Registered Pimp
Truck acting goofy
Basically, my dad ripped the y pipe pretty bad about a year and a half ago. It was totally broke in half and crushed, so a month or 2 back my friends dads friend welded it up, but theres still a little hole. Lately its been seeming to take longer to start up. I might have to crank it for 2-3 secs, when it used to be instant. Also, when I floor it, its gets a wierd hesitation. It sounds like the rpm's kind of drop for a sec then really high, then go to normal, they basically kind of fluctuate. Its not really bad, but it sounds like ass. You think it might be some kind of O2 problem? I plan on a new y pipe. And also my trannys going too, bangs into gear after exactly a half hour of driving. And a few times it went into neutral when I put it in reverse. My trucks getting old, id appreciate the help.
*98 ZQ8 Ex Cab Stepside 4.3 150,000 miles* |
Local Tech
Re: Truck acting goofy
if you had been driving it with a substantial exhaust leak for a long time, you may have burnt a valve..... another possibility is the exhaust leak may be oxygenating the readings of an 02 sensor, causing a rich mixture..... these arent terribly likely, but according to the info i got, these are my ideas, considering that you mentioned the leak
Registered Pimp
Your engine could be running rich from the leak and fouling up the plugs, I would start with plugs cap and rotor as a likely culprit. Get a new Y-Pipe made, most muffler shops could bent and weld a new one for you.
Registered Pimp
How much you think itll run im probably gonna do 2 1/4. I dont wanna get screwed. Should be around $100 right? |
Blue-X
Registered Pimp
Wire Splicin Fool :-)
16/ 21?
stupid regular cab!!
Registered Pimp
If anyone can help I keep trying to change my age but no luck.
I think you have to do it like everyone else, one day at a time! :-)
Registered Pimp
haha
