Seafoam effect on O2 sensor and Cat Converter? - S-10 Forum
post #1 of 16 Old 05-29-2007, 04:43 PM Thread Starter
tommyncal
tommyncal's Avatar
User is: tommyncal is offline
I've looked thru many threads and it seems 'seafoam' is liked by many. But, I have not seen any talk or questions about it's effect on the O2 sensor or Cat Converter. Does anyone have any knowledge whether seafoam adversly effects either of these two. Thanks
'90 Blazer S-10 4 x 4...4.3l
soon to be running!
post #2 of 16 Old 05-29-2007, 06:26 PM
Starting from scratch...
02_Black_XBlazer's Avatar
User is: 02_Black_XBlazer is offline
Re: Seafoam effect on O2 sensor and Cat Converter?
You'll be fine. I've used it on every vehicle in my family with cats and 02s, and never had any check engine lights or issues with running the seafoam.
Pipefitter's Local 597, Chicago, IL
'97 S-10 SS (gone) ( pics- http://www.s10forum.com/forum/f3/a-l...ing-up-367228/ )
'02 Blazer Xtreme
post #3 of 16 Old 05-29-2007, 07:27 PM Thread Starter
tommyncal
tommyncal's Avatar
thanks for the reply, I've read where it fouls spark plugs, but was wondering about other issues. Didn't want to replace other parts because of seafoam. thanks again
soon to be running!
post #4 of 16 Old 05-29-2007, 11:54 PM
Don't look at my car
travy's Avatar
User is: travy is offline
Just make sure to do a run just having cleaning it. get all the stuff out of the system.
I remember from a thread awhile ago and some one saying "go for a spirited drive" lol
I love snoboarding and blondes.
travy is offline
post #5 of 16 Old 05-30-2007, 07:47 PM
mxm
User is: mxm is offline
is it recommended to get an oil change soon after? i think i remember someone saying that somewhere.....just a question. i want to seafoam mine but i just did an oil change 2 weeks ago( i got it the truck 3 weeks ago) and if i need to oil change after seafoam, then i'll wait a few weeks....
mxm is offline
post #6 of 16 Old 05-30-2007, 09:54 PM
Good Bye SonomaST
91sonomast's Avatar
User is: 91sonomast is offline
Send a message via Yahoo to 91sonomast
GM has top engine cleaner which is the same thing as Sea-Foam and does the same thing. The instructions on the back of the GM can says: "get engine to operating temperature, introduce Top Engine Cleaner through a vaccum source(i personally prefer PCV line or brake booster line), introduce approximately 2/3's can into engine. Once smoking occurs shut engine off and let sit 45-60 minutes(the stuff boils on top of the pistons, valves, anything it gets on and removes the carbon), after sitting start engine and pour the remains of can into TB ports(this loosens up what small amount may have dried up) then replace TB cover and run engine at 1500-2500RPM's until smoke clears(and buddy there WILL BE smoke, lots of it!!! and could take upto 5 minutes to clear out). Thats the instructions on the can, then i take it on a spirited drive. From what i understand per GM, if u dont hold it at 1500RPM or higher it doesnt blow the carbon out good, i always hold it 2000RPM's, even in my own vehicle until the smoke clears, all the smoke is pretty sweet, but stinks like hell, make sure ur cab is upwind from the tailpipe cause if not ur gonna smoke urself out
EDIT: if GM suggests it on Cadillac's still under warranty there arent to many adverse effects.
1998 Dodge Dakota, 2wd ECSB, 318, M1 2bbl intake, 52mm TB, Taurus fan, Ford injectors, MP PCM, MPP mid-length headers and full exhaust, Hooker Aerochamber, DJM 3/5 drop. Put back to stock and sold
2001 Grand Cherokee 4.0L, it's so SLOW!!!
1991 SonomaST, WAS SOLD, reacquired and rusting away.
Originally Posted by 99 BUCKET View Post
I will get off at some point.
post #7 of 16 Old 05-30-2007, 10:40 PM Thread Starter
tommyncal
tommyncal's Avatar
thanks for the great directions. Sounds like I better take it out of my neighborhood! I'm drawing a blank on ' TB ports". Please explain what they are, thanks.
soon to be running!
post #8 of 16 Old 05-30-2007, 10:48 PM
I would guess a "TB port" is would be any connection to the throttle body drawing vacuum, assuming it's large enough to introduce liquid through.
