What's missing on this vaccum hose tee fitting?
Old 08-31-2008, 07:09 PM   #1
They P'd on my F'n rug
ZQ8 Blazer's Avatar
ZQ8 Blazer will become famous soon enough
Question What's missing on this vaccum hose tee fitting?
Yeah I know I need a new hose. The tee was on there when I bought it w/ no hose connected to one end, I couldn't find a hose that could go on it so I just capped it off. Just wondering what's suppose to be there or if the tee is something someone added to the hose?
BTW it's on the drivers side next to the booster.
Old 08-31-2008, 07:34 PM   #2
BaggedXMAN's Avatar
BaggedXMAN can only hope to improve
Re: What's missing on this vaccum hose tee fitting?
for your NOS hook up!
Old 08-31-2008, 07:35 PM   #3
Registered (Ab) User
Yogi's Avatar
Yogi is on a distinguished road
If it's a 2nd gen, there is a ball type vacuum reservoir under the fender. Kinda hard to find.
Old 09-01-2008, 12:48 AM   #4
BaggedXMAN's Avatar
Blow Off Valve maybe?!?!
Old 09-01-2008, 01:04 AM   #5
ZQ8 Blazer's Avatar
uh.......it's not there. I know exactly what you're talking about, but it's no where to be found...
Old 09-01-2008, 01:12 AM   #6
easterwabbit
fastr68's Avatar
fastr68 is an unknown quantity at this point
hmm well my 91 doesnt have this at all
my vacuum ball is way overon the pass side wheel tub up on top right out in the open and has a tee totally different than this one and is neat the distributor in the back down low by the intake rear middle
the only rubber hoses on my driver side at all are the washer fluid tank pump and the cruise control on the driver side wheel tub top
original engine never pulled and nothing removed or modified
good luck
Old 09-01-2008, 09:41 AM   #7
s-clusive oh. prez
snoplow's Avatar
snoplow has a little shameless behaviour in the past
you sure thats 4 vacc. it kinda looks like a washer hose but gimmie a minute ill go out and look at my truck.
Old 09-01-2008, 09:52 AM   #8
s-clusive oh. prez
snoplow's Avatar
damn was to late to edit what i said. ok on mine it what u have plugged off goes to the vac. reservoir tank thats bolted onto my hood from the factory maybe urs is totally missing?
Old 09-01-2008, 11:10 AM   #9
Wire Splicin Fool :-)
lesterl's Avatar
lesterl is on a distinguished road
Thats not a T, it is a check valve that trys to keep the vacume in the ball for your vacume accessories (vacume doors on your HVAC/ Cruise controll, etc.)
Old 09-01-2008, 12:21 PM   #10
Yogi's Avatar
I would call it a combination "T" and Check Valve.
Old 09-01-2008, 09:29 PM   #11
lesterl's Avatar
Well, yeah, the checkvalve part just only lets vacume past the inlet, the T part allows vacume from ball to accessories.
Old 09-01-2008, 09:31 PM   #12
lesterl's Avatar
When I installed a cruise control on my '05 cavalier I used a 1' long piece of 2" PVC pipe and 2 endcaps, drilled a small hole in one end and glued a vacume fitting in place, worked great. And I also had the stuff around (looked for a vacume ball and I was getting $50 + prices.
Old 09-01-2008, 11:34 PM   #13
easterwabbit
fastr68's Avatar
wow you guys trucks are way totally different
never seena vcacuum ball mounted on a hood before
and ive been under the hood of billions of vehicles
looks like it is for vacuum ball for sure
good luck
Old 09-01-2008, 11:58 PM   #14
boar huntin' fool
4x4zr2GA's Avatar
4x4zr2GA is an unknown quantity at this point
if you have small hands... you can get to it by taking your tire off and unbolting the fender liner or wheel arch liner whatever you call it, pull it down as far as it will go and youll be able to see it. it was a bitch replacing the hose for mine... i didnt take the fender off, i just crammed my hand up there, felt for the nipple on the end of the ball, and squeezed the new hose on there...
Old 09-02-2008, 12:13 AM   #15
You got 30 minutes?
laydout97's Avatar
laydout97 is on a distinguished road
I agree with yogi, it is in fact for the vaccum ball. 1st gen trucks have this on the passenger fenderwell. 94-97 is on the hood and 98+ is inside the fender.
Page generated in 0.13557 seconds with 11 queries
