SPUN a Rod Bearing!! Now What ??? - Page 2 - S-10 Forum
post #51 of 63 Old 01-16-2010, 02:12 PM
User is: Dirty White Boy is offline
Re: SPUN a Rod Bearing!! Now What ???
Originally Posted by LabRat116 View Post
How many Cubic inches would that yield ?
How much more HP we talking ?
We never got actual HP numbers, but judged a lil over 300 hp.
post #52 of 63 Old 01-16-2010, 02:20 PM
LMAO...this is what we used as a guidline.
http://www.hotrod.com/techarticles/e...ild/index.html
post #53 of 63 Old 01-16-2010, 02:29 PM
Braves FTMFW!
1sic03x's Avatar
User is: 1sic03x is offline
Send a message via MSN to 1sic03x
Originally Posted by The Blown Blazer View Post
Oh god LOL.
So you used pistons from a 305 with 3.736" bores on a 262 4.3 with 4.0" bores?
BET IT RAN AWESOME BRAH.
And I'm sure that bore-job and stock length rod swap really woke it up.
2006 TBSS - lots of go fast parts
2001 S10 4.3 M5 - Daily
2003 Xtreme LSx - Sold
1sic03x is offline
post #54 of 63 Old 01-17-2010, 12:16 AM
Bills Dad's Avatar
User is: Bills Dad is offline
I got a truck with a slight tap/knock/miss, when I tore it down I found this....
post #55 of 63 Old 01-17-2010, 10:50 AM
Bill Wheats's Avatar
User is: Bill Wheats is offline
The OP hasn't even checked his oil for any signs yet. So the vertic isn't in yet....
That pic is a big reason why not to add seafoam into your oil. Something got in between the beering and the race.
Some people are like slinkies - not really good for much.
But they bring a smile to your face when pushed down the stairs.
post #56 of 63 Old 01-17-2010, 06:17 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
What pic are you looking at? I see a melted piston.
Teamsters Local 1150
SH-60B is offline
post #57 of 63 Old 01-17-2010, 06:27 PM
minimum wagn' it to glory
DCsdime16's Avatar
User is: DCsdime16 is offline
a melted piston...or perhaps detonation?
post #58 of 63 Old 01-17-2010, 09:11 PM Thread Starter
GO STEELERS !!!
LabRat116's Avatar
User is: LabRat116 is offline
Unhappy Re: SPUN a Rod Bearing!! Now What ???
It may be awhile too. Luckily for me the truck is a back-up vehicle.
I don't have the funds (yet) to do needed repairs either at this time. Sucks when you still owe $2700 on something you can't even drive.
Can't really work on it either.... Don't have a garage here.
Tentative plans are to probably buy a remanufactured engine and have a local garage do the install. Mechanic will only charge $550 Labor.
Trying to decided where to buy an engine from.
When I do get the job done, I will have an Autopsy performed on the old engine and report the results.
post #59 of 63 Old 01-17-2010, 10:21 PM
Sorry, I was looking at the wrong pic Too much going on...
post #60 of 63 Old 01-18-2010, 06:02 AM Thread Starter
GO STEELERS !!!
LabRat116's Avatar
Question Re: SPUN a Rod Bearing!! Now What ???
What would cause the piston to desinigrate on the SIDE like that ?
Would detonition destroy a piston from the TOP ????
post #61 of 63 Old 01-18-2010, 12:38 PM
Basically, extreme heat and pressure. Alot of things can cause that.
post #62 of 63 Old 01-21-2010, 11:35 AM
I posted this in another thread but thought it might help others searching the threads....
If you think that you may have spun a beering: must read
Funny how some can hear a spun beering over the internet.
The first test is to test your oil:
Drain the oil and filter into a clean mortar pan. Then while the drain plug is still off pour in a quart or two of warm low weight ~5W30 motor oil to push the residue out of the pan. Then look for silvery stains on top of the old oil caused by the beerings. Using a funnel, magnet and a coffee filter. Place the filter into the funnel then the magnet. Pour the oil through the filter. It will grab all of the beering material if there is any.
Next; repace the oil and filter. Start the engine and track the noise down using a stethiscope if advalible.
Once you narrow it down to the closest cylinders:
Starting with the closest cylinder, pull the spark plug wire (ground it) and restart the engine. The noise should have drastically changed. If the knock didn't then repeat the test with the surrounding cylinders until you find the correct cylinder.
The reason for the knock to diminish is because by not firing that cylinder you have taken away the force causing the knock.
Using a helper to start and start the engine, this test should only take a couple of minutes.
Many use an old plug wire w/ the plug side cut off and stripped back and grounded to the engine (Aligator clips speer this up). Then w/ eng off pull the plug wire at the dizzy and install the grounded one. Start the engine till you hear or don't hear the knock, then kill the engine. If knock sounds the same, then go to the next cylinder plug wire and retest....
This test should only take ~15 minutes or so.
NOTE:
1.For ease of writing this please realize that more than one cylinder may have beering woes and the knock sound may only change as one of the affected cylinders plug wire is disconnected.
2. As for being able to accurately diagnois a spun beering over the internet, others may, but my hearing just isn't that good.
post #63 of 63 Old 01-21-2010, 10:09 PM
User is: fox_forma is offline
Curious but why do you need to ground the one wire out and connect to the dizzy and put it in place of the cylinder wire you are pulling off?
