Hey guys welcome to the Official Blowers and Bottles Roster. The purpose of which is to gather everyone’s information, stats, pictures, and video into a centralized location for easy access. Also this will give me an official registry to go to when I need opinions / comments on some FAQ and Consumer report type threads we will be making in the future. Please try and follow the format I have laid out and feel free to reply with questions but note that I will come in every so often and edit out anything that is not an official entry. Also please note that I will be editing your posts as well to try and make the place as clean as possible. If I erase something you wanted up their just PM me or reply on the thread and I will fix it. Again I am not trying to piss anyone off, just wanting to keep it all in close to the same format. There has been some discussion of whether or not to add exterior mods to the list and for now I think we are just going to stick with engine and drivetrain mods including tires. Posting Pics and Video is encouraged because after all, that’s what makes it cool. If you need a place to host either videos or pics let me know, Ill help you out. Also take advantage of the s10forum gallery. That’s what its their for.
Thanks Guys. Don’t be shy. ~jim Last edited by ZQ8-97 : 02-10-2004 at 05:47 PM. |
Truck: 1997 GMC Sonoma
Body: Regular Cab Engine: LF6 Code 4.3 Mods: Machperformance P1SC Procharger @ 10 psi. ATI 3 Core Intercooler Edelbrock TES Headers & Y-Pipe Custom 3" Stainless Steel Turndown Exhaust w/ Spintech Prostreet Muffler Granatelli MAF Sensor Machperformance Custom Flashed PCM 3.73 Zexel Torsen Limited Slip Rearend Poweraid TB Spacer MSD 6BTM Ignition AC Delco R42LTS Plugs Summitomo 245-50-16 Tires Dyno #: None as of yet. Best Track Time: 13.6 at 105 mph with a 2.2 60ft Track: Muncie Dragway in Muncie, Indiana Elevation 600 feet. Pics: Video: Ride Along Video Engine Video Last edited by ZQ8-97 : 06-23-2004 at 01:33 PM. |
Done
Re: Blowers and Bottles Roster
Truck: 1998 Chevrolet S-10 ZQ8
Body: Regular Cab/Sportside Bed Engine: L35 Code 4.3L Mods: Performance mods: K&N FIPKII (partial install) Granatelli Mass-Air-Flow sensor Powerdyne supercharger @ 9 psi (was 7 psi) TPS Sensitivity Adjustment CFM-Technologies high-flow throttle blade EGR restrictor Flex-a-Lite Black Magic #60 electric fan MSD Superconductor 8.5 mm spark plug wires MSD 6BTM Ignition MSD Blaster Coil AC Delco R42TSM spark plugs Hypertech Power-Programmed Hypertech 160° thermostat Perma-Cool oil cooler and filter relocation kit Cloyes "True" Double-roller timing chain Crower Camshaft (.435/.449 lift, 212/218 duration @ .050”, 112 LSA) Crane Cams Gold Race full-roller 1.5 ratio rocker arms Crane Cams 3/8" rocker arm stud conversion Hurst Competition Plus short-throw shifter Edelbrock TES Headers/Y-pipe Jet Hot ceramic coating on headers and y-pipe Hollowed-out Catalytic Converter (re-installing the Dynomax Super Converter soon) Casper Electronics O2 simulator (to be removed when Super Converter is re-installed) Dynomax Ultra-Flow cat-back exhaust Kumho 245/45ZR17 Ecsta Supra tires Dyno #: Last dyno was 225 rwhp/283 rwtq (mods in bold type have been added since that time). Best Track Time: Not been to track yet, and speculation is pointless. Track: Not yet – will be National Trail Raceway in Hebron, Ohio (if I can find the time). Pics ![]() ![]() Last edited by ZQ8-97 : 02-10-2004 at 05:48 PM. |
Posts: n/a
Truck: 99 S-10
Body: Extended cab Engine: 4.3L (262cid) Mods: Granatelli mas K&K FIPK genII AC Delco Platnum Plugs Hypertech power programmer Casper electronics throttle response enhancer Custom 2.5 dual exhaust w/ flowmaster 40 series muffler Michelin Pilot Sport P245 45 18's NX 75 hp shot wet system Track Times: 15.4 @ 95mph spun 150-200feet after hitting nitrous (warm bottle) 15.6 @ 89 mph shattered a spider gear on the line before nitrous engaged (cold bottle) been through 1 driveshaft, 5 u joints, and one limited slip diff Last edited by ZQ8-97 : 02-10-2004 at 05:51 PM. |
