LinkBack (5) | Thread Tools |
#101 |
Registered (Ab) User
Location: League City, TX (Houston) User is: OffLine ![]() |
Re: SCPI to MFI upgrade kit...
Don't forget air and fuel filters too!
#102 |
I'm slap happy, bitches!
they make one for v-8's yet?
#103 |
Got Fuel Rails?
#104 |
cool, i wonder if these things are easier to control with FAST.
if they are, i might put the FI back on the vortech. |
#105 |
#106 |
#107 |
#108 |
Registered Leadfoot
Kinda off topic but is there an upgraded spider for the CPI motor? 92' thru 95'?
#109 |
Starting from scratch...
#110 |
#111 |
#112 |
Has anyone with the MFI attempted to swap to larger fuel injectors?
#113 |
Got Fuel Rails?
#114 |
Or is there something proprietary about these fuel injectors? |
#115 |
Got Fuel Rails?
#116 |
![]() Are the Multec 2 *connectors* at least standard connectors? Meaning, can I get some Multec 2 to EV1 adapters if I wanted to use the assembly to connect the truck's harness to my own intake and some EV1 injectors? (As opposed to splicing wires.) |
#117 |
Got Fuel Rails?
Just splice the wires, it takes about an hour. You can't do what you are saying because you would throw away the stock fuel metering body anyhow, so you are left with the massive 12 wire plug that goes to the stock fuel metering body.
#118 |
I'm swapping on a marine MPFI intake w/ MotoTron injectors. My goal is a way to connect the factory fuel inj plug to the new injectors w/o cutting. I came across this new MPFI assembly and was curious if it was a solution for larger injectors w/o all of the intake swap work, but apparently not. So now I'm just curious if I could use it as a way to connect my factory harness to my EV1s. (Or EV6s if I stick with the marine MPFI injectors for now...) |
#119 |
Does the MFI assembly use "standard" Multec 2 connectors?
E.g. Can I get Multec 2 to EV1 adapters and they should work? |
#120 |
Got Fuel Rails?
It doesn't matter what type of connectors the new injectors use. You still use the same big plug with all 12 injector wires on 1 to plug into the new injector harness. You will need to cut that off, and splice your 12 wires. If you leave a little bit when you cut it off you can always put it back on.
Stock the fuel metering body and where the harness plugs in is the same. You are getting rid of the fuel metering body, and therefore need to cut the part that plugs into the fuel metering body off and replace it with individual injector plugs. Look at the pics on the first page of this thread... It isn't that hard, how do you expect to swap manifolds, recalibrate the computer, move all of the emissions stuff around, and you are worried about cutting into your harness? |
#121 |
move emissions components or re-tune the PCM. I will use the new MFI assembly in order to plug into the factory wiring harness and have 12 wires that I can easily splice into -- or use Multec 2 connectors that already exist w/ adapters to easily plug into my EV1 injectors w/o doing any splicing at all. Word is the injectors are not standard Multec 2, so that's why I'm curious if the connector is actually a standard one or something proprietary, too? |
#122 |
Are there any difference in fuel pressure requirements for this system?
#123 |
#124 |
#125 |
Daily Driver
sorry that i havent been around guy!!!
update the truck still runs great, got 24.4 mpg when i went down to Fresno on my trip and that was 90% freeway and some town drive (only 13 gals) but i still think are gas tanks are bigger but the gas gauge is empty at 12 to 13 gals as far as the problem im have when its really hot out i still have and im going to order a new cat. off eBay and see what happens its the only thing i haven't replaced DON'T get me wrong this swap got my gas mileage back and the truck runs better (now that my tires are shot.... ill leave that for another trend) the mfi kit helped 90% of my problems!! Last edited by sparky2613 : 08-27-2008 at 01:17 AM. |
#126 |
You can find the exact capacity of your gas tank in the option codes on the glove box door. Look for Nxx and go to the RPO Decoder sticky. Mine was NE2 - 18 gal. |
#127 |
If I only went by using the guage from full to empty I would have a 12 gallon tank. The sending unit HAS to be off a good amount on my truck. I was just over a quarter tank tonight and it took 8 gallons to fill up.
#128 |
The tank size is programmable in the PCM. Maybe yours is off by a bunch.
#129 |
Sorry if I missed this somewhere but does this kit come with a new regulator and regulator bracket?
#130 |
#131 |
Daily Driver
comment #64 i put pic of the bracket
#132 |
just wondering how long did it take you guys to recieve yours through the mail i ordered mine more than 2 weeks ago and the website says that its on order but when i call the # they just tell me to email them wtf.. i dont understand why they even have a number if its just a stupid voicemail but yet they are already payed for it is there alot of people that have this unit on order right now or something i would like to get my truck put back together hell if its going to be a while i want my money back so i can buy the junky a** popet valves i didnt have a prob. untill i went to replace the intake gaskets anyways thanks guys
#133 |
Daily Driver
Posts: 128 |
