rusted exhaust manifold bolts... what can i do - S-10 Forum
post #1 of 18 Old 06-07-2008, 12:42 PM Thread Starter
User is: davidbjordan is offline
i am doing a head job on my 96 s-10 (4.3l) and cannot get to the outside head bolts because of the exhaust manifolds... the bolts are so rusted the nut is a round shape.
i thought i could cut it but can't get my grinder in there to get a clean swipe.
Is there anything i can use or do to get these manifolds off???
post #2 of 18 Old 06-07-2008, 01:28 PM
User is: Project89 is offline
Re: rusted exhaust manifold bolts... what can i do
Go to sears and the get the BOLT OUT kit , runs bout $20 or so . But it works better than anything , even on round headed bolts . You will use it over and over again
post #3 of 18 Old 06-07-2008, 04:05 PM
Will work for turbo parts
User is: King_Ice_Flash2 is offline
Send a message via AIM to King_Ice_Flash2 Send a message via MSN to King_Ice_Flash2 Send a message via Yahoo to King_Ice_Flash2
Cut them off, like with a sawzall then when the manifold slides off, you have plenty to grab onto with a vice grips.
2003 S10 Long Bed 4.3L ZQ8 + 2/3 drop, Caltracs, rear disk conversion, 7" dual diaphragm booster, 255/50/R16 Falken ZE-512, MPFI converted 2114, 48LB Racetronix injectors, eBay RS BOV, Accel 60115 distributor, Aeromotive FPR, Corbeau Forza seats, Mach headers, 2.5" front mount intercooler, Innovative turbo, Precision Industries Vigilante 3,000 RPM torque converter, EFILive COS3 tune.
post #4 of 18 Old 06-07-2008, 05:41 PM
Registered (Ab) User
Yogi's Avatar
User is: Yogi is offline
A small Dremel with a 1.25" cut off wheel will get into some pretty tight spaces. I was surprised at how fast that sucker would cut a bolt head off!
2008 Saturn Sky Red Line Roadster
2.0L LNF Turbocharged Motor
5 Speed Manual Trans.
Custom made Blazer CAI (Click Here)
Yogi is offline
post #5 of 18 Old 06-08-2008, 01:09 PM
Make sure you get the fiberglass cutoff dremel wheels. The stone ones wear out too quick.
post #6 of 18 Old 06-10-2008, 01:42 PM Thread Starter
I'm going to give the multi-tool a try... i never had much luck with it... seen it as more of a hobby tool
i'll let you guys know
post #7 of 18 Old 06-10-2008, 01:43 PM Thread Starter
Also i forgot to mention that it was the bottom side of the manifold where it attaches to the "y" pipe that i have to cut off
post #8 of 18 Old 06-10-2008, 01:55 PM
Bill Wheats's Avatar
User is: Bill Wheats is offline
You know, it only takes about ~an hour or so to take the fender and fender well off. Then you can just drill the cap off and it makes it a lot easier installing the head.
Just a thought!
post #9 of 18 Old 06-15-2008, 01:46 PM Thread Starter
With the inner fenders off i still can't get a good angle at the bolts with my grinder...
i'm down to two options from what i can see...
cut the pipe right below the oxygen sensor, that way i can have a straight pipe and hopefully pull it out the front... then reconnect when everything is ok... (will I have room to pull the manifold out forward? and how close can i get to the oxygen sensor without fowling it?)
or ...
give up haha...
let me know if there are any other ideas...
post #10 of 18 Old 06-15-2008, 04:25 PM
Tellin you that the bolt out kit will work the best , it works with a ratchet and will work wonders no matter how rounded the head is , I have used it on many exhaust systems
post #11 of 18 Old 06-15-2008, 04:26 PM
ALso if you just cut them off then you have the same problem trying to get the rest of the bolt out
post #12 of 18 Old 06-15-2008, 04:34 PM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
User is: 1fast4by is offline
Send a message via AIM to 1fast4by
x2!!!
Those things are indispensable in my toolbox
"The police cannot protect the citizen at this stage of our development, and they cannot even protect themselves in many cases. It is up to the private citizen to protect himself and his family, this is not only acceptable, but mandatory."
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #13 of 18 Old 06-15-2008, 07:13 PM
User is: bg's is offline
Can you post a picture so we can get a better idea of
what you're facing ? Maybe then we can come up with
a game plan.
bg's is offline
post #14 of 18 Old 06-15-2008, 10:00 PM
Works too much!
laydout97's Avatar
User is: laydout97 is offline
you could use a torch to heat up the nut, then use the bolt out thing the other guy was talking about to get them out. you could use one of those benzene torches if you dont have access to an oxy/cetelene torch.
92 4.3/700r4 315k- ole red
2011 altima- daily ride
post #15 of 18 Old 06-15-2008, 10:25 PM
If you have the fender off check to see if you can drill the head of the bolt off. We usually start with a small bit to drill a pilot hole then a bigger bit..
Try not to go any deeper than you have too.
After you pull the head, the machine shop will be able to pull and replace the bolt.
Pain in the ass.
Good luck.
post #16 of 18 Old 06-15-2008, 10:30 PM
I'm slap happy, bitches!
User is: Deeze49686 is offline
you talking about the 3 bolt downpipe flange? BLEH, cut them off behind the flange, youll have 1/2 inch or more to get them out when you have the manifolds off.
post #17 of 18 Old 06-16-2008, 01:21 AM
WHOO WHOOOO
Slamd_S_Dyme's Avatar
User is: Slamd_S_Dyme is offline
Send a message via AIM to Slamd_S_Dyme Send a message via Yahoo to Slamd_S_Dyme
+1 on the bolt out kit, those things work magic on stripped bolt heads and even studs. I picked up one a few months back and god knows how many times its helped me out. I'd pick up a kit and heat the area and try and back it off, it will more then likely come right out.
post #18 of 18 Old 06-16-2008, 06:31 AM
One more thing , instead of heat , go get a can of PB BLASTER , spray it on there and let it sit a few minutes , then use bolt out .
I have used the PB BLASTER many times on bolts that where rusted in there and man it eats that crap away and loosens the bolt right up . Can get it at Advance , auto zone , walmart , dollar store bout anywhere