I love Summer
Truck: 98 S-10
Body: Extended cab Engine: 2.2l 4cyl Mods: -NX 50 shot -Spec billet aluminum flywheel -Centerforce stage 2 clutch -LT1 camaro dual electric fans -K&N fipk -ASP underdrive crank and alternator pulleys -Helix throttle body spacer -MSD wires -2 stage cooler ac delco r42lts plugs -180 degree thermostat -Magnaflow cat -Flowmaster 40 series -Autometer 2 1/16 lunar nitrous pressure , and air fuel ratio -Billet b&m short throw shifter -225/50s front and 255/50/16's back Track Times: I ran a 17.5 bone stock so i will have to get some new times Pics: Last edited by ZQ8-97 : 02-10-2004 at 05:50 PM. |
Truck: 1985 GMC Jimmy
Body: SUV (heated cargo area )Engine: 3.2L Hybrid Mods: 3.2L Hybrid bottom end: Block: '86 2.8 Crank:'92 3.1L (genII) Rods: '86 (genI) Pistons: Federal Mogul hypereutectic for a '90 to '94 Cavlier VinT Beraings: Federal Mogul bearings Misc: 87 front cover and related serpentine belt driven accessories. Top end: Heads: '95 3100 from a buick Skylark (un ported)(genIII) Intake: '95 3100 from a Buick Skylark (un ported)(genIII) Cam: GM Performance cam (same specs as Crame 260-2) Rockers: '92 stamped rockers (1.5:1)(genII) Rocker Studs: '86 2.8 (genI) Turbo: T-3 from a mid eighties automatic Turbo Coupe Exhaust: Headers: Custom made, from Hedman Hedders "box of bends" and a few other sources 1.5" primaries Down pipe 2.25" Catalytic Converter: Car Sound 2.5" cat back Muffler: Supertrapp, with no discs Misc: Ignition: GM DIS ECM: '88 Cavalier Z24 Custom harmonic balencer mounted crank trigger Intercooler: Mitsubishi Starion BOV: GenI Eagle Talon Intake piping: modified Sunbird GT turbo to TB piping. Air Filter: Conical K&N Relocated battery to left side Electric fan: 1987 Sunbird GT Rad: 3 core Track Times: Best so far of 13.873 @ 99 MPH, 2.07 60' Track: St.Thomas Dragway just outside of Sparta Ontario Pics: For more pictures, go here: Eye Candy ![]() |
Got spray? Got boost? (y)
Truck: 01' S-10
Body: Regular cab shorty Engine: 4.3l Mods: March pullies Custom cold air intake with K&N filter Edelbrock headers and y-pipe 3" single exuast mandrel bent with Dynomax Ultra-flow muffler Casper electronics o2 simulator MSD Digital 6 plus MSD coil MSD window activation switch (2200-5400) Mach Performance computer cal. Zexel Torsen diff. NX GM EFI wet kit jetted@100 w/ Genx-2 upgrade Walbro 255lph intank pump 245/45r17f, 255/45r17r, BFG G-force T/A KDW Dyno: None yet. Track: 13.29@102.05 Pics: ![]() Last edited by ZQ8-97 : 06-23-2004 at 12:52 PM. |
Truck: 2002 Chevrolet Blazer Xtreme
Body: 2 Door Engine: L35 Code 4.3 Mods: Machperformance 60-1 Turbo @ 11 psi. ATI 3 Core Intercooler Machperformance Custom Flashed PCM Stock Motor w/ 40k miles Dyno #: 360 RWHP @ 11 psi Best Track Time: 13.54 at 103.88 mph no boost launch...just mat it and watch the 4100 lbs brick GO!!! Pics: ![]() Last edited by ZQ8-97 : 06-23-2004 at 12:54 PM. |
Truck: 2001 Xtreme
Body: extended cab, step side bed Engine: L35 4.3 Mods: Machperformance P1SC Procharger @ 12 psi. ATI 3 Core Intercooler Mach's 1 5/8" headers and 2.5" y into single 3" Magnaflow Machperformance Custom Flashed PCM MSD 6AL Ignition Comp Cams 266hr Ported and polished heads with 2.02 & 1.6 undercut valves ported and gasket matched intake manifold Comp Cams roller tip rockers and screw in studs B&M short throw shifter Caltracs Khomo 255/50/16 (they suck) Dyno # 388 HP 416 Torque. Best Track Time: 13.6@105mph 2.2 60 ft. Track: KCIR Kansas City, Missouri Pics: ![]() Video: JDB Kickdown Last edited by ZQ8-97 : 06-23-2004 at 01:37 PM. |
Vortech power not Vtec!
