bad news... good news (turbo Build)
ok. hopefully this will clear up a few things. like why i have been asking so many questions and why some of them may have been a bit wired.
i got in an accident. 3 car pile up on the highway on the way to my parents house about a month ago. i got rear ended and pushed into the car in front. and i have been fighting with the insurance company for the past month to get a reasonable settlement out of it. well after all the back and forth they eventually totaled my blazer. thats the bad news. The good news is that i should be able to fix all of the damage. (all body work except for the front core support). i trust me i have been all over it looking for anything else. and i should be able to fix it with enough money left over to turbo my truck. VERY good news. so here is a list of the stuff i got lined up so far. i have been planning this for ... well a long time. i keep pretty meticulous (read: anal) records. so i got the costs pretty well figured out. if you have any suggestions or see something i missed please let me know. (DONT SAY STUPID SH*T LIKE GET A V8). that said i would love your input. heres the list. 2114 fuel rails tb adapter fuel injectors 42lb/hr turbonetics turbo masterpower turbo Jet DST intercooler AEM UEGO wideband o2 AEM TRU boost controller fuel pump (granatelli) cartech fmu Turbonetics wastegate blow off t3 inlet flange air filter Oil complete kit |
Re: bad news ... Good news
also i am trying to figure out how i want to do the exhaust. i might copy meyers and just use the stock manifolds and weld some pipes on. or i might get some syty manifolds if i can find/afford them. i am also trying to see about a syty intake manifold. hopefully i can get one of those because the 2114 all said and done is over $1000 and i dont have that kind of money in the budget.
I call her: NIGHTMARE
Do an 01 ecm swap, get hptuners instead, you dont need an fmu if your gonna use a 2114 and a nice intake pump like a walbro
97 is just a rough year for tuning, the 01 swap isnt all that difficult....on paper at least between a 98 and 01.......but i dont know the differences between 97 and 98 |
well zygoat after all the hurdles i'm having with my manifolds idk if the sytys would of been better.
Top three concerns are steering shaft clearance, motor mounts (considering i melted one already) and the tight crossover. Its doable but with hurdles i'm glad i'm done with mine |
i got the fuel pump spec'd out. and i know i dont need the fmu with the 2114 i just copy . pasted that from the spread sheet i have, and i have them both so i can calculate the cost a bunch of different ways. does anybody know where i can get the syty intake manifold? i think that might be a better solution to the intake (ie less $$$). what about the map sensor is the stocker good to 10 psi. i believe it craps out a 14 am i right? |
well got the ball rolling today. i ordered some of the exhaust components. i got the flowmaster 50 series suv. and a tubing kit and some turn downs. the tale pipe got a jacked up in the wreck + you got to have a good muffler and cat back if your gonna turbo ... right?
its gonna be a dual out. i know it will be tight but i think i can make it work. i will hopefully do it this weekend, provided that the parts get here by fri. ordered Monday night so fingers crossed. if i do ill post up in the exhaust section and you all can check out my handy work.![]() |
TurboV6
May I suggest a Tial waste gate, http://www.tialsport.com/prod_wg_38.htm
One of the more important things on a turbo application and these are considered to be the best on the market by most. |
i like my aem thank you
yes, that is a v6
by the time you buy a syty upper and lower intake manifold, and pay for it to be modded to fit vortec heads, and pay to have a set of vortec heads redrilled, you will probably have more into the setup then a 2114. atleast a 2114 you can use your stock TB and it keeps it close to the stock location which means less stuff will have to be changed
or you could just use the older style heads, which i wouldnt recommend |
yea im not totally sure what i am gonna do as far as the intake goes yet. i don't really like the fmu idea. i am pretty sure that over time my spider is going to blow up. but the 2114 is pretty dam expensive. i would like to do it i just don't know if i can afford it. if only we didn't have popets...
ok well i talked to the folks at turbonetics today. i have spoken with them several times and they suggest the to4e 50 trim stage v. what do you guys think? here is the compressor map and the little red dot is where i have calculated my motor to be at wot, redline.
![]() i got a possible wastegate form tony. looks to be a nice piece and hopefully i will be ordering it shortly. |
so nobody has anything to say about the above? looks good, did you think of this, i hate your hair cut. anything? well i ordered all of the body panels that got messed up in the wreck. speaking of which you guys prolly want to see some pics of the carnage huh?
