Symptoms for a bad Throttle Position Sensor - S-10 Forum
post #1 of 11 Old 01-26-2006, 02:59 PM Thread Starter
hatetheblazer
User is: lovetheblazer is offline
Does anyone know what happens when this part goes bad or starts going bad?
'99 Blazer V6 4.3L Vortec 262ci, custom y-pipe, no cat, Flowtech Raptor Muffler, K&N FIPK 2, MSD Blaster Coil...
$$$SOLD AND GONE FOR GOOD!
post #2 of 11 Old 01-26-2006, 06:46 PM Thread Starter
hatetheblazer
Re: Symptoms for a bad Throttle Position Sensor
hello?
post #3 of 11 Old 01-26-2006, 06:48 PM
Primer?
Tha s-10's Avatar
User is: Tha s-10 is offline
On hard take off it studder, may not want to idle, hesitation, bad mpg, it goes on and on .
What problems r u having
Mods350 vortec,edelbrock performer rpm carb mani
600 edelbrock carb,Holley electric pump
fuel pressure regulator,.488 lift cam duration 292
headers 2 1/2 exhuast true duals,flowmaster mufflers,hei distributer stock,vacuum advance curve kit,Trans/ Rear end,700r4 stock stall,Vette servo
street shift kit,Z-28 camaro rear end 3:73 posi
Tha s-10 is offline
post #4 of 11 Old 01-27-2006, 06:28 AM Thread Starter
hatetheblazer
Shaking at idle...already did a super complete tune-up and it's still there...
post #5 of 11 Old 01-27-2006, 06:47 AM
takes 2 balls in our game
s10-den's Avatar
User is: s10-den is offline
mine did the exact same thing as this.never could get it out so i sold it was a 4.3 5 speed truck
s10-den is offline
post #6 of 11 Old 01-29-2006, 11:44 AM
Primer?
Tha s-10's Avatar
4.3l are very shaky with out a balance shaft. But sounds like iac more than tps any engine lights
Tha s-10 is offline
post #7 of 11 Old 01-29-2006, 07:03 PM
Blown ex ***
Jess's Avatar
User is: Jess is offline
the trans will shift funny, if the tps is bad.
97, VORTECH V2 SQ, PowerStroke FMIC @14 psi, A4, 3.08
a broken down 13.88 @ 96.65
now with, 2114, 270ahr, ported heads, 1 5/8 L/T's & true duals, TunerCat, LC1 & XD-16, 3:73 Z/T
My Truck...
95 x-cab, silver, tint, 4.3cpi, a4, 2/3 = after 10+ years its rusted out badly.
its replacement = pewter reg cab 01, 4.3, A4 and 0 rust
Jess is offline
post #8 of 11 Old 01-29-2006, 07:13 PM
.:|Hustlin4life|:.
dirttysouth's Avatar
User is: dirttysouth is offline
I had the TPS go out on an F150 I had, and it was alot like having a mess uped transmission, when I tried to go up even a small hill it would not pull itself up the hill and it would shit really jerky and hard at times
post #9 of 11 Old 01-29-2006, 08:25 PM
A4, A5, A6, A8 ASE Cert
madscientist101's Avatar
User is: madscientist101 is offline
Send a message via AIM to madscientist101
sounds like a vacuum leak or a sticky EGR VALVE, check your lines and take off the EGR valve and clean out the passageways in the EGR intake and the valve itself. the comp its trying to run rich when its running lean
post #10 of 11 Old 01-30-2006, 01:54 PM Thread Starter
hatetheblazer
When I was just about to buy every freakin' sensor built for the '99 4.3l 262ci, and approx. $1500 after...
I re-checked the motor mounts and I guess I mounted one incorrectly 'cause when I tookthe nuts out of the lh motor mount and pushed the engine up with the jack it fell apart in half...without doing this you could say that the mounts were ok...BUT the engine is now smooth...
It still shakes but nothing like it was before... I know 4.3's are shakers but now it is smoother than ever...Now I am back in love with my truck again...was really considering selling it...
post #11 of 11 Old 01-30-2006, 10:31 PM
If you want to check for a Bad TPS, jump the tps with three wires then hook up a voltmeter in parrallel with the graound and signal wire and start the engine, rev the engine from idle and WOT and check for a spot where the volts dont change. if the volts wont change from 0 to 5 volts then its bad and need a replacement TPS it works like everyother sender, map, IAC, EGR and IAT or Mat sensor.