Truck: 1999 Chevy S10 LS
Body: Extended Cab Engine: LF6 Code 4.3 Mods: Vortech V1 polished supercharger @ 9psi JBA headers Custom 2.25" Y-Pipe 3" Stainless Steel from y-pipe back, 3" Magnaflow highflow cat and muffler w/turndown CraneCams Ignition box with timing control B&M shift+ NGK TR6 Plugs EGR mod, Throttle body plate mod AirRaid Intake Flex a lite Elec.-Fan HPP3 MAF Translator additional oil cooler Dyno #: 234rwhp with 277 rwtrq on a 98 deg. day and running 10.8:1 air/fuel ratio Best Track Time: 15.5@88mph with a 2.4 60ft on a 78 deg. day (I know this can be better because i ran 15.6 with my powerdyne @ 7psi on a cold day at the same track) Track: LACR Elevation 2,800 feet. Pics: ![]() Powerdyne Videos (Before the Vortech): DriveBy Engine Ride Along Last edited by ZQ8-97 : 06-23-2004 at 01:37 PM. |
TRUCK 2001 S-10 Xtreme
BODY extended cab fleet side 3 door ENGINE 4.3L TRANS 4L60E MODS Powerdyne supercharger, & Syclone intercooler Edelbroock headers & Y-pipe Gibson 2.5" cat-back MSD 6a, coil, & wires Egr restricter CFM throttle blade 180 degree stat Underdrive crank pulley E-fans MAF screen removed Super servo Superchip Micro Tuner Walbro 255 lph intank fuel pump O2 simulator Relocated battery to bed 1" blocks Removed overload springs Gauges fuel, boost, & LM1 wideband Adjustable FMU GM rollpan Last edited by ZQ8-97 : 02-18-2004 at 05:26 PM. |
T04E 60-1 Member
Body: 2 Door Engine: L35 Code 4.3 Mods: Machperformance 60-1 Turbo ATI 3 Core Intercooler 3" Exhaust Piping Through Magnaflow Muffler Machperformance Custom Flashed PCM Ported Intake Manifold Stage III Heads Custom Grind Turbo Cam Stage II Bottom End Dyno #: 414 RWHP / 506 Torque @ 11 psi Best Track Time: 14.4 at 98.88 mph (old motor) no new times yet Track: Las Vegas Motor Speedway - 2,200 feet. above sea level Pics: Last edited by xblazinlv : 02-17-2004 at 12:39 PM. |
Turbos and Naws
Truck: 1997 GMC Jimmy
Body: 4 Door Engine: L35 Code 4.3 Mods: SRP Flat Top Pistons 10.2:1@ 0" Deck Heigh Comp. Cam Custom Nitrous Grind Cam Eagle H Beam Rods ARP Connecting Rod Bolts File-Fit SpeedPro Chromoly Piston Rings Cloyes True Roller Timing Chain Comp. Cam Lifters ARP Head Studs Engine Girdle ARP Main Studs Melling Oil Pump Comp. Cam Gold Roller Rockers 1.6:1 Ferrea Stainless Steel Valves Comp. Cam High Rev Valve Springs MSD 6A MSD Timing Contol Box EGR Restrictor HPP3+ Dynomax Single IN Dual Out Muffler Summit Exhaust Cut Out Caspers TPS-TEC Caspers 02 Sim K&N FIPK II March Power Pullies 3 Piece Flex-a-lite 60 E-Fan 160 T-Stat Nitrous Works 150 Shot Wet Taylor Wires MSD Coil Lakewood Traction Bars CFM Tech T/B Plate Corvette Servo B&M Shift Plus Edelbrock Tes Headers And Y Pipe Jacobs Nitrous Mastermind Manual Steering Box Walbro Intank Fuel Pump Dyno #: None as of yet. Best Track Time: None as of yet. Track: N/A Pics: ![]() Last edited by ZQ8-97 : 02-18-2004 at 08:31 AM. |
My-chilled, MACH boost
Truck: 2001 GMC
Body: Extended Cab Engine: L35 Code 4.3 Mods: Machperformance P1SC Procharger @ 12 psi. Custom Liquid Chilled Intercooler JBA Headers SLP Y-Pipe 3" Cat Back Exhaust Machperformance Custom Flashed PCM 2600 TCS Stall Cal Tracs Dyno #: 260 RWHP @ 12 psi Best Track Time: 13.57 @ 99.3 mph Pics: Coming Soon Last edited by ZQ8-97 : 02-24-2004 at 06:45 PM. |
Un-Blown Fake ZQ8
Body: Ext Cab Engine: 4.3 Mods: Vortech V1 Supercharger Procharger 3core FMIC JBA Headers, SLP Ypipe. 3" Exhaust w/ Magnaflow Muffler Procharger adj. FMU Crane Hi-6 Ignition Lakewood Traction Bars Nitto DR's LM-1. Dyno #: 238hp/273ftlbs torque@10psi - before FMIC. Best Track Time: None yet. Pics: ![]() Last edited by ZQ8-97 : 03-21-2004 at 11:11 AM. |
I Am Canadian!
