LinkBack (1) | Thread Tools |
#101 |
Re: Built 4.3 turbo underway Pics will talk
good to hear looks like the guy did a pretty good job and it wasn't too expensive. looking forward to seeing it all in there.
#102 |
Good to see you got that fixed, hope you get it buttoned down soon
#103 |
Got Fuel Rails?
Do you have any u-pull it's around you? The one by me has a ton of first gen s10s/blazers, wonder if that would work.
#104 |
#105 |
my hoopty
Location: Belmont, just west of Charlotte, NC User is: OffLine |
check suicidedoors.com for the blower box. i remember reading that they were producing a custom box for the bagged and big rim crowd. they might have what you need. also, i'm not that familiar with this engine, so it isn't obvious to me, but i thought i'd mention to make sure your water pump accessories will be rotating the correct direction with the new belt. it would suck to overheat during break-in and ruin the engine because the w/p was turning the wrong way! keep up the good work
#106 |
nobody makes them. you gotta custom fab your own or find a stock one.
#107 |
Akerfeldt
That is looking very nice meyers, what is that steering shaft with normal joint instead of the rag joint out of?
#108 |
To answer mintsick summit sells steering knuckles, its jus welded to a 3 or 4" steel pipe then welded to the stock s10 colaspable shaft
Update **** yea the motor is in. I have a 1/4" of clearance between the shaft and the exhaust, i wanted more but i won't kno till i rev that btch. I also wrapped that piping which adds 1/8" thickness if not more. After staring at the motor and convinced there was something wrong with boosted frame pads, i modded the motor mounts and moved em down and then it hit me tonite. drop the pass bolt in and pull a chain and jack up the left side and sure enough the bolt holes lined up, much easier considering i tweaked the mount. But its like when u stare at something too long and u need to come back with a clear head. The other good news is the exhaust is in i intend on two 3" exhaust systems I will have a electric cutout to a open 3" dump pass side exit and for the sleeper truck, cops, neighbors and emissions i have a 3" magnaflow cat into a huge 70 series flowmaster for a nice quiet daily exhaust tone. So at the flip of a switch i can have optimum performance but yet not wake my neighbors at 630am and 3am when i come home. Next goal is to get her started N/a to blow out the exhaust pipes and to test the engine then turbo goes on. But for now some pics ![]() ![]() Last edited by meyers2211 : 06-05-2007 at 12:41 AM. |
#109 |
holy huge freakin muffler! looks like it should go on a hummer!
the electric cut out is shiny! ![]() |
#110 |
She lives I fired her up today N/A to blow out the pipes and do a test run. The good news is she purrs and god can u hear the cam in it.
First set of problems to get her started The fuel lines on the top had a loose seat in the valve so she blew fuel all over the firewall, After a new valve seat she was fine. Then after tightnening the loose battery ground, she started right up and then 10 seconds later a shit load of smoke and oil, i thought i blew the a main seal or something turned out the be my PS pump, the lines were leaking bad,(looked serious to see oil on the ground dripping fromall over the oil pan,so i ran new hose and better untill she blew it off again, so either i need to put factory lines bak on instead of my modded or i crossed the feed and the return. For fueling i hooked up a Aeromotive FPR but i have a few questions What is the stock psi in the fuel lines? Does the 4.3 mpfi have a FPR built in? If i run a FPR and crank it up to 60psi will the computer shorten the pulse width on the injectors for closed loop running,and let 60psi be let loose under open loop Last edited by meyers2211 : 06-10-2007 at 11:55 PM. |
#111 |
Got Fuel Rails?
