Torque Converter Bolts
Old 07-02-2009, 11:14 PM   #1
Re: 1999 S10 4.3 Auto 2WD
Ok, before I break something, what's the trick to removing
these torque converter bolts through the starter hole area?
Obviously the engine rotates with the flywheel, so what is
the best way to remove them? And what is the exact size?
They seem to fit 15mm, but I assume they'd be standard?
Old 07-03-2009, 12:46 AM   #2
Will work for turbo parts
Re: Torque Converter Bolts
They are metric. I used a wrench on the crank pulley (5/8 socket) to hold it while I bust them loose, then use an air ratchet.
Old 07-03-2009, 06:53 PM   #3
Worked great, thanks.
Old 07-05-2009, 12:19 PM   #4
2ToeRacing's Avatar
small 3/8 impact gun,i have a bad-ass snap-on one. Hit them with a small hammer first,sometimes it helps. Are these the steal looking 15mm bolts or a aluminum ones that have a allen head hole in the middle?
I have had to use a impact hammer with a flat chisel to get them out.let us know how it went. Sometimes a air ratchet will work,sometimes not
Page generated in 0.55748 seconds with 31 queries
[Output: 49.46 Kb. compressed to 47.15 Kb. by saving 2.31 Kb. (4.67%)]