Truck: 1999 GMC Sonoma
Body: Ext Cab Engine: 4.3 Mods: Nx Gen X2 Nitrous kit running 75 and 100shot MSD Window Switch 1.6 Roller Rockers AEM Brute Force intake Granatelli Maf ASP Underdrive Pulleys Electric Fan B&M Shift + HPP 3 with 180* stat EGR restrictor MSD 6A MSD Wires MSD Coil JBA Headers 2 1/4 custom y-pipe 2 1/2 Exhaust Super Z Muffler Eaton Posi 3.73 Gears Dyno #: 240rwhp 310ft/lbs Best Track Time: Ran a 14.3 at 94mph w/ 2.1 60ft on the 100 shot Videos RACING VID FROM 2003 WHEN I WAS SLOW http://www.dragtruk.com/PICS/FXKQCWV65YDY3.mpg ![]() Last edited by ZQ8-97 : 07-08-2004 at 11:17 AM. |
9.52@152.65
Truck: 2002 Chevy S10 Xtreme
Body: Reg Cab Step Side Engine: 2.2L 134CID Mods: NX WET KIT 35 Or 50 MSD DIS-2 MSD RPM Window switch MSD 8.5MM Wires K&N FIPK 180 degree thermostat Al's Custom Header Black Magic Efan B&M Short Throw ASP Underdrive Pulley Zexel-Torsen LSD Caspers o2 simulator Flowmaster 40 series Mods Waiting to be Installed: Spec Stage 2 Clutch, Fidanza Aluminum Flywheel, 16G Intercooled turbo kit @ 8Psi, 62MM Rsm Racing throttle body. Dyno #: None Yet Best Track Time: 15.71@ 85.23 Approx: 65N20 Pics: http://www.s10forum.com/forum/attach...chmentid=40194 Last edited by ZQ8-97 : 06-23-2004 at 01:38 PM. |
Truck: 1997 Chevrolet S-10
Body: Extended Cab Engine: LF6 Code 4.3 Mods: Internally Stock 4.3 Vortech V2-SQ Supercharger Ford Powerstroke Intercooler Edelbrock TES Headers 2 1/2" Custom Turndown Exhaust 4l60E Transmission 2600 Stall Corvette Servo Zexel Torsen Limited Slip 3.73 Gears 275-60-15 T/A Radials. Pics: ![]() Last edited by ZQ8-97 : 03-15-2004 at 12:29 PM. |
2ManyS10's
Truck: 1994 S-10 SS
Body: Regular Cab Engine: L35 Code 4.3 CPI Mods: Nirous Express EFI Kit 75/100 Shot Comp Cams Cam and Roller Tip Rockers 3in Air Intake with K&N ConeFilter March 2 Piece Pullies Edelbrock TES Headers & Y-Pipe Custom 2-1/2 Exaughst W/ 2 Chamber Flowmaster MSD 6AL Ignition W/ Blaster GM Coil Jet Stage 2 Chip 3.73 Gears Nitto NT555R's Drag Radials 245-50-16 Best Track Time: 13.7 at 97 mph with a 1.9 60ft (*75 Shot) Track: Atco Raceway Pics: ![]() |
Truck: 1999 S-10 Xtreme
Body: Regular Cab Engine: L35 Code 4.3 CPI Mods: Headers Powerdyne Supercharger Custom Single In / Dual Out from Y-Pipe back MSD 6 BTM Last edited by ZQ8-97 : 06-23-2004 at 01:41 PM. |
Nasty V8 S10
Truck: 1991 S-10
Body: Regular Cab Engine: L98 Blown 350 (Carbed) Mods: B&M 144 Roots Blower 7 psi L98 350 ci Ballanced lower end Melling High Volume Oil Pump Melling High Volume Water Pump 160* High Flow Thermostat Griffan Radiator Hedman 1.5" primary shorty headers Full 2.5" dual exaust 2 High flow 2.5" cats Hardened Pushrods Edelbrock RPM 64cc Aluminum heads. Edelbrock RPM Cam 1.6 : 1 Full Roller Rockers 750 CFM Mighty Demon Blower Carb MSD 6BTM Ignition MSD Probillit Distributor MSD Spiro Pro 8.5 mm Wires MSD Blaster 2 Coil Mastercraft 225-50X16 tires all around Built TH700R4 Tranny 2500 RPM Stall TCI Break Away convertor SFI approved B&M Flex Plate Eaton Posi (7.5" 10 Bolt) Dyno #: 282 RWHP and 298 RWTQ (without the blower) Best Track Time: 12.654 @ 114.49 with 2.0 second 60' (3 psi, edelbrock carb and 6A ignition) Track: Old Bridge Township Raceway Park, Englishtown, NJ. (drove the truck 164 miles down there, raced and drove 164 miles back!) Pics: ![]() ![]() Vids: Vid of beating a C5 Vette This video was taken on a 95* humid day. I was running 3 psi with my Edelbrock 750 carb and of course my street tires.... i started off in second to keep from spinning too much but it wasnt bad! Last edited by Sixer : 05-26-2004 at 11:32 AM. |
i've been blown captain!
