#51 |
got cones?
Re: Blowers and Bottles Roster (Newbies Click Here)
Truck: 2003 GMC Sonoma
Body: Ext Cab Engine: 4.3L 4L60E Engine Mods: Powerdyne BD11a, 2.75" (9#) pulley 928motorsports head unit rebuild 3.5" charge tubing with bolt-on bonnet. Greddy BOV - eventually I'll route it back into the intake. Front half of an ebay intake with heat-shield. Cartech adjustable FMU. Dyno-tune by AFI Performance (afiperformance.com). 8.5mm MSD superconductor wires AC Delco R42LTS plugs. Autometer phantom boost gauge in a silverado column mounted pod. 2.5" cat-back exhaust, dynomax ultraflow muffler. Drivetrain: 7.5, G80, 3.42 gears 245/50's on 16" TransAm wheels Dyno #: waiting on the correct 6-rib pulley but it made ~185rwhp at ~4000rpms before the belt started to skip badly on the 8-rib blower pulley Best Track Time: N/A Track: Pics: ![]() ![]() ![]() |
#52 |
Truck: 1997 Chevy S10
Body: Reg Cab Stepside Engine: 4.3l turbo 5spd Mods: Engine Internals: Speedpro Pistons 9.2:1 CR Balanced rotating Assembly Ported Heads Custom Turbo Cam from Comp (266AHR) Comp Cams valvetrain Smoothed Lower intake mani Electric Fan March pullies Accel coil, 8mm wires NGK tr6's gapped at .028 20 degrees total timing A/c deleted Stock injectors, with Extra injectors SDS EIC 2 86lb injectors for boost. Tuned with tunercat Turbo setup: Master Power T70 .68 A/R exhaust housing Stock manifolds flipped, 1 1/2" crossover 3" turbo back, with manual cutout Tial Wastegate on crossover externally dumped Ebay intercooler with 2.5" piping Knockoff greddy BOV 4" turbo intake Everything custom. Dyno #: 353whp 397ft torque @9psi Full boost at 2900rpm Best Track Time: Unknown with traction in the 12's Track: Build thread http://www.s10forum.com/forum/f11/bu...l-talk-289191/ ![]() |
#53 |
TURBOS SUCK
Truck:1998 GMC Sonoma
Color:Smokey Caramel Body:ext. cab sport side Engine:vortec 4.3 litre V6 Mods:hi perf.4L60E auto trans,Accel billet dist.,Mallory HyfireVl-6AL ign.transgo shift kit/trans cooler,zexell-torsen(3:42's),3" JBA catback,3" cat,granatelli maf,boyd's 17X8 Motorious with Nitto's,2nd gen cowl hood,3200 rpm stall converter,KDS super servo module,March pulleys,LS1 fans,Cal-Trac bars,tech edge wideband,tial bov,Blitz boost controller,convert.2114 edelbrock/65# inj.t3/t4 hybrid turbo /stage III engine,meth injection kit, ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by sy-clone : 02-17-2008 at 05:17 PM. |
#54 |
thanks for the shot of your crotch reflected in the licence plate in pic # 2
looks great otherwise tho |
#55 |
TURBOS SUCK
#56 |
did you make the scoop for the intercooler, if so how, you got a box and pan break?
#57 |
stens rule
1992 s10,235770mi. 2.8l
mods 4.3tb msd blaster coil& distributor msd 8.9mm wires headers posi rear k&n filter electric fan underdrive pullys ac bypass aem tb spacer crane cams .454in/.480exh never seen a track tho. driven properly u can get 0-100 in the 12 to 13.5 range |
#58 |
Truck: 1993 GMC
Body: Typhoon #0883 Engine: 4.3L forged Bowtie Build/vortec heads Trans: 700r4 Trans, Stage VII Mods: PTE 72GTQ Turbo Front Mount Intercooler ATR tubular headers 3" Downpipe, 3" exhaust through a 3" Borla-X1 Muffler F.A.S.T. DFI, (6) 84# injectors MSD Ditigal 7 spark control Aeromotive A1000 fuel Pump Moser Built posi rear with 3.46 gears 275/40R17 Nitto DR, 315/35R17 Nitto DR, 3,400 rpm stall converter Chassis Engineering coilover rearsuspension JKS tubular coilover front suspension Hydra-boost brake system Wilwood 4 piston disc brakes BeCool Radiator TCS Electric water pump Autometer Gauges Razor Alky Injection Complete mod list in signature (needs updated) Dyno #: N/A Best Track Time: 10.61 ET - See slip in signature below Track: Muncie, IN Videos: See videos in signature below. Pics: ![]() ![]() ![]() John |
#59 |
Truck: 1993 GMC
Body: Typhoon #0735 Engine: 5.0L forged Bowtie V6 Build/18* aluminum heads Trans: Coan Extreme duty Turbo 400 Trans, Mods: Twin PT60-1 Turbos Delta mini-gate wastegates Front Mount Intercooler ATR tubular headers 3" Downpipe, 3" exhaust through 3" Borla-X1 Mufflers F.A.S.T. fxi, (6) 96# injectors F.A.S.T. Dash mounted touch screen data logger MSD Ditigal 7 spark control Aeromotive fuel Pump Peterson Dry sump oil pump Stef custom oil pan Stef Accu-sump oil reserve Chassisworks custom tube chassis/12 pt cage Chassisworks ‘Fab 9’ rear with Stranger gun drilled axles Moser Pro Aluminum 9” Center Section with 3.89 gears Chassisworks coilover rear suspension Chassisworks tubular coilover front suspension Strange dual adjustable shocks Weld Aluma Pro wheels 26X5.50-15MT ET DR, 30X13.50-15MT ET DR, 3,600 rpm stall converter B&M Pro Bandit Shifter Wilwood mastercylinder brake setup Wilwood 4 piston disc brakes BeCool Radiator TCS Electric water pump Autometer Gauges Custom leather and carbon fiber interior Dyno #: N/A Best Track Time: N/A Track: N/A Videos: N/A Pics: ![]() ![]() ![]() John |
#60 |
Moderator
Cleaned up, anyone wants to update the post? I'll take care of it
#61 |
Moderator
Cleaned up, anyone wants to update the post? PM me, I'll take care of it
#62 |
EconolineJunkie
i know nothing about turbos but i do know those typhoons are bad a$$ just awsome i want to see what that small blocked one runs!
