Service Engine Soon Blinking : Missfire? - S-10 Forum
post #1 of 15 Old 03-27-2009, 05:26 PM Thread Starter
Lifted without a clue
Svenson14's Avatar
User is: Svenson14 is offline
Ok I've got a 95, so I know my computer is OBD II.
I've checked with some local repair shops, they want to charge a minimum just to tell me what the code is if they hook me up to their computer.
My engine light blinks for a period of time ONLY when i give it gas while going up a grade (trying to keep up to speed or accelerate up a hill).
I dont hear anything, I dont see or know of any other symptoms.
Is it most likely a spark plug? what should I check?
95 S-10 Blazer http://www.cardomain.com/ride/685810
*SOLD*
6" superlift F.I.T, 32x11.5"BGF MT on Procomp 15x8
post #2 of 15 Old 03-27-2009, 05:43 PM
THE Registered User
Renegade_Z's Avatar
User is: Renegade_Z is offline
Re: Service Engine Soon Blinking : Missfire?
When mine did that it only did it at 65-70 miles an hour. It was misfiring. It needed a crank relearn. But thats just mine.
'03 S10 step-side regular cab: 4.3 w/ 4L60E, 266AHR cam, worked heads w/ 1.52 roller rockers, W4M Performance/Blackbear Performance tuned computator, dumped Flowmaster 40-series, March underdrive pulleys, Lakewood traction bars, Marine intake manifold, K&N CAI, MSD coil, MSD 6AL box, Black Soft 8's with Radial T/A's. Sold
post #3 of 15 Old 03-28-2009, 12:22 PM Thread Starter
Svenson14's Avatar
ok so in that case you still had to take it to the shop?
*SOLD*
post #4 of 15 Old 03-28-2009, 12:32 PM
xtreme2299's Avatar
User is: xtreme2299 is offline
When mine did that it showed bank 1 too rich. Which could have been a number of things. It was time for a tune up so i went ahead and had that done and it hasn't done it since. Mine would flash like yours, going up hill and the engine would down shift.
01 xtreme...4.3L X-cab...Mostly stock except for the K&N filter, magnaflow convertor with single in dual out flomaster 40 series muffler. I've got 4 mtx 12's and a kicker zr360 amp. Nothing fancy, but hoping to drop in a 5.7 soon!
post #5 of 15 Old 03-28-2009, 02:02 PM
THE Registered User
Renegade_Z's Avatar
In my case I took it to the dealership, only because my grandma (who technically owns it) pulled rank on me and told me too. If it needs a crank relearn, not saying it does as stated above, yes you would need to take it to a shop or to someone who has a big expensive scan tool, like a Snap-On Modis or Solus or a GM scan tool. There are some others out there too. But that was just my case. Like stated before, it could be a whole boat load of other stuff.
post #6 of 15 Old 03-28-2009, 05:56 PM
Oh shit....
CommanderKidUT's Avatar
User is: CommanderKidUT is offline
Send a message via AIM to CommanderKidUT Send a message via Yahoo to CommanderKidUT
Check your TPS, its a cheap fix and that was my problem when mine was doing what yours was. It was not throwing a code for the TPS, though and my scan tool was telling me misfires in 1 and 3.
I are returned.......
post #7 of 15 Old 03-28-2009, 06:18 PM
Sgt. Stv-LoNowitz
stv-lo's Avatar
User is: stv-lo is offline
Send a message via AIM to stv-lo
a flashing ses light indicates a catalyst damaging misfire... so you're gonna need to ri[p that bitch out n throw a sbc in
Stephen
stv-lo is offline
post #8 of 15 Old 03-28-2009, 10:27 PM
THE Registered User
Renegade_Z's Avatar
post #9 of 15 Old 05-21-2009, 11:25 AM Thread Starter
Svenson14's Avatar
so i called up autozone, and they said apparently in california, it is illegal to give someone just a reading off of the OBDII reader, free or not.
*SOLD*
post #10 of 15 Old 05-21-2009, 05:17 PM
THE Registered User
Renegade_Z's Avatar
I dont know anything about California law, but smells like BS to me.
post #11 of 15 Old 05-21-2009, 05:25 PM
992drjimmy's Avatar
User is: 992drjimmy is offline
If the have the reader to use, Have them go to the car with you and you do the reading. A flashing SES light indicates a SEVERE mis-fire. Could be a plug wire popped off the distributor, That did happen on my 96 last week.
Or just buy your own reader. Handyto have and ive seen some now as low as 40 bucks.
*97 GMC JIMMY 4x4 on AR wheels with 275/60/15(SOLD)
*02 GMC Sonoma Highrider(ZR2) with 3" body lift on 15x8 ion wheels, 5.5" backspaced with 33x12.50 kumho road venture MTs
*98 MUSTANG GT Not at all Stock.
*01 Monte Carlo SS fully loaded
post #12 of 15 Old 05-22-2009, 06:54 PM Thread Starter
Svenson14's Avatar
really? where at? Local autozone wants 60 bucks for it., and secondly will the reader tell me enough to hopefully fix the problem?
*SOLD*
post #13 of 15 Old 05-22-2009, 07:51 PM Thread Starter
Svenson14's Avatar
another issue:
Ive been looking into it a little more, just in case I were to decide to buy a reader, BUT every reader out there seems to be for 1996 and up.
looking into that, i found a site or two that says you have to switch some pins to make the reader think you are '96, while others said you have to get "special software".
apparently Im the bastard year of '95 that is a hybred between '94 and '96, with and OBDII reader that isnt compattible with OBDII.
Is this true, and what do I do?
*SOLD*
post #14 of 15 Old 05-22-2009, 08:31 PM
992drjimmy's Avatar
The auto zones in CA dont have the loan tool? I have a basic actron reader. I have always been able to figure out evry problem using it. You may have to do some research, A reader is a mechanic in a box. Not try to be smart guy but you will have to work with it.
post #15 of 15 Old 05-22-2009, 09:19 PM
THE Registered User
Renegade_Z's Avatar
They really dont have a loaner? Most places do.
