symptoms for bad rod bearing - S-10 Forum
post #1 of 9 Old 12-18-2010, 03:57 PM Thread Starter
BBs-10's Avatar
User is: BBs-10 is offline
i bought a 92 with the 4.3 motor (90k miles original) in it for $900 bucks. the guy said he thinks it has a spun rod bearing. everything else on the truck is in great shape so i got it with the intention of 350 swap around the
summer.
what are symptoms of bad rod bearings. it gets about 40 psi oil pressure when driving. and it runs kinda rough, just thought it could use a tune up. what should i be looking for before pulling the motor. id like to use it as a work truck for awhile if the motors okay
always accepting donations
BBs-10 is offline
post #2 of 9 Old 12-18-2010, 04:16 PM
AWD V8's Avatar
User is: AWD V8 is offline
Re: symptoms for bad rod bearing
Well the most obvious symptom is a knock.
If it's knocking, while running pull the plug wires one at a time. When you get to the cylinder with the bad bearing the knocking will be much less.
AWD V8 is offline
post #3 of 9 Old 12-18-2010, 09:17 PM Thread Starter
BBs-10's Avatar
ok. planning on changing the oil tomorrow to check it and cut the filter open to see how material is in it.
as far as the knocking. you cant hear it unless you rev it up from the throttle body. it is not noticeble from the cab when driving. ill try the plug wire thing too. thanks
BBs-10 is offline
post #4 of 9 Old 12-18-2010, 09:21 PM
terrible. take a lap.
joyride's Avatar
User is: joyride is offline
Send a message via AIM to joyride
What's the oil pressure like? You sure it just isn't an exhaust leak or loose exhaust manifold bolts? Just throwing it out there.
Brian
01 xtreme 4.3L 5spd 2/3 drop w/ SS front bumper|.030 over|270 comp cam|500 lift|dual valve springs|10:1 C/R|p&p heads w/ 3 angle valve job|w4me tune|shorty headers|2.25 y pipe|no cat|Spintech muffler|windage tray|LW flywheel|DF clutch|8mm wires|no ac|efan|walbro 255|MPFI upgrade|Comp Cam timing chain|ARP bolts/studs|totaled***
Now owner of a white 2002 Blazer Xtreme
http://www.youtube.com/watch?v=CO_A1IrbQNM
85 Monte Carlo SS
KCCO
joyride is offline
post #5 of 9 Old 12-18-2010, 10:33 PM
xtreme no more
bagd00xtreme's Avatar
User is: bagd00xtreme is offline
I bought a truck that had a bad rod bearing and it had no oil pressure at idle but if you revd it up it would build pressure. I think as long as you have oil pressure through all rpms your bearings are probably good. It could just be a noisy top end like lifters or something. just my 2 cents.
post #6 of 9 Old 12-18-2010, 10:45 PM
Wire Splicin Fool :-)
lesterl's Avatar
User is: lesterl is offline
Could be carbon build up also, might seafoam the top end before you change the plugs and such.......
lesterl is offline
post #7 of 9 Old 12-19-2010, 11:11 AM
Tom1994's Avatar
User is: Tom1994 is offline
Originally Posted by joyride View Post
What's the oil pressure like? You sure it just isn't an exhaust leak?
The way you describe it, that is my bet
Tom1994 is offline
post #8 of 9 Old 12-23-2010, 11:56 AM
User is: joeek is offline
I had perfect oil pressure all rpm range. had 3 rod bearings and 2 main bearings spun + 2 rod bearings very bad.
I had bad noise from my engine.
joeek is offline
post #9 of 9 Old 12-24-2010, 02:16 PM
User is: lessersivad is offline
I didn't see anything in the posting about what transmission you have. If it's an automatic then i would check the flexplate around where the bolts hold it to the back of the crankshaft.
My daughter's '91 w/4.3 had what I would call "an intermittent knock". I thought "great, rods and/or mains".
Was talking to a friend of mine one day and he suggested checking the flexplate. Dropped the inspection cover unbolted the torque converter and slid it back, sure enough, cracked dang near all the way around between the bolts. Took around 2 hours to change and no more knock.
This is only my 2ΒΆ. YMMV.
