Smoke at start up 93 S10 4.3 - S-10 Forum
post #1 of 13 Old 02-17-2005, 05:18 PM Thread Starter
newell1967's Avatar
User is: newell1967 is offline
I've been noticeing a little smoke at start up. I only have 72000 original miles. valve job already? I noticed this after a recent oil change. If a valve job is needed would I be better off finding the problem valve and repairing it or get them all done or just go with some new heads all together.
post #2 of 13 Old 02-17-2005, 05:22 PM
the youngest has been
tippmann243's Avatar
User is: tippmann243 is offline
Re: Smoke at start up 93 S10 4.3
all 4.3's do it nad yeah you say it has 72xxx oroginal miles but its 12 years old also
common problem w/ a 4.3 i wouldnt worry about it
-mark
89 s10 blazer 5.7 vortec/t56 0411 pcm powered
03 zr2 s10 with some mods
post #3 of 13 Old 02-17-2005, 06:51 PM
User is: bg's is offline
If it's a TBI or even the CPI back in 89/90 to 93 I believe GM installed the wrong valve seals. They were
the o-ring type. GM put aTSB out and I think a quiet recall out telling the dealers to change over
to the GM "umbrella" style valve seals. Mine started when I had about 65000 on it and it still does
it. once in a while. I never changed them out. I use Valvolines high mileage oil now and it doesn't
hardly do it at all anymore and I have 108, + on the speedo now..A GM screw up back in the late
80's to early 90's deal..
bg's is offline
post #4 of 13 Old 02-17-2005, 07:04 PM
guy
User is: guy is offline
yeah sounds like valve seals if its only on start up. and easy fix if you got some compressed air. i think gm changed to teflon seals in 93 to solve this problem
guy is offline
post #5 of 13 Old 02-17-2005, 07:33 PM
i just put o bottle of stop smoke in when i change my oil works like a dream
-mark
post #6 of 13 Old 02-17-2005, 07:50 PM
Unregistered User
j894's Avatar
User is: j894 is offline
Mine used to do that a little bit, once in a while. after running Vavloline max life since I got it, it
doesnt seem to do it anymore//
'01 Blazer, 5sp, 4x4
Retired: 1993 Chevy S-10 Blazer - 4x4,4.3L,CPI, auto
-Cardomain-
j894 is offline
post #7 of 13 Old 02-18-2005, 02:18 AM
Pushrod for life!
pare_john's Avatar
User is: pare_john is offline
Send a message via AIM to pare_john Send a message via MSN to pare_john
Not necissarly bad valave seals. could be a bad ring. How much oil does the engine burn between oil changes?
1992 Chevy S10, 3.1L V6 5 speed. Bored .40 over, 272 crane cam, heads ported,polished,plained. Decked block. Port matched intake.
Valve job. High compression pistons. Roller rockers. AFPR. Compression 9.5/1. 3.43 rearend. 2/2 drop. Taurus E-Fan
www.s-series.org
post #8 of 13 Old 02-18-2005, 10:56 AM Thread Starter
newell1967's Avatar
Hardly any. Whenever i've checked the oil it was always right on or a little below so i'd say possibly a half quart. Do you guys use the recommended 5w40? or somthing different. I've noticed some seepage from the oil adapter underneath where it goes into the block. Is that an easy fix?
post #9 of 13 Old 02-19-2005, 02:10 AM
User is: YELLOWMAN is offline
your problem is the valve seal i just did mines
post #10 of 13 Old 02-19-2005, 03:32 AM
Pushrod for life!
pare_john's Avatar
i don't understand people. how can you say this when you haven't done any diagnosis on the vehicule
first what you should do is a compression test. if you see a cylinder with compression out of spec then do a leak down test. put a few drops of oil in that cylinder(through the sparkplug hole) then do the compression test again. if the compression raises then you know you have a bad ring. If that test shows the rings are good then it is most likely your valve seals
www.s-series.org
post #11 of 13 Old 02-19-2005, 09:29 AM
your are rigth about perfroming a compression test cylinder leak down he has 72,000 miles on the truck i don't think he needs rings the valve seal become brittle causing oil to leak pass the valve . my truck has over 150,000 miles and it original internal parts
post #12 of 13 Old 02-19-2005, 09:40 AM
04Xtreme's Avatar
User is: 04Xtreme is offline
Send a message via AIM to 04Xtreme
smoking only at start-up is 99% of the time bad valve seals , rings are generally all the time, often not noticable cruising
ASE Certified Master Technician
2004 Blazer Xtreme, Indigo Blue
2000 Silverado 2500 6.0 4L80E 2wd
1989 Camaro IROC-Z SOLD
Originally Posted by Jay Leno
It looks good but then so does putting socks down your pants: fine until you have to perform
04Xtreme is offline
post #13 of 13 Old 02-19-2005, 02:34 PM
Doing the diag is the correct way to do it. In the meantime, I'll try and find the TSB. I made a few copies
of it off a Snap-On- Mitchell On Demand diag dics we had installed on a smog machine we had at
the shop here in SoCal..It address's this problem with the late 80 early 90's 4.3 engines when they
start the "smoke at start up" and then goes away. It points to the o-ring valve seal replacement to the
"corvette umbrella " style seal.
bg's is offline
