What's this goop in my radiator???
I flushed my radiator at the end of last summer. There was this thick, brown goop that was stuck inside the hoses, radiator opening, and on the bottom of the radiator cap that literally looks like brown snot.
Well I changed my oil yesterday and took my radiator cap off, just to check the level. There's even more brown goop build-up now! What causes this? Could it be the brand of antifreeze? I added some anti-rust/waterpump lube solution last year, could it be that? |
Re: What's this goop in my radiator???
Probably the oil cooler in the radiator side tank broke and is leaking oil into the coolant.
I took that oil cooler off years ago, and converted the filter mount to the non-cooler mount. It blew the line off of the fitting and I almost ran the engine out of oil once. This film in the radiator is like dried silcone actually. It's still very pliable, and just dirty brown. |
Maybe someone put leak sealer (glue) in it at one time?
JDepp FTMFW!!!
You're both wrong.
That crap is from your coolant. It's the wonderful thing called "Dexcool". Just do a search for Dexcool on google, and you'll come up with several links right off the bat about Dexcool sludging up your cooling system. Several people on the forum have done a good cooling system flush and converted over to the regular green coolant. Might be worth a try? |
If it is Dexcool, then you should be replacing your intake manifold gaskets before the coolant leaks in and destroys your engine. Check your oil for contamination. Dexcool sucks!
To be exact, it's the SuperTech generic Anti-freeze from Wal-Mart. Comes in a blue jug, and is orangish in color.
What would be a good brand to use? |
umm yea
Location: newly relocated 2 Glen Burnie MD User is: OffLine ![]() |
ya dexcool is what i was thinking, just try rinsing everything out and starting over.
the best protection for your application. GM was paying so much for intake gasket repairs several months ago so if any is having issues check back with the dealer. Last edited by pipster : 06-30-2008 at 03:52 PM. |
So don't mix green and orange coolant? |
I need a new truck!
pretty much lol, anytime you change coolant make sure you flush EVERYTHING out |
I've been draining it out this week by opening the drain peck when I get home each day, then filling it back up with just water after the engine cools. After doing this every day this week, I'll put some flush in the radiator on the way home Friday, then drain everything and refill/drain with water one more time before re-filling with a quality Coolant.
First thing I do on all of my GM cars that came with DexCool is drain, flush, drain, flush, drain, flush and then refill with regular Green Anti-freeze.
When you say "flush", do you mean actually putting radiator flush in each of those times after you drain, or just refilling with water, until you're ready to add the antifreeze? |
Just keep flushing it with water. You can leave the hose runnning for a long time... and force the flow in different directions by kinking one end of the heater hose and having it flow out of the radiator cap...
I'm sure you can figure it out... |
Ok, I was going to flush my radiator today (I have Dex cool in it) and I was looking under neath for about ten minutes trying to figure out where the drain (petcock?) for the radiator was. On my '94 2.2 it was easy to spot but with my 2002 4.3, I can't seem to find it.
yeah, same here i can't find the drain plug either, plus what you guys do with a cracked radiator? you think sealant would be the best and cheapest answer?
plus its been leaking coolant and drained out all the coolant a couple times from the intake side of the radiator, leaving the resevoir a rusty brown color inside of it. would flushing it out til its clear be the answer? btw 4.3 2000s10. any help would be appreciated greatly!
VC Vice Prez
the petcock for the 2000 and 2002 is on the driver side bottom of the radiator. It is a 3/8 plug. take a 3inch extension and a ratchet, put it inside the plug and turn towards the inner fender. you may or may not be able to use a 3in extension. If you cant find it, it may not have one.
drain/flush and refill with the dodge extended life coolant. i put this stuff in my mom's lumina and many friend's gm trucks... no sludge problems, stuff is great...
I thought there was an easier way to drain the radiator. The way it sounds it might be easier if I just bring it in to get flushed.
well thank you for the help, but there is a definite crack in the radiator and took it in this morning to a radiator shop and they told me it was from the dexcool, since i had i alot of rusty brown crap all in my resevior. so hopefully nothing else is wrong now.
#24 |
half bagged.
yep.get ready to do intake gaskets.definatly get that dex out.when i was a tech we always recomenneded to have it flushed and converted.get the kit that prestone makes.it makes it alot easier to flush.
#25 |
well instead of fixing the leak, it's too bad to repair, so instead i gotta get a new rad, but thanks for ur guys' help
#26 |
Ok, so again, I spent about ten minutes under my truck looking for the damn petcock or bolt to drain the radiator. I'm not sure where the hell it is. I can barely see the radiator, so I cant find the petcock. I don't want to start pulling hoses from it without knowing what they are. Please help... Thanks.
#27 |
#28 |
I Has a GREEN Dot
#29 |
I found it is easier to pull the radiator because the petcock is hidden under the lower hose on my 4.3. Pulling the rad. takes all of 10 minutes. I flush with Prestone flush the first time and water each time after that.