Body: Extended Cab LS Engine: 4.3L V6 Mods: Vortech V2-S Supercharger K&N Cone filter Custom 3" catback Exhaust w/ Flowmaster Muffler CraneCams "Fireball" HI-6R Ignition box NGK TR6 Plugs Lakewood traction bars General 245-50-16 Tires Dyno #: None as of yet. Best Track Time: coming soon.... Pics: Video: http://www.diminished1.com/images/ot...ride-along.mpg Last edited by ZQ8-97 : 06-26-2004 at 12:40 AM. |
Re: Blowers and Bottles Roster (Newbies Click Here)
Truck: 1994 Chevrolet S-10
Body: Regular Cab Engine: 4.3 TBI Vin Z Mods: NOS Wet Kit (50-150) Currently @ 75hp K&N Cold Air Intake Jet Adjustable FPR Port matched intake to heads March AMP Pulleys Derale E-fan Accel Extreme 9000 Wires and Cap Crane Hi-6 Ignition and Coil AC Delco R42TS Plugs Eaton Posi Unit Richmond 3.42 Ring and Pinion Lakewood Traction Action Bars BFG 245-60-15 Centerforce II Clutch and Pressure Plate 40 Series Flowmaster Dyno: None Best Track Time: 8.70 @ 83 mph 1.99 60' (1/8 Mile) Track: Jackson Dragway in Jackson,Tennessee Pics: ![]() Last edited by sunk96 : 07-08-2004 at 12:13 PM. |
#24 |
I Am Canadian!
If you can change my time that would be much apreciated 13.6@97 mph at Bud Park Raceway in Edmonton Alberta Canada elv.2200 feet
#25 |
Nasty V8 S10
EDIT: went to the dyno, 614.4 rear wheel ftlbs and 399 rear wheel hp |
#26 |
Truck: 1987 Chevy S-10
Body: Extra Cab Engine: 2.8 liter V-6 Mods: Stock with 152,000 miles Soon to be turbo'd (2.8's are cheaper to replace)Dyno#: they dont make dyno's for cars that need to be pushed Best track time: I dont feel like pushing my truck that far, sorry |
#27 |
Truck: 1987 S-10
Body: Reg cab Engine: 408 Chevy Trans: Powerglide with pro brake Mods: 12 bolt narrowed w/ 33 spline Moser internals BTE custom coverter Scat 4340 crank Eagle 4340 rods w/ Arp 2000 bolts Lunati 2618 Nitrous pistons Custom grind Comp roller cam Comp lifters rockers & pushrods AFR 210 heads Hedman 1 7/8" race headers 3" mandrel bent exhaust/ Dynomax ultra flo's Super Victor intake Quickfuel 3 circuit 1050 Carb NOS Bigshot plate system MSD pro billet dist & MSD wires MSD digital 6 w/ HVC coil Hurst 1/4 stick 8 point roll cage in cab Belltech 2" drop spindles Lakewood 90-10 front shocks Hal QA1 rear shocks 12 way adjustable Competition Engineering slide-a-link bars 4" Centerline Warriors f 9" Warriors in back 28x10.5x15 M/T Et drag's Dyno: *** Track: 9.63 @ 141 The list go's on & on Oh btw you still can hear the cd player while cruising!!! Pics are too big!!! Last edited by Quick S-10 : 01-24-2005 at 01:48 AM. Reason: pics |
#28 |
No S-Series... Just a GTO
Truck: 98 S-10 SS
Body: Reg. Cab Engine: 4.3L HO Mods: Powerdyne Supercharger at 7 Lb.'s (For now) MSD ignition Edelbrock T.E.S. headers Edelbrock Y Pipe K&N cold air intake Magnaflow Hi Flow Cat Flowmaster 40 series SI/DO dumps Taylor Wires Soon to Come: 9 Lb. pulley PCM programming E fan Comp Cam ![]() Last edited by jimmything08 : 01-24-2005 at 01:47 AM. |
#30 |
92 S-Blazer 2 door
4.3 CPI Hedman full length headers True duals w/ Flowmaster 40's Removed tune port switching valve and modified intake Mezeire Electric water pump Fluidamper 1.6 Scorpion full roller rockers Dynosources custom chip Precision Industries Vigilante 3200 stall converter w/lockup 4L60 w/ 'vette servo and Turbo-Action upgrades '03 S-series rear disc brake conversion Torsen locker w/3.73's or 4.10's NOS dry system w/ .055 orifice (125 shot) |
#31 |
Quad-Turbocharged Blazer
Truck: 97 Blazer - 4 door 4wd
Engine: 4.3L Transmissions: Fully Built 4L60e Mods: Homemade intake Modified throttle blade Modified MAF Removed EGR MSD Coil Custom Electric Fan assembly Full 2.5" exhaust with Dynomax muffler, no cat. Custom lowered ~4 inch Full Belltech suspension ![]() |
#32 |
Truck: 2003 Chevy S-10 Xtreme
