PM   #393
meyers2211's Avatar
So it was a gorgeous day, about 25 runs over 8 hours and we didnt break the truck :-).
12.13 @ 113mph was the best slip of the day with a 1.68 60ft
second best was 12.16@115mph
the morning we spent getting me comfortable and towards the afternoon we were hard pressed to get that 11sec slip. We didn't get there but the best 60ft was 1.66 launched at 5psi off the 2step at 4500rpm
Once we started getting dialed in the track starting slowing down, early in the day 11's looked easy to grab and as the hours pressed on it began to get out of reach. The motor richened up which i think started killing my top end. Well great experience and a fun day for my first time at the track.
we have lots of footage but the only one i have to show is the go pro view which is uploaded to youtube. the rest is 28min and needs to be edited
http://www.youtube.com/watch?v=3FBQDtXs0lM
Old 11-11-2009, 01:53 PM   #394
i need a paint job
s106banger's Avatar
cool! good to see you got some very quick times. you should have 11's real soon!
Old 11-11-2009, 01:54 PM   #395
Yogi's Avatar
Really nice, Mark! I know that you wanted to break into the 11's but a 12.13 is not too shabby!
I enjoyed the vids! 12 sec. really goes by in a hurry!
Thanks for sharing!
Old 11-11-2009, 03:21 PM   #396
98 SS's Avatar
Very very nice.
Old 11-16-2009, 01:26 AM   #397
nimrod8560's Avatar
Awesome!!
Old 11-16-2009, 02:38 AM   #398
meyers2211's Avatar
here are the pics, the full length vid needs time for editing
Old 11-16-2009, 09:56 AM   #399
Molon Labe
BudRacing's Avatar
Sick
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f11/built-4-3-turbo-underway-pics-will-talk-289191/
Posted By For Type Date
recent vid turboed s10 - SVT Snake.com Forums This thread Refback 10-05-2007 02:21 AM
Page generated in 0.66106 seconds with 32 queries
[Output: 215.78 Kb. compressed to 197.34 Kb. by saving 18.43 Kb. (8.54%)]
