This must be a joke ? Firing order...
Old 11-01-2009, 06:21 PM   #1
Jesper's Avatar
Found this on another forum site :
CAB
6-5
4-1
2-3
GRILL
Is this in reference to the cap or the engine?
The engine goes:
CAB
6-5
4-3
2-1
GRILL
Right?
Old 11-01-2009, 06:47 PM   #2
Gettin' ready for V8!
03blazer's Avatar
Re: This must be a joke ? Firing order...
Firing on a 4.3 is 1-6-5-4-3-2 if I'm not mistaken.
Doesn't matter where they go on the cap as long as they are in that order.
Old 11-01-2009, 06:57 PM   #3
Founding member of DA
pack of q tips's Avatar
Actually it does matter where they go on the cap. The cap is labeled to help you out
Old 11-01-2009, 07:01 PM   #4
03blazer's Avatar
Actually, it depends on which engine it has in it... And, no, it doesn't really matter where they go. It'll still run fine if they're in the correct order. I moved mine around so it would make routing them easier.
Old 11-01-2009, 07:15 PM   #5
Jesper's Avatar
I must be absolutely honest, i didn't understand that at all.
Move them around? doesn't really matter where they go on the cap?
I made a search on this because I'm wondering if I mixed up number 1 and 3 when I put it back together after the LIM gasket change.
Old 11-01-2009, 07:18 PM   #6
03blazer's Avatar
It matters what order they go in, just not where they are on the cap. I'm assuming you have the crab style cap with the posts on the sides. They should all be labeled on the cap.
Old 11-01-2009, 07:23 PM   #7
Jesper's Avatar
yes and yes. but in the first post. it's the last one that is correct in reference to where the wires go on the engine right?
Old 11-01-2009, 07:24 PM   #8
if you set the motor on top dead then just drop the distributor in where the rotor is pointing you could use as number one. it dont matter where the wires are as long as the rotor points at number one wire when on top dead because it will still fire the right. i have done this in the past and if you think about it you will see what im talking about
Old 11-01-2009, 07:27 PM   #9
03blazer's Avatar
Yes the last one is the correct one.
Old 11-01-2009, 07:29 PM   #10
i almost forgot the crab cap the must go where they belong to run right and
6-5
4-1
2-3 is the way they are numbered on the cap
passenger side of cap front to rear is 246 then coil and driver front to rear on the cap is 315
Old 11-01-2009, 07:32 PM   #11
Jesper's Avatar
thanks!
Old 11-01-2009, 07:38 PM   #12
It most certainly matters where they go on the cap on the vortec motors.
Old 11-01-2009, 07:49 PM   #13
03blazer's Avatar
Hmm... tell that to the engine in my Blazer...
The only one you can't move is the coil wire...
Old 11-01-2009, 07:58 PM   #14
The plugs on the cap are not in firing order. They are set up so wires don't have to cross over the cap to go to the Correct plug
Old 11-01-2009, 08:23 PM   #15
not low, not gonna be...
Crew Cab Sonoma's Avatar
CAB
6-5
4-1
2-3
GRILL
The engine goes:
CAB
6-5
4-3
2-1
GRILL
Right?
the top figure is correct for 96-later dist. caps.
the bottom figure is the correct cylinder numbering
for the engine itself, for all years of 4.3's.
Old 11-01-2009, 09:06 PM   #16
Jesper's Avatar
what about a 1995 dist cap?
Old 11-01-2009, 09:45 PM   #17
95-older, are vertical terminal, and not arranged
"side-to-side" like the late models.
they just start where ever #1 is/was, and go clockwise
from there, following the firing order. 1-6-5-4-3-2...
Old 11-02-2009, 07:05 AM   #18
Since the cam sensor in the distrubuter has to be synced with the rotor and cam timing, you're a moron if you think it doesn't mater where the wires go on the cap. It might run but not correctly and I doubt if it will run at all.
Old 11-02-2009, 09:18 AM   #19
i'm just wondering how he gets some of his plug wires
to stretch around to other side of the cap...
Old 11-02-2009, 05:02 PM   #20
03blazer's Avatar
The cap I have is aftermarket... The posts are not labeled on mine. Idk why... It came from Accel that way... I can move the wires wherever I want on the cap and it runs fine... as long as they're in correct firing order...
Anyways, that doesn't matter...
To the OP, I hope your questions have been answered and I apologize for the slight thread-jacking...
Old 11-02-2009, 05:33 PM   #21
so you have an aftermarket ignition system?? thats a whole different story
Old 11-02-2009, 07:43 PM   #22
95tahoelt's Avatar
[quote=03blazer;6605563]The cap I have is aftermarket... The posts are not labeled on mine. Idk why... It came from Accel that way... I can move the wires wherever I want on the cap and it runs fine... as long as they're in correct firing order...
I just pulled a Accel Dist and rotor cap off my blazer and That thing is the worst quailty I have seen, a year old and they were junk.
There is No way it will run right crossing wires. Dont be a morron!!!!!!!!
Old 11-02-2009, 07:47 PM   #23
03blazer's Avatar
[quote=95tahoelt;6605833]
You guys can think what you want... I really don't care. There is no point in starting an argument over it. And if you're gonna call someone a moron, learn how to spell it first, @$$hole!
Old 11-02-2009, 07:56 PM   #24
does your aftermarket cap look like the stock cap or do you have an old style cap where the plugs point straight up and down?
Old 11-02-2009, 08:26 PM   #25
03blazer's Avatar
It's the crab style cap. I have never seen one like it. I'd show you a pic of it if I were home. I'm on deployment now... It's made a little different than the Vortec cap. Looks almost just like it, but it's almost smooth on top.
Old 11-02-2009, 09:03 PM   #26
paint color? ... Mud =D
83blazer28's Avatar
i hardly believed it the first time someone told me the firing order on a 2.8 is 1-2-3-4-5-6, i looked at them like they had six heads
Old 11-03-2009, 03:21 AM   #27
95tahoelt's Avatar
[quote=03blazer;6605837]
Excuse me, I read and write in 4 langauge's and can speak 6...
sometimes flipping the switch is confusing.....
Actully a morron is a pepper.
Old 11-03-2009, 10:51 AM   #28
i'm sure the order of the terminals is the same as stock.
the question is why would you even want to alter the
wires from their original positions, since some of the wires
would have to cross over to the far side of the cap???
kinda deafeats the purpose of the "crab" style cap,
doesnt it?
and you would likely have to have some kind of
"universal fit" wires to achieve this....
i dont think stock or stock replacements would have
enough lenght to achieve this.
Old 11-03-2009, 10:57 AM   #29
Registered Neanderthal
SH-60B's Avatar
[quote=95tahoelt;6606683]
You forgot to "flip the switch" on the word actually, you "morron".
Old 11-03-2009, 11:32 AM   #30
did you just call him a "pepper"???
Old 11-03-2009, 12:09 PM   #31
405AWDHP
Draggin88's Avatar
This thread is full of fail. Isn't it?
Page generated in 0.60467 seconds with 31 queries
[Output: 146.50 Kb. compressed to 134.44 Kb. by saving 12.06 Kb. (8.23%)]