Body: Regular Cab Engine: 4.3 Vortec Mods: Powerdyne Supercharger 7psi PEP Tubing for the powerdyne Greddy BOV K&N Air Filter Firestone Indy 500 235/55-16 Dyno #: None Best Track Time: None Track: None |
#33 |
Truck: 1996 S-10
Body: Ext cab Motor 4.3w Mods: K&N FIPK Underdrive pullys 1.6 Comp Cams roller tip 2.5 Hooker Aero Chamber Muffler Dumped HPP3 Throttle body mod JBA Headers MSD 6A Taylor 8.5 Wires 160 T stat PCV plumbing GONE! Cat gutted Mass Airflow screen gone Full Synthetics Stage 2 B&M shift kit Corvett Servo NOS 35 shot 225-50-15 Dunlop Sports @ 20 psi Dyno #: NA Track time: 16.618 @83.1mph (4200lbs and 35shot of NOS with a really cold bottle) Last edited by ghosts-10 : 10-10-2005 at 11:28 AM. |
#34 |
#2 Post Whore
TRUCK: 97 S10
BODY: extended cab MOTOR: 4.3L MODS Powerdyne S/C w/ 2.70" pulley (9 psi manufacturer claims) MSD 6AL Optima Red Top Battery HPP3 160* T-Stat K&N Filter Gibson Headers Custom Y-pipe Flowmaster 40 series Centerforce Dual Friction Clutch Hurst Short Throw Shifter MAF Sensor De-screened Accel Extreme 9000 Wires E-fan Powertrax No Slip Locker SSBC Dual Piston Calipers Powerslot Rotors Russels Stainless Steel Braided Brake Lines Ceramic pads Ground Force Drop Spindles Belltech coil spacer 2" Blocks GM Roll pan 98+ Front End Conversion White Face Gauges BFG Radial T/A 235/60/15 DYNO: N/A TRACK: N/A Last edited by Bennelton : 10-10-2005 at 12:08 PM. |
#35 |
It is a 1996 Extended cab S10 with a 350 chevy in it. It has a TH350 Tranny, with a custom Front driveshaft. The tranny has a shift kit and B&M torque master 2400 torque convertor. The engine has a Compcams camshaft (don't remember the grind) but it is Lopey, Keith Black Hypereutectic pistons with forged crank.
The heads are Stock 350 chevy heads BUT!!! I have a Set of Aluminum Superflo Heads 190CC intake, 64cc combustion chambers, angled plugs. With a set of Compcams Springs good up to .600 Lift all retainers. The only thing they need is some new spring cups (they sent me wrong ones and I just installed them to find this out WAY after the return period) they cost around 20 bucks. I installed Compcams Teflon valve seals (30 bucks for those). I also have a MSD Pro Billet Distributor on the motor as well as MSD Blaster 2 coil, and 6A ignition box. Moroso Super blue 8mm wires (suppose to be the best) The engine has an edelbrock 600 CFM carb (needs to be 750) a carb spacer, Chrome edelbrock Valve covers, Chrome oil dipstick, chrome trans dipstick, chrome brackets for accessories, chrome pulleys, corvette radiator, 3 electric fans (one on toggle switch), headers with header wrap. I also have a set of 5 Autometer Ultra Lite gauges installed. 1 speedo, water, oil, volt, fuel. <<< I believe the fuel guage has a neg wire missing off of it because it doesnt show fuel level. Interior- It is all Tan Minus the parts I changed because I hate tan and I wanted to change to charcoal grey. The dash is Charcoal grey and out of a 2000 Blazer So it has a newer dash in it. (looks really cool) the pillers are grey, door panels are grey, door sill is grey, kick panels are grey, carpet is tan, seats are tan and extended cab trim is still tan. There is no stereo because I am going to install a Touch screen Monitor indash like on mp3car.com and have a PC as stereo and MP3 player, but I have a set of audiobahn flame 3inch speakers. 1 installed in dash other not. Exterior- Exterior is Emerald green. I had it painted around 2 years ago but I havent had the orange peel wet sanded out of it. It has a 2 1/2 Cowl induction hood (fiberglass) and fiberglass rollpan. The windows are tinted to california specs. 20% on back and 35% on front 2 windows. and JUST purchased a 125hp NOS power shot : ) should be at my house within the end of week. I have yet to run the truck on the track i want to tune and get it how i want it before i go running it. |
#36 |
Banned
Vehicle- 2002 LS blazer 2door 2wd.