The computer assumes the fuel pressure is constant at 60 psi. It has no way of knowing if it is different or not. The pressure will fluctuate on a gauge depending on vacuum conditions, but it is really constant with respect to vacuum, so that is the important part. The o2's will do a fair job of keeping closed loop in line. The stock fuel pressure is 60psi. |
#112 |
:-) turbo is on, jus finsihed clocking it and getting ready for body panels and piping
quick video http://vids.myspace.com/index.cfm?fu...D=20364 07416 |
#113 |
neato
#114 |
looking good
#115 |
Will work for turbo parts
#116 |
the truck is on the road, shes in the exhaust shop right now, i wanted to hear that bitch spool and i finally got to yesterday at 3100rpm u jus hear the turbo start spooling, tough to hear over the exhaust but when i got off the gas you could hear it loud and clear
i take that bak exhuast shop called and said shes done Two 3" pipes pass side side exit Piping is in the mail i'll post pics when i get her back |
#117 |
#118 |
hot shit man, i'm glad to see this thing running
#119 |
I have a vortech super fmu if you still need one. I am going to use an eic so I am getting rid of it. pm me if you are interested
#120 |
hey meyers, The non AC blower box is on www.gmpartsdirect.com
![]() Part numbers 52474409 for 11 for the box And 52457440 for 12 for the seal that goes between the box and the firewall. total is $50.36 shipped for both parts. I have to order it myself. |
#121 |
i really appreciate the diagram, unfortunately i went thru and put the sheet metal block off in already after waiting, but i wish i saw this, its only june so i have 4-5 months before i will need Heat again. I'm gonna look it up now, cause i need not only the box but the heater blower motor too, from what i've read they are much shallower than the AC motors
and chris whats that ratio on that fmu i will have the tuning software so i don't mind trying a few i take that bak i jus cross ref the part #'s and they are the same blower motors Last edited by meyers2211 : 06-21-2007 at 12:14 AM. |
#122 |
you can alter the ratio on this one, it has different sets of springs and shims
#123 |
How is the truck running after a couple of days of it being finished? Have you hit the gas yet on it? Hows that turbo working.
#124 |
Hey I see you got her running.
So how is it? Thats what I wanted to do with the motor but I have enough toys already and not enough garage space. Good luck with the setup I had fun with it while I had it.Now I have the wife's turbo Lt1 and she's a blast. |
#125 |
Drag Truck In Making
Location: Westwego, LA outside of New Orleans User is: OffLine |
[quote=meyers2211;4234553]
![]() Like the side exit. But it looks like the pipe towards the front of the truck has angle, and the rear pipe is like 90degree straight. Would you mind posting some more pics up? |
#126 |
Yea unfortunately i will have to live with it, also the cut is straight jus not flush with the body line so i will have to trim it. The reason they are not perfectly coming out together is because i'm merging two dif exhaust systems. The one toward the front is the 3" cutout pipe the pipe towards the rear is catted and muffled. Its going bak to the exhaust shop to swap vbands and trade out a exhaust bolt thats hitting, so after thats done i will trim the exhuast.
In answering the questions about it running, its runs rough i'm confident it won't stall but shes running much better this week with the exhaust and some 02 sensors. The trouble has been to track down the leaks, the oil return is leaking some and the PS line gave me hell so I've been sorting everything out. I did the intercooler mounting yesterday and piping. Things that are left Finish the Batt Reloc FMU Vacuum Line Work something with the intake bonnet Gauges and wiring Tuning. |
#127 |
#128 |
#129 |
I call her: NIGHTMARE
oooh, i like the intercooler
Thats one of the things in the top 3 of my project list.gonna brace your core where you cut for the pipes? |
#130 |
yes the pass side wasn't cut up too bad, but the driver side needs to be reinforced i had to cut through most of the vertical support and think i'll make a bracket out of scrap for the pass side |
#131 |
OOO. That is cool. One for exhaust one for cutout. Im pretty sure they could make it even, but then again maybe space issue. Well it's awesome.
#132 |
<3 redheads
man i never knew you had a single cab stepside. i always thought you had an ex cab fleetside. anyway i am enjoying your progress. i look foward to completion.
#133 |
Starting from scratch...
Those pics make me happy in my pants.