![]() the front. my girl friend said that it was pretty funny that i fixed it with tape so the body lines match up better than alot of ppls cars normally do. (had to tape it to keep it from rubbing in my wheel.) rear. ![]() the police report labels the damage from 1 to 3(worst) mine was all 1's the guy that hit me almost all 3's (scion tc) and the person i was pushed into had some 2's (vw jetta) Gotta love the good old American iron. |
what do you think of the rear window trim. i just painted it a few months ago. and the passenger side door like 6 months ago. (some one tried to brake into it, when the previous guy owned it.) they took a screw driver to the door handle. so i did some body work and fixed it all up then painted her.
ok does anybody have the part # for the walbro pump? also will this work instead
http://store.summitracing.com/partde...5&autoview=sku |
Idk man i bought a inline walbro, search the forum theres a walbro thread
TurboV6
UPDATE:
i started my flowmaster custom cat back this weekend. check it out. its got pics ![]() http://www.s10forum.com/forum/f89/fl...3/#post4473647 |
well i ordered my jet dst and both the aem uego and the tru boost. man that was a pricey 3 items. but i looked all over and got them as cheep as i could find ne where.
Will work for turbo parts
It could have been a hole lot worse. Glad to see you are doing OK. Good luck on the turbo project. The money adds up fast, that's why I have been piecing mine together for over a year, hopefully next fall, mine will be up and running too.
I got a AEM UEGO, Tru-Boost, Greddy fuel pressure gauge, and a GlowShift Pyrometer. I was going to go with the Greddy boost gauge, but having the controller built in is a huge bonus, and everyone seemed to think it was a decent controller for the money. If you are using the MAF sensor, I thought you could use the original MAP sensor. Please correct me if I am wrong. I am probably going to go with the 2 bar map speed density, which doesn't use the MAF. You might also consider going with an extra injector controller. |
where did you get the pyrometer from? i have been looking for a good one thats not like $200 but no luck!
#24 |
Ebay. I called glow shift direct, and they sent me the pyrometer for 49, the pod for 29, and 29 for shipping.
#25 |
the pyrometer is not going to be needed. all you need is boost and wideband airfuel. pyrometers used to be popular before widebands were affordable, now they are essentially useless to the average joe who isnt tuning his engine to the absolute max.. and they are worth even less when you only have one... cars being put thru advanced tuning will have one on every cylinder.
if your on a budget, i wouldnt even bother with a boost controller, just get a wastegate spring for the intended level of boost, and then you dont have to fight the temptation to constantly turn it up just a little bit. SyTy exhaust manifolds are definatly your solution, you can get them for 175-250. for anything custom at all you will break that $$$$ wise. SyTy intake manifold setup will cost you a grand said and done. the link to the edelbrock pump on summit that you listed is a walbro. walbro and bosch are pretty much the only manufacturers of OEM fuel pumps, and that particular one that edelbrock is branding is a walbro. |
#26 |
ok Little update. i got all the new body pieces i needed to fix the parts that got jacked in the wreck. i bought them from (scary voice)
ebay..... . they were actually pretty dam good quality. i was surprised. i bought them because they were cheep like VERY cheep. and i needed the money i could save for the turbo stuff. ne way here are a couple of pics.this is how the grill looked when i got it. ![]() after 3 hours of cleaning up all of the edges and casting marks. ![]() this was the worst damage to the grill when it arrived. not terrible really. ![]() here is a profile of the grill. ![]() (dont mind all the planes in the background.) another one of the hobbies that sucks you dry. here is the biggest blemish on the hood when i got it. ![]() i sanded it down with 1000 grit and all is well now. it needed a little bit of body work on the edges and corners but that was all. shoot of the whole hood ![]() (the guy in the back ground is my pop!) and the car is my moms, that thing handles better than my carmaro did hands down! so basically i prepped the hood, grill, rear bumper end (which was the only piece that was plastic that wasn't originally) i would have preferred metal, but it is cast pretty well. and they use metal reinforcement at all of the mounting points. here is the real story. all the parts i ordered. hood grill front bumper end rear bumper end rear bumper core support i got all of that shipped to my door for $350! pretty dam good deal i think. and for the price the quality was pretty good. the company was car parts wholesaler. so if you need some cheep parts check them out. especially if you need alot because they combine shipping. |
#27 |
wish i could have done more but somebody keyed my dads truck so we spend a good bit of time fixing and repainting the side of his truck.
assholes! |
#28 |
Is that an ultra stick? Other one a Yak?
#29 |
#30 |
#31 |
Let's see what I got in the basement...
GWS A10 EDF Super Bandit Super Decathalon 275 watt 3D foamie Demolished Pitts S3 Viking Crazy thing Pile of busted combat planes Dynaflight P51 Hornet 3d LA Maxir 3D 3D Pro Knight 3D Raptor 50 Yeah, it's an expensive hobby... ![]() |
#32 |
yea those are my dads hes got a tone of planes and now helicopters. i got out of it in high school to fund my car and computer (my two biggest hobbies) i still enjoy it tho just cant afford it right now. i actualy landed a midair in my easy 40 took the tail off of the plane i hit (flew in front of me) and tore most of my left wing off. i landed on the runway (could not turn left at ALL after the impact).
