What does P0103 Mass or Volume Air Flow Circuit High Input mean? - S-10 Forum
post #1 of 13 Old 01-29-2008, 07:35 PM Thread Starter
ZQ8 Blazer's Avatar
User is: ZQ8 Blazer is offline
ℐustin
post #2 of 13 Old 01-29-2008, 07:42 PM
Life Begins @ Zero PSI
jakefiddlesticks's Avatar
User is: jakefiddlesticks is offline
Re: What does P0103 Mass or Volume Air Flow Circuit High Input mean?
ECM code for the mass air flow sensor.
Did you install a cold air intake?
If your truck doesn't run its time to replace the MAF.
wanted 2002 4.3 5 speed gauge cluster
post #3 of 13 Old 01-29-2008, 07:44 PM Thread Starter
ZQ8 Blazer's Avatar
it runs fine and I have a cold air intake, but I installed it back in october and the code just showed up...
ℐustin
post #4 of 13 Old 12-02-2010, 10:36 PM
User is: Demonchild is offline
***cough***cough***bump from almost three years ago.
I lurk around these forums, however, I've never had any issues with that noma. First post: does anyone know what cause a p0103? Truck is running fine. I'm completely stock.
post #5 of 13 Old 12-02-2010, 10:41 PM
zacharyh687's Avatar
User is: zacharyh687 is offline
try cleaning the MAF with the cleaner that they sell at the autoparts store and reset the computer and see if it comes back on
96 Chevy Blazer 4.3L HO 4L60E with 291,XXXmi and 14x,xxx on a reman 4.3.. Mods: 5000K 35W hid's, K&N drop in filter, Magnaflow high flow cat, MSD coil.
09 GMC Sierra 1500 X-Cab Short Bed 4.8L auto.
Mods. Magnaflow exhaust true duals.
5k hid. Undercover se tonneau cover. Afe dry flow air filter. Diablo sport predator.
future mods. Factory fog lights with hid. Billet front grille. And stereo system
post #6 of 13 Old 12-02-2010, 10:45 PM
Wire Splicin Fool :-)
lesterl's Avatar
User is: lesterl is offline
It is an error triggered by too high of a frequency of the MAF sensor and as I recall that would be excessive airflow thru the sensor....
lesterl is offline
post #7 of 13 Old 12-03-2010, 01:45 AM Thread Starter
ZQ8 Blazer's Avatar
When I reset it it never came back.
ℐustin
post #8 of 13 Old 12-03-2010, 02:36 AM
I reset my computer and then did some errands tonight. I haven't thrown a code yet. I'll keep an eye on it. I think I'll get some MAF cleaner this weekend. Has anyone ever had any adverse effect with using it?
1998 Sonoma
4.3L v6|5 speed|completely stock
post #9 of 13 Old 12-03-2010, 02:41 AM
AWD V8's Avatar
User is: AWD V8 is online now
Oiled air filters will cause the MAF to send an code.
post #10 of 13 Old 12-03-2010, 02:47 PM
Why will oiled air filters cause a code?
1998 Sonoma
post #11 of 13 Old 12-03-2010, 08:12 PM
AWD V8's Avatar
The oil picked up by the air flow over the filter media will coat the MAF sensor wire and throw the resistance off resulting in an inaccurate reading of the air flow, thus the ECM throws a code. Cleaning sometimes works, but it will happen again unless the type of filter is changed to a dry paper element.
I've seen this lots of times.
post #12 of 13 Old 12-04-2010, 08:30 PM
lesterl's Avatar
Depends upon how heavily you oil them, I have run plenty of K&N filters and never threw a MAF code.
The MAF sends out a signal based upon the resistance of the wires in the unit. The resistance is dependent upon the airflow over the wires. The PCM monitors the signal and alters the fueling parameters based upon the signal. If the signal falls out of a preprogramed threshold for certian other engine paramters, I.E. RPM/ MAP/ ETC..... it will set a DTC assuming something is wrong with the MAF.....
lesterl is offline
post #13 of 13 Old 12-11-2010, 08:04 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Perform POWERTRAIN ON-BOARD DIAGNOSTIC (OBD) SYSTEM CHECK. Retrieve and record FREEZE FRAME and/or FAIL RECORDS data for each DTC set. After performing OBD system check, go to next step.
Start engine. With engine at idle, use scan tool to read MAF value. If MAF value is greater than 20 gm/s, go to step 4). If MAF value is not greater than 20 gm/s, go to next step.
Turn engine off. Turn ignition on, engine off. Using scan tool, read and record FAIL RECORDS data. Operate vehicle within conditions noted in FAIL RECORD data. Using scan tool, read SPECIFIC DTC. If scan tool displays that this DTC FAILED THIS IGN, go to next step. If scan tool does not indicate that this DTC FAILED THIS IGN, see DIAGNOSTIC AIDS.
Turn ignition off. Disconnect MAF sensor harness connector. Start and allow engine to idle. Using scan tool, read MAF value. If value is about 0 gm/s, go to next step. If value is not 0 gm/s, go to step 7).
Check for faulty connection at MAF sensor. Repair as necessary. After repairs, go to step 10). If connection is okay, go to next step.
Replace MAF sensor. After replacing sensor, go to step 10).
Ensure MAF sensor harness is not routed too close to high-voltage wires, such as spark plug cables, ignition coils or other high-voltage components. Reroute harness if necessary and then go to step 10). If harness routing is okay, go to next step.
Check MAF sensor signal circuit connection at VCM. Repair as necessary. After repairs, go to step 10). If connection is okay, go to next step.
Replace VCM. Program replacement PCM using required equipment. After replacing VCM, go to next step.
Using scan tool, select DTC, CLEAR INFO function. Start engine and allow it to reach operating temperature. Using scan tool, select DTC, SPECIFIC function and enter this DTC. Operate vehicle within conditions required to set DTC. If scan tool indicates that this DTC RAN AND PASSED, go to next step. If scan tool does not indicate that this DTC RAN AND PASSED, repeat step 2).
Using scan tool, select Read and Record INFO, REVIEW INFO function. If any undiagnosed DTCs are displayed, diagnose affected DTCs. If no additional DTCs are displayed, system is okay.
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