#134 |
Recent update. So after installing the 16" efan i crossed two wires on the flexalite thermostat switch, shorted the circuit and fried some wires. :-(. The next day it went back to the exhaust shop to finish a weld and add a bung for the the wideband and wrapping the downpipe. It barely made it there, spittering stalling throwing 5+ codes i posted a thread about it, and i believe it to be a bad ecu. I found a guy on ebay had one, matched the #'s and he programmed it for $100 shipped. So now we are back on the road again. More new parts in, and what i've been anticipating My autotap is up and running along with me dropping $480 on JEt dynamic tuner.
Things left to do Swap the FPR for my cartech adjust. FMU Hook up wires for cutout permanently Wastegate exhaust piece Run guages Wideband and boostguage Mount ecu Get a bonnett that doesn't blow off Tuning and dyno time :-) |
#135 |
looking good keep us updated
#136 |
Mark |
#137 |
might want to reroute your wiring harness thats passing over the turbo befor theres a meltdown. im sure you knew that though.
![]() p.s how's the tuning comin? is jet fairly straight forward? Last edited by onecrazynoma : 08-06-2007 at 05:17 PM. |
#138 |
Progress Wiring/guages/switches hooked up for good Still left replace slave cylinder need intake bonnet tuning. if 8psi is not a safe reliable tune the credit card comes out and 2114 will be in the mail So much as jet being straight forward, umm i do feel over my head its not like ok i need some fuel here and some timing there. I miss the good ol days of jetting the carb and rotating the distributor. The program jus needs some getting used to. Once i got used to the cables i can reflash the ECu in less than 5 mins from datalogging Last edited by meyers2211 : 08-07-2007 at 04:01 AM. |
#139 |
sucks about your tranny, but hopefully you'll get it sorted out before to long.
also did you put a new clutch in when you did the swap, if not now might be the best time. Well good luck anyway. |
#140 |
TURBOS SUCK
I think this bonnet would solve your problem. PEACE OUT>Tony
#141 |
#142 |
Very nice intercooler, i would of ran one of those but i wanted the right side to exit top side, mine was really easy to due the piping for.
Well i set a new record 1 hour 35 minutes tranny was down and out and look just as i suspected the slave cylinder is gone, well its all there jus sheared into two pieces. And yes i have a new clutch in there with ARP hardware, i'm not running a centerforce i want my tranny to last, rather break the stock clutch than a 900 dollar tranny. Heres the pic of the slave cylinder ![]() ![]() new walbro will go in while i have driveshaft out of my way ![]() |
#143 |
truck looks really good man
#144 |
ntheworks!
beautiful setup man!!!!
#145 |
Is'nt a BLAST when the turbo spools up and sets you back in the seat ya let off and hear it blow off. Have fun and I'll be waiting for that PM
#146 |
I have a question, kind of off topic, but do you remember what the sizes on those AN fittings on your power steering box are?
#147 |
hey jk i don't remeber maybe 16 and 18mm to 6an line. It cost me 45 bucks to make the one piece. But last night my ppower steering pump blew to hell and i'm tired of fking with it so i'll get manual steering. Let me kno if u want the line.
Ok setup is up and running i took her out last night and was definately smiling when the boost kicks in but i need more fuel still goes 12.7 then 12.9-13.0 under boost. and the MAF flips out at 4000rpm throws a code P0103 which is high frequency. but i don't kno how to go around this |
#148 |
speed density
(for your maf problem) |
#149 |
yea but i'm still working with the stock MAP sensor and would like to retain the MAF for knock sensor. Am i the only one with this problem? supercharged guys still run the stock MAF so should i just turn down the boost to like 4psi |
#150 |
Got Fuel Rails?
Just get a larger maf off of an lt1, or ls1.
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f11/built-4-3-turbo-underway-pics-will-talk-289191/
| recent vid turboed s10 - SVT Snake.com Forums | This thread | Refback | 10-05-2007 02:21 AM | |
