whats the better vortec head casting # for flow 12556140 or 12557113 - S-10 Forum
post #1 of 11 Old 01-03-2006, 05:48 PM Thread Starter
User is: toyrocs is offline
Anyone out there have any info on these casting #s ? The 12556140 casting came as a stock head in my 1998 vortec 4.3l engine with std rockers . The 12557113 casting i just got from a wrecking yard out of a 2000 s10 pu with the oem roller fulcrom rockers.Other than the slight hp increase going from std rockers to oem rockers are these castings ( 12557113) flow or are better in anyway than my current setup.( 1998 4.3l stock eng, k&n filter, cat delete,2.5" single exhaust, hand held flash program by street & performance). Btw i did a search on the 1257113 & found some info that it was a better casting, but no reason why, & no info found on the 12556140.Thanks. toyrocs
toyrocs is offline
post #2 of 11 Old 01-03-2006, 07:02 PM
User is: Dan Plante is offline
Re: whats the better vortec head casting # for flow 12556140 or 12557113
The only reason I can think that they are a better head is because they are a full roller head. That can be the only reason why. I mean they are both Vortec heads just yours are the older non-roller heads.
post #3 of 11 Old 01-04-2006, 11:01 AM
Gaaoooooo
MINTSICK's Avatar
User is: MINTSICK is offline
Flow numbers should be exactly the same for both heads, like Dan said the only difference is the roller fulcrum rockers in the 2000 set.
2004 Silverado Z71 ECSB - |Silver Birch Metallic|5.3|Custom Single Exhaust|Method Standards
1993 Mustang LX Hatchback - |Reef Blue|5.0 H.O.|5 Speed|MGW Short Shifter|70MM MAF|MAC Shorty Headers|Pypes O/R X|Spintech Pro Streets|3.55's|
1984 El Camino Conquista - |Black|5.0L|Comp XE262H|Holley 570|700r4 swap|2.41 open rear|
MINTSICK is offline
post #4 of 11 Old 01-04-2006, 06:42 PM
Unregistered User
j894's Avatar
User is: j894 is offline
Wonder why the engine with roller fulcrums dont make more power,
or they're not rated for a little more power. Still reduces alot of friction.
I know its still the stock 1.5:1 ratio... but am I missing something?
'01 Blazer, 5sp, 4x4
Retired: 1993 Chevy S-10 Blazer - 4x4,4.3L,CPI, auto
-Cardomain-
j894 is offline
post #5 of 11 Old 01-05-2006, 01:36 PM
Gaaoooooo
MINTSICK's Avatar
There's maybe a slight difference in power, I wouldn't say anymore than 1 or 2hp at most though so it's not worth re-rating the engine to 182hp.
MINTSICK is offline
post #6 of 11 Old 01-05-2006, 02:15 PM
Exactly. Running a full roller rocker is going to free up a very little hp. Nothing that you would notice.
post #7 of 11 Old 01-05-2006, 04:19 PM
Unregistered User
j894's Avatar
Just wondering, cause it hasnt really been mentioned before.
I figured with the reduced fiction, it had to do something.
just curious.
-Cardomain-
j894 is offline
post #8 of 11 Old 07-09-2009, 10:02 PM Thread Starter
just curious.
Yes the reduced friction thing with the rollers was what I was thinking also. Maybe reduced emmisions/ higher gas milage/ lower noise/ longer engine life( less wear on valve guide/ seal ) less oil comsumption ?
Toyrocs
toyrocs is offline
post #9 of 11 Old 07-09-2009, 10:07 PM Thread Starter
What would GM be doing with this change ( add rollers) if it didn't improve something? There is a reason for the rollers because every penny in production costs add up with the high production volume . They wouldn't have done it for "fun" or more power in this class of engine --- it's not a "sports" engine .
Toyrocs
toyrocs is offline
post #10 of 11 Old 07-09-2009, 10:50 PM
User is: poconojoe is offline
A good possiability is they wanted to be able to change the ramp speed for the new cam that eliminated the need for the EGR, which was a cost savings
post #11 of 11 Old 07-10-2009, 08:55 AM
"factory freak"...
Crew Cab Sonoma's Avatar
Toyrocs
not sure if fuel economy played a role or not, the economy
gains would have been only a fraction of a mpg.
IMO, the switch to oils with lower levels of ZDDP
probably was a bigger factor.
95 S-10 2.2. Soon to be DD