Motor- 4.3L Transmission- 4l60e Mods- ZEX wet kit, converted to a regular nitrous set up(solenoids taken out of box and put on NX microswitch) w/ NX 100hp jets MSD digital window switch Dynotune purge kit Marchperformance pullies 2 peice Royal purple 10w30 oil Ac delco R42LTS plugs Custom 3" intake w/ K&N cone filter- AiRaid tb spacer 3/3 drop to come- 4l60-e.com nitrous spec 2800 stall torque converter Ford 8.8 axles and rear end w/ 3.73's and posi MSD 6a w/ timing controller JBA headers w/ 2.5" y-pipe and 3" exhaust w/ spintech muffler Light weight corvette Z06 wheels MSD plug wires Corvette servos and .490 valve B&M shift kit E-fans 170 t-stat Bottle warmer Remote bottle opener. CFM-tech tb blade 1.6 roller rockers Machperformance head package Warlbro 255 fuel pump Custom 2114 set up w/ 36lbs injectors w/ B&M fuel pressure regulator Either PCMforless tune or Machperformance tune. w/ axles i can run 10.5 wide tires in rear so i will run 10.5 wide slicks at the track. Then maybe off of the JBA's do a custom STS turbo set up. intercooled 11 psi Dyno #'s-??? 1/4 Mile #'s- ???? |
#37 |
Truck: 1998 S10
Body: Extended Cab Engine: LF6 Code 4.3 Mods: 3" Catco Cat 3" to dual 2.5" Delta Flow Flowmaster Vortech V1 Crane Fireball Ignition Dyno #: None as of yet. Best Track Time: Never been to the track Track: NA Pics: NA Video:NA |
#38 |
well i dont really feel like typing. so ill jsut say a few of the stuff. i would like to post pics of it in here but i dont know how. its a 82 s10. Its running a 355 sb with nothing exotic. best time on motor 11.04 at 123. on a 150 shot and letting off at half track 10.04 134. its runnin a tunnelram and nos now. its had a blower in it and will soon have a procharger f1r. or two 62-1 turbos. i really liked the blower im thinking of a 8-71 bds with air lock rotors too but the power would suck. if you know how to post pics let me know and ill post on a few. later guys.
#39 |
Xtreme Dreams..
Truck: 2002 S-10 4x4
Body: Blazer Engine: 4.3 Mods: Wynjammer 6psi Supercharger Pcmforless Custom tuned ECM Flowmaster Cat-Back JBA Headers Drilled and Slotted Rotors Ceramic Brake Pads 3/3 Drop With Keys and blocks Belltech Nitro Drop Shocks 18x9.5 Zr1 Wheels 255/45/r18 Continental tires Goodmark Cowl induction Hood Style 2 160* Thermostat Dyno #: Spring 2006 Best Track Time: Spring 2006 Track: NA Pics: Soon Video:NA Last edited by 99xtreme : 11-23-2005 at 06:51 PM. |
#40 |
Body: 2 Door Engine: 4.3 V6 Mods: Wynjammer Supercharger @ 6psi LS1 Edit PCM Cold Air Intake Full Exhaust w/ Flowmaster 40 Flex-A-Lite Flex 60 Lowered 3/3 17x8.5 Corvette C5 Wheels A-Pillar Guage Pod w/ Boost/Vacuum and Air/Fuel Guages PS2 w/ 7.5" LCD Flip Down MP3/Cd Player w/ Pioneers all around and 10" Mmats Sub Brushed Billet Interior Trim Dyno #: Coming Soon Best Track Time: Coming Soon Track: Coming Soon Pics: |
#41 |
I didn't build it for you
Body: Extended Cab Engine: 4.3l, 4l60E Mods: ·Hypertech programmer HPPIII (removed for a true tune) ·March power and amp series under drive pulleys (removed when P-dyne was installed) ·K&N FIPK (partially removed with P-dyne install, continue to use filter and heat shield from the kit) ·Modified Edelbrock 2114 intake manifold (uses original throttle body still) ·TBI blade mod (half moon restrictor removed) ·PTE 44# injectors ·ATI fuel pump kit (removed P-dyne FMU) ·Powerdyne supercharger with 7psi pulley (for now) ·Tuned by MC Racing with Tunercat ·Transgo shift kit ·Vette servo ·Flex-o-lite electric fans ·Hypertech 180* thermostat ·NGK iridium plugs Dyno #: 165 RWHP before s/c. New #'s after 1-14-06 Best Track Time: No #'s yet Track: Pics: |
#42 |
Add 55 shot Zex nitrous kit to the above for 270 RWHP.