#33 |
lol i had to read everything to know what u guys were talking about lol
justin did u remove the center of the grille? |
#34 |
nope thats how she bee.
#35 |
well i called stripper motor sports (the place i ordered my aem uego and tru boost as well as the jet dst) on Tuesday of this week seeing as when i ordered the stuff on Tuesday LAST week they said it would be here by Friday LAST WEEK!
so i was a little upset.... when i talked to the guy on the phone he said that they did not have the jet when i placed my order (would have been nice of them to tell me that). but, he said that they had ordered it and it would be in on Wednesday. (the day after i talked to him) and that because of the delay they would overnight the stuff to me at no charge. (ok so they should have told me they didnt have the stuff and they should not have told me it would be here in 3or4 days, but they are doing the right thing by upgrading my shipping for free to make it right) so i was better after talking to him and all was well. UNTIL TODAY. when i get the ups tracking numbers via e mail and they were all shipped via ground shipping! So i tried to call them about 5 times today (Wednesday) but of course no one will answer the phone. at this point i am pretty dam pissed off with them. because the estimated delivery date now is next Monday. that puts it at THREE WEEKS after i ordered something that was supposed to be here in THREE DAYS! on top of the fact that basically they lied to my face twice. saying it will be here "in 3 to 4 days" and again "well upgrade you to overnight for free" i spent very close to a grand at their store and they treat me like this!?! i am not at all pleased and i will be trying to call them tomorrow.![]() |
#36 |
yes, that is a v6
i think i remember soneone talking about bad experiences with them on syty.net. sucks to hear your having troubles. i had some similar issues with my turbo build, i think they are inevitable for all these types of projects where you have to order alot of things. as long as you get your stuff your good, better late then never. patience pays lol
#37 |
#38 |
TURBOS SUCK
Justin, the wastegate will go out tomorrow. PEACE OUT>Tony
#39 |
yea i got your pm thanks man. that cheered me up!
#40 |
Re: bad news... good news (turbo Build)
well i tried calling them 2 more times today and no answer. i guess i am just gonna let it be. as long as the stuff is in one piece when it gets here. i doubt i would have gotten anything from them any way.
#41 |
well let me kno how the tru boost works for you, i thought it was a bit much. My boost is set by the wastegate no boost controller for me
#42 |
#43 |
I'm not sure what is up with AEM, but my Tru-Boost is still back ordered from 3 weeks ago.
#44 |
mine is supposedly on a truck some where.
also i got those heat sheilds thanks man you sir are awesome! |
#45 |
i don't understand what the tru boost does, above being a boost controller
#46 |
Boost/Vac gauge. That's about it.
#47 |
yea thats all it does on paper but because of the fact that it is digitally controlled it is much more accurate than a spring based waste gate alone. as the boost pressure rises springs tend to open slowly as they approach the boost level that is desired, meaning longer spool times and long times to full boost. the good ones minimize this but its still an issue. the tru boost keeps its valve and thus the waste gate completely closed until you reach exactly the level of boost that you want, resulting in faster spool and fast times to full boost.
and then of course their is the fact that you can adjust the boost pressure with the touch of a button instead of havening to physically change out springs. also one of the important features for me is that it allows you to run a waste gate spring for a lower boost level than you actually want to run. this means that in the event of a mechanical failure or problem with the tru boost or elsewhere it will either automatically run lower boost levels (in the case of the gage failure) or you can turn it down manually (engine failure) and hopefully save your shit! |
#48 |
you said they totalled your blazer!!!! whenever a insurance company totals a vehicle it gets the dreaded salvage title or cod title even if you buy it back. i cant imagine you doing all this work on a slavaged vehicle. did it retain the clear title when u bought it back? if not, you might want to move on unless its going to be a off road use only vehicle.
#49 |
my boost is 9psi like a rock, no peaking jus 9psi
#50 |
a little update. i worked on the truck a little this weekend. didn't get much done tho. a little disappointing. finished prepping the hood for paint,started to paint it and realized that i did not have as much paint as i thought i did. (had leftover from a previous repair). so i only had enough to do 2 light coats. right after the second coat a bug landed in the paint.
i pulled him out without disturbing the paint any further but when i tried to touch up the spot where he landed the paint ran. a very little run but a run none the less. so i will have to sand that down and then re prep the entire hood so that i can spray the rest of the color coats and then clear it. spent the rest of the weekend fixing my dads truck that some one keyed. that didn't go great either. but i will hopefully be able to fix his and mine this weekend. |
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f11/bad-news-good-news-turbo-build-313878/
| Untitled document | This thread | Refback | 12-02-2007 10:18 PM | |
