What is the Coolant capacity of my 4.3? - S-10 Forum
post #1 of 5 Old 12-04-2009, 12:59 PM Thread Starter
User is: Johnny_S-10 is offline
This weekend I'm gonna be installing a OEM Block Heater, and while I'm at it I'm going to replace my thermostat, and convert my cooling back to the green stuff. So I plan to flush out my cooling system first, but was curious if anyone knew the full capacity of coolant used in a 4.3 engine? Any feedback or responses would be greatly appreciated!
2000 Chevrolet S-10 LS Reg. Cab Short Box
....................4.3L Vortec 2WD
post #2 of 5 Old 12-04-2009, 06:54 PM
I make pneumatics
262X02's Avatar
User is: 262X02 is offline
Send a message via AIM to 262X02
Re: What is the Coolant capacity of my 4.3?
Its somewhere arround 2 gals, but it should be listed in your owners manual on the exact amount.
Brandon
06 TBSS AWD - my DD
10 MKV Jetta TDi - wife's DD
02 Xtreme, 4.3L, 5-speed, K&N FIPk, B&M shifter, Blazer DP Front Brakes, LS1 Disk Rear Brakes, PermaCool e-fans, Flowmaster 40 dual side exit, Marine Intake Manifold, CompCams 270AHR, CompCams High Energy Lifters, Cloyes Timing Set, MSD coil, Taylor 8.2 wires, PLX Wideband, HPTuners Pro, 39lb EV6 Bosch Injectors
Coming Soon: Turbo, Syclone headers & crossover, new Magnaflow exhaust
262X02 is offline
post #3 of 5 Old 12-04-2009, 08:19 PM
Dain Bramaged
User is: b1lk1 is offline
6 liters of coolant and 6 liters of water.
b1lk1 is offline
post #4 of 5 Old 12-05-2009, 10:41 AM
Dallas Anyone?????
SpiderDallas's Avatar
User is: SpiderDallas is offline
I found the exact amount on mitchell for you 50/50 mix 11.70qts in the auto and 11.90qts in the standard.
post #5 of 5 Old 12-07-2009, 08:53 AM Thread Starter
Thanks!