No track times till mid April. |
#43 |
driftersdime
Hey how much was total cost for your intake manifold? |
#44 |
Banned
UPDATE-
TRUCK- 2002 Blazer BODY- 2 door 2wd LS- PEWTER ENGINE- 4.3L w/ 4l60e MODS- Custom rearmount turbo @ 11psi intercooled B&M shift kit Vette servos Lakewood traction bars 275-17-60 Falken Ziex tires on the back OPEN DIFFRENTIAL STOCK 3.42'S March Underdrive pullies MSD coil DYNO #'s- 255whp & 330ft.lbs @ 8psi @ 11psi ????? 300+??? TRACK #'s- 8.54 @ 80mph in the 1/8th- good for high 12's ![]() TRACK- Immokalee Regional Raceway FULL WEIGHT WITH PASSENGER & 60LBS WHEELS/TIRE COMBO ON THE BACK- PICS- ![]() ![]() Last edited by 02_Vortech : 02-05-2007 at 10:26 AM. |
#45 |
Starting from scratch...
Truck: 1997 S-10 SS B4U/ZQ8
Body: 2 door, Reg cab Engine: 4.3l, 4l60e A4 Mods: Powerdyne S/C, 7 lbs (until the bugs are worked out) "Greddy RS"-style B.O.V. Edelbrock T.E.S., 3" bullet-style cat Flowmaster Super 40 3" in/dual 2.5" out MSD 6a, coil NGK Tr6 plugs (stock gap for now) Taylor 8mm wires Flex-a-lite E-fan Ported T.B., butterfly removed All synth. fluids B&M Shift kit B&M aux. Trans cooler Granatelli MAF K&N FIPK (partial) 3 gauge pillar- A/M Phantom Boost, A/M Phantom Trans Temp, B&M fuel pressure 2" spindles, 3" JTR blocks and trans shim kit + ZQ8 drop PowerStop slotted rotors, front C5 rims (17x8 fronts, 18x9 rears) Coming Soon-(Possibly) Comp Cams 266 Intercooler, Front Mount Dyno #: Probably not any time soon Best Track Time: Coming soon- As soon as Route 66 opens in the spring Last edited by 02_Black_XBlazer : 02-07-2007 at 11:28 PM. |
#46 |
Truck: 2004 Chevrolet Blazer Xtreme
Body: 2 door Engine: 4.3l, 4l60e A4 Mods: Powerdyne S/C, 9 lbs pulley custom 2 1/2 inch catback Magnaflow strait through muffler ( also known as the screamer) NGK TR6 IX spark plugs Richmond 4.10 ring and pinion gears Hp tuners ( reprogrammed toque managment and shift firmness.) lower half of K&N intake system NOS nitrous wet kit 50 shot for now NOS bottle heater NOS purge kit Dyno #: ????? Best Track Time: 14.621 @ 92.89 Track: No Problem Raceway in Belle Rose ![]() ![]() |
#47 |
'01 Noma
Truck: 2001 GMC Sonoma
Body: Ext Cab Engine: 4.3L 4L60E Mods: T3/T4 0.50 A/R cold, 0.63 hot, 0.69 trim Turbo Front Mount Intercooler Custom made tubular headers 2.5" Downpipe, 3" exhaust through a 3" Hooker Maxflow Muffler SDS EIC firing (2) 95# injectors Zexel posi unit with 3.23 gears 255/50R16 Falken 512's Corvette Servo Lowered 2/3 Dyno #: N/A Best Track Time: N/A until summer Track: Pics: ![]() ![]() ![]() |
#48 |
Banned
update on track times-
8.36 @ 83mph |
#49 |
#50 |
all right guys here is my intercooler setup on the truck right above
