Throttle body blade wont close all the way - S-10 Forum
post #1 of 10 Old 10-20-2012, 08:12 PM Thread Starter
User is: redlineaddiction is offline
I need an reponse as soon as possible. i am cleaning my throttle body and it was difficult to get the blade off so i pulled a little harder and it finally came out well i got everything cleaned and took the diffuser off and when i tried to put the blade back in it doesnt close all the the blade isnt bent and from what i can see the sandwich thing that the blade screws too isnt bent. i sont know what to do
post #2 of 10 Old 10-20-2012, 08:18 PM
AWD V8's Avatar
User is: AWD V8 is offline
Re: Throttle body blade wont close all the way
Sounds like you installed the plate the wrong way around. Either upside down or wrong side around.
The blade is designed to fit the bore very close.
AWD V8 is offline
post #3 of 10 Old 10-20-2012, 08:22 PM
992drjimmy's Avatar
User is: 992drjimmy is offline
Be sure its perfectly clean. If it is, clean it again. Same thi g happened to me.
Sent from my SGH-T999 using AutoGuide App
*97 GMC JIMMY 4x4 on AR wheels with 275/60/15(SOLD)
*02 GMC Sonoma Highrider(ZR2) with 3" body lift on 15x8 ion wheels, 5.5" backspaced with 33x12.50 kumho road venture MTs
*98 MUSTANG GT Not at all Stock.
*01 Monte Carlo SS fully loaded
post #4 of 10 Old 10-20-2012, 10:11 PM Thread Starter
Ok so i sprayed an entire can of throttle body cleaner in it and it looks almost polished inside. i ended up taking the trottle body off and got the blade in put it all back together but it still idles at 1k. Is that just he throttle body cleaner going through the system or something else. Oh and btw i took the one sensor one sensor that reads from the inside of the throttle body off and cleaned it too. Its not the one on the shaft
post #5 of 10 Old 10-21-2012, 07:14 AM
User is: Coyote1 is offline
The one off the shaft is the Idle Air Control Valve, cleaning it will take it under a minute to adjust its self. When you put the blade back in open and close the throttle a couple of times before installing the screws to make sure its centered. Sometimes after cleaning the TB you may have to adjust the throttle stop screw if it sticking when you press the gas pedal adjust the screw in a 1/16 to 1/8 of a turn.
Coyote1 is offline
post #6 of 10 Old 10-21-2012, 11:36 AM
burned's Avatar
User is: burned is offline
If the throttle plate does not seal or if those rivets holding the diffuser have come out it will idle high.
2002 Dakota, QC 4x4, 4.7L HO Intake.
1997 S10 ZR2, Ext Cab, 5 Speed (SOLD)
How to test fuel pressure and leak down <---diagnostic help
burned is offline
post #7 of 10 Old 10-21-2012, 04:38 PM Thread Starter
ok so there are holes where the rivets used to be. That would make it idle high ? If so how do i repair the holes ?
post #8 of 10 Old 10-21-2012, 04:43 PM
Registered Hoosier
Hoosier Rick's Avatar
http://www.s10forum.com/forum/f107/h...emoval-348823/
2002 rcsb, 2.2 at, 267,000 miles
1967 C10
post #9 of 10 Old 10-22-2012, 01:17 AM
burned's Avatar
If the rivets are no longer there you can put some in with a pop rivet gun. Or go to a wrecker and get another throttle plate and re do the mod by cutting off the half moon only this time.
Yes it will idle high, there should only be the center hole. Too much air is getting in while the TPS reads zero.
burned is offline
post #10 of 10 Old 10-22-2012, 01:19 AM
Ninja Owns Me
User is: BLKzq8noma is offline
It sounds like it is not in perfectly. There is very little if any room for tolerance if its not in perfectly. Move it around a bit and open and close the blade with the throttle cable. Make sure there is no carbon on the throat of the throttle body. Dont mess with the rivets.
