what does the M.A.P. sensor do - S-10 Forum
post #1 of 18 Old 07-12-2001, 06:51 PM Thread Starter
98esten's Avatar
User is: 98esten is offline
Send a message via AIM to 98esten
I was told it might be bad on my truck i dont know what it does
98esten is offline
post #2 of 18 Old 07-12-2001, 07:01 PM
Tha_Boom's Avatar
User is: Tha_Boom is offline
It is a manafold air pressure sensor. Pretty much it just measures how much vacume your engine is pulling. The computer uses this information to adjust fuel and spark.
Tha_Boom is offline
post #3 of 18 Old 07-13-2001, 11:29 PM Thread Starter
98esten's Avatar
how can you tell if it bad
98esten is offline
post #4 of 18 Old 07-14-2001, 01:38 AM
Tha_Boom's Avatar
Ok there should be 3 wires 1 ground 1 5volt 1 return signal. (at least on the older ones) If you run a multimeter from a body ground and return signal you should see fluctuating voltage from 5 volts on down with engine running and hitting the throttle a little.
I am not sure if the pinout is the same on the newer tucks but the middle pin is the return signal on the older ones.
<==- 86 4.3 Blazer Sport -==>
<==- 89 4.3 Blazer Tahoe -==>
Whoomp! There It Is.
Originally Posted by orangesonoma
...i will love you forever...
Tha_Boom is offline
post #5 of 18 Old 07-16-2001, 11:49 AM
General L33
Hotwire's Avatar
User is: Hotwire is offline
Send a message via AIM to Hotwire Send a message via Yahoo to Hotwire
duh, never thought to look in the service manual. when we get back up, I can check it. If you feel like driving back down my way, I can get your truck scanned for free.
*Jeff*
1998 4dr 2wd Blazer, 06 L33 5.3L, LS6 cam, 3.73s, built trans, etc.. http://www.s10forum.com/forum/f213/p...blazer-512528/
Hotwire is offline
post #6 of 18 Old 07-16-2001, 03:59 PM Thread Starter
98esten's Avatar
ok sounds good. I will call you sometime later this week
98esten is offline
post #7 of 18 Old 03-10-2007, 06:10 PM
User is: jammon is offline
Re: what does the M.A.P. sensor do
hey now a shout from out west.want to know conditions before
you fixed it. I'm having rough accl. & idle. ('89 4.3 TBI) feels like running out of gas.Fuel filter, ign mod, cap rotor, usual stuff?
Any help appreciated
jammon is offline
post #8 of 18 Old 03-10-2007, 06:45 PM
User is: MadMikeZ28 is offline
Check all your vacuum lines. Look carefuly. I had onr going to the map that was split right where it hooks to the sensor but could not see it until I bent the hose over.
If I acted like some of the people here do and ran to someone when ever my feelings were hurt I would have been called a sissy and then ridiculed for that as well. I suppose I just grew up in a time when we were all tougher and turned out to be men and women instead of staying crying children.
post #9 of 18 Old 03-10-2007, 06:50 PM
yes, that is a v6
s10ls's Avatar
User is: s10ls is offline
Send a message via AIM to s10ls
first thread ever started on s10forum?
but jammon sounds like a vacuum leak
turbocharged 4.3l, sectioned HSR with aluminum heads, twin t3/t4's
de-bagged for coilovers
Project thread - http://www.s10forum.com/forum/f11/tw...letion-423956/
s10ls is offline
post #10 of 18 Old 03-11-2007, 03:01 AM
Oh damn I let that slip by. This is an old one.
post #11 of 18 Old 03-11-2007, 04:42 PM
SILENCE! I KILL U!
rockfan1815's Avatar
User is: rockfan1815 is offline
if you blip the trottle real quick from idle, the engine will bog down, this happens the most when the vac line going to it is clogged or cut open. using a volt meter should give you some answers.
post #12 of 18 Old 11-11-2010, 06:29 PM
User is: gmcjoe is offline
My 95 s10 I just changed the ing modgule and its still running fough and I unpluged the map sensur what is it now
gmcjoe is offline
post #13 of 18 Old 11-12-2010, 09:56 PM
King Turd Polisher
89Chubby's Avatar
User is: 89Chubby is offline
Throttle position sensor, perhaps? (You can test them with a voltmeter.)
Also, are you getting a Check Engine Light (CEL)? Or have you tried to pull the diagnostic codes yet?
1989 Chevrolet S-10 Blazer 2WD 4.3 auto (SOLD)
1986 GMC S-15 2WD X-cab 2.8L T-5 (SOLD)
1992 Chevrolet S-10 Blazer 4WD 4.3 auto (DAILY BEATER - 235k and still going)
89Chubby is offline
post #14 of 18 Old 08-29-2012, 12:05 PM
User is: frankiel is offline
I have a 0-3 4.3L eng and am having problem with MAP sensor voltage on volts test eng. running volts should go up when eng. is revved but mine volts go down.what gives
frankiel is offline
post #15 of 18 Old 08-29-2012, 04:23 PM
burned's Avatar
User is: burned is offline
Test guide:
http://troubleshootmyvehicle.com/gm_...ensor_gm_1.php
2002 Dakota, QC 4x4, 4.7L HO Intake.
1997 S10 ZR2, Ext Cab, 5 Speed (SOLD)
How to test fuel pressure and leak down <---diagnostic help
burned is offline
post #16 of 18 Old 09-02-2012, 10:17 AM
User is: Takeum is offline
This is why I changd back ver to a carburetor,,just too many issues with all these electronics.....forever failing and causing poor drivability issues,,,
Takeum is offline
post #17 of 18 Old 03-09-2013, 01:52 PM
looking for a pin arraingment on a 0-3 4.3l computer i think map censor ground wire ic open or corroded at the computer
frankiel is offline
post #18 of 18 Old 03-09-2013, 08:20 PM
burned's Avatar
http://troubleshootmyvehicle.com/gm/...map-sensor-3#3
A ORG to PIN #23
C GRY to PIN #17
B LT GRN to PIN #4
burned is offline