'02 Blazer Xtreme
post #9 of 16 Old 05-31-2007, 05:18 PM
crewcabguy's Avatar
User is: crewcabguy is offline
what is the name of the GM cleaner and can it only be gotten at GM dealer?
post #10 of 16 Old 05-31-2007, 06:38 PM
Registered Fabricator
cdog24's Avatar
User is: cdog24 is offline
Send a message via AIM to cdog24
It says right on the bottle "Top End Cleaner". yes, a GM product from the dealer only. It's a lot thicker than sea foam. You can foul out plugs by doing this, but I have not seen it happen often. Both liquids losen up carbon deposits in the intake. These carbon deposits can get caught in the plugs. Like I said though, VERY unlikely.
It wont harm the 02 sensor or CAT
Some ppl might think you should change your oil after you do this b/c it could wash down your cylinder walls and get into the oil. But you would have to dump a shit load in your motor very fast to do this. Just make sure you keep your engine running. dont pour it in so fast that it kills it. Not that it will harm it, just not a good idea. Although the GM Top Engine Cleaner instructs you to do this at the end (I think). But like I said, it is a much thicker liquid and is less likely to wash down your cylinder walls past the piston rings.
Don't use this stuff all the time either, overkill is not nessesary or benificial
///RA Illinois Chapter
cdog24 is offline
post #11 of 16 Old 05-31-2007, 08:46 PM
goin broke but n style
S15vortecpwr's Avatar
It stated right on both cans (the GM and Seafoam) that it will not hurt O2's or cats.
I ran mine thru the vacuum line that runs to my vacuum ball on the hood. It worked great. You wil have to idle it up to about 1500 or it will stall.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #12 of 16 Old 06-01-2007, 02:04 PM
crewcabguy's Avatar
I read somewhere that this should'nt be used on engines with 150000 or more miles on them, whats your guys thoughts on this?
post #13 of 16 Old 06-01-2007, 05:58 PM
I didn't build it for you
Dogsofjune's Avatar
User is: Dogsofjune is offline
364,000 miles on my Toyota, no problems beyond normal wear and tear issues. At least with the Seafoam. Dunno about the GM stuff.
Doesn't play well with the ignorant.
New project
My 2003 Turbo 4.3l SyTy wannabe Build
post #14 of 16 Old 06-01-2007, 07:11 PM
Good Bye SonomaST
91sonomast's Avatar
when u take ur air cleaner off, the 2 Throttle Body holes, pour a semi equal amount down each hole (after start up to blow it out)
yeah the GM stuff is thicker and i think does a better job because it is thicker so it sticks longer and yes i have heard the few tales of it fouling plugs, but it usually only does that if u do per directions and stall out the motor with it and its been a while since u have had plugs and wires.
as far as 150,000 miles, never heard that, my truck has 33x,xxx miles and i did it to it and it runs better than it has in the 6 years i have owned it.
o yeah, idk about the sea-foam, but GM only suggests using Top Engine Cleaner every 3 years or 30,000-35,000 miles
one more thing, GM Top Engine Cleaner USED to make Toyota's Top Engine Cleaner, or upper cylinder cleaner or something like that jazz, same can and everything just had Toyota on it
post #15 of 16 Old 06-07-2007, 09:50 PM
NOT DONE TO MANY PROBLEMS
blazin24's Avatar
User is: blazin24 is offline
if i were to put the seafoam thru the vaccum line and put it in the oil would it make my truck leak oil or other substances ? It has 184000 miles on it and i really don't want to start an oil leak but i know there is probably a lot of build up in both the oil and upper part of the engine that should be cleaned out. thanks
'91 2.8, 5 speed
Shaved doors, 2/2 drop
http://www.cardomain.com/ride/2518778
blazin24 is offline
post #16 of 16 Old 06-07-2007, 11:20 PM
96 s10 4.3
User is: fuzz is offline
it could foul plugs if you pour it into the vacuum hose , but not if you put it in the gas tank
fuzz is offline