#63 |
so are powerdynes the worst supercharger you can get?
#64 |
got cones?
update on post #51
now running a 2.93" pulley and meth injection = 222 rwhp |
#65 |
The Bombs About To Drop
#66 |
Can anyone help with the sy/ty turbo on a 2nd generation 97ss?
#67 |
Sprayed 4.3
Truck: 2000 Chevrolet S10
Body: Regular Cab Engine: L35 4.3 M30 4L60E Mods: NX Express 75 Shot K/N FIPK Stock Exhaust Manifolds Stock Exhaust with Flowmaster Muffler and Cutout BlackBear Custom Tune 3.73 Zexel Torsen Limited Slip Rearend MSD 6AL Ignition Box NGK TR-6's LS1 Electric Fans 275/40/17 Kuhmo Ecsta's Bold has ben added since posted E.T. MPFI Marine Manifold Built Transmission Transgo HD-2 Shift Kit 3200 Stall Nitto 555r Drag Radials Dyno #: 163/204- Motor 236/311 75 Shot Best Track Time: 8.7 @ 77 w/2.0 60'ft Track: Texas Raceway, Kennedale Texas Pics: ![]() ![]() ![]() Video: |
#68 |
2001 GMC Sonoma ZQ8
![]() ![]() 4.3l 5 speed/hurst shifter 8.5 10bolt with Auburn posi 3:73 gears custom headers and crossover to ar70 turbo FMIC custom 3" exhaust with dynomax bullet and fully welded muffler marine intake with 42lb injectors Walbro LT1 fuel pump MSD 6AL ignition MSD wires TB Spacer Tial blowoff valve custom electric fan setup underdrive pulleys AC delete HP suite tuner/datalogger Track Times TBA |
#69 |
WICKED 6 RACING
Truck: 1988 S-10
Body: Long Bed Regular cab Engine: 267 Cubic inch V6 Mods: Engine 40 Over 13.4:1 compression Custom ground comp cams hydraulic race cam with Rhodes race lifters 1 7/8 custom long tube headers 1050 stage 3 carburetor with Aeromotive feeding the carb and nitrous from fuel cell 200 AMP Alt with march crank pulley only drive accessory Meziere water pump with Becool 2 core Rad with flex a lite electric fan Lil Brodie aluminum heads Melling aluminum race pump inside RPM 8 quart pan Hardened crank with Oliver I beam rods Hamburger relocated filter system for 2 HP 1 filters RPM valve covers with 12 AN bungs for crank pump. Turbo 350 with reverse valve body and TS 5500 stall. Ford 8.8 rear cut down from explorer. Moser 31 spline axles with full spool. 9inch axle bearing from Moser and GM bolt patteren Wilwood Rotors and 4 piston up front with discs out back at the moment with Wilwood manual brake master cylinder. Weld draglite front with 26x4x15 upfront from MT and Weld draglite in the back with MT 295x65x15 screwed on. Procar race seats with 5 point harness and 8 point cage |
#70 |
WICKED 6 RACING
Truck: 1988 S-10
Body: Long Bed Regular cab Engine: 267 Cubic inch V6 Mods: Engine 40 Over 13.4:1 compression Custom ground comp cams hydraulic race cam with Rhodes race lifters 1 7/8 custom long tube headers 1050 stage 3 carburetor with Aeromotive feeding the carb and nitrous from fuel cell 200 AMP Alt with march crank pulley only drive accessory Meziere water pump with Becool 2 core Rad with flex a lite electric fan Lil Brodie aluminum heads Melling aluminum race pump inside RPM 8 quart pan Hardened crank with Oliver I beam rods Hamburger relocated filter system for 2 HP 1 filters RPM valve covers with 12 AN bungs for crank pump. Turbo 350 with reverse valve body and TS 5500 stall. Ford 8.8 rear cut down from explorer. Moser 31 spline axles with full spool. 9inch axle bearing from Moser and GM bolt patteren Wilwood Rotors and 4 piston up front with discs out back at the moment with Wilwood manual brake master cylinder. Weld draglite front with 26x4x15 upfront from MT and Weld draglite in the back with MT 295x65x15 screwed on. Procar race seats with 5 point harness and 8 point cage Best time: 11:0 at 118 1.47 60ft Home track: Cecil Count Drag Way Not the prettiest but mine project to be complete probably never Before the cage went inThe motor as it sits now In Truck ![]() |
