ruff idle
Old 08-24-2008, 06:05 PM   #1
thecody
thecodyd21's Avatar
thecodyd21 is on a distinguished road
ruff idle
ive got an idea but maybe somebody could help me out on this one...took my truck to tha dealership for engine issues and it ended up being that i needed a new maf sensor and a new cat..so im like ok ill just throw performnace parts on it...k&n cold air,jet MAF sensor and a high flow cat with a magnaflow single in dual out muff.installed all these parts and it runs like shit on idle for about 30 sec and then clears up and runs like a raped ape..so i call jet and they tell me that the k&n is puttin oil on my sensor so i clean most the oil from the filter and intake and clean the sensor and with the correct cleaner and it does nothing> ? anybody have some input?thanks
Old 08-24-2008, 06:55 PM   #2
Bill Wheats's Avatar
Bill Wheats is on a distinguished road
Re: ruff idle
What year is it?
The IAC may just need to be reset.
Old 08-24-2008, 07:08 PM   #3
thecody
thecodyd21's Avatar
Re: ruff idle
its a 99 xtreme..ive un hooked the battery a couple times and i have a data recorder and it shows bank 1,2 are too rich but i think that is just is the ruff idle stage?
Old 08-24-2008, 09:33 PM   #4
thecody
thecodyd21's Avatar
Re: ruff idle
ok the codes are PO171,P0174 what would cause that?MAF Sensor?
Old 08-24-2008, 09:46 PM   #5
Registered (Ab) User
Yogi's Avatar
Yogi is on a distinguished road
Re: ruff idle
Those codes show that you are running too lean, not too rich.
Try cleaning your MAF. The K&N may have put some oil on it. Click here for more info.
Old 08-24-2008, 10:07 PM   #6
thecody
thecodyd21's Avatar
Re: ruff idle
could this damage the new cat?
Old 08-24-2008, 10:23 PM   #7
Yogi's Avatar
Re: ruff idle
Not likely.
Old 08-24-2008, 11:31 PM   #8
goin broke but n style
S15vortecpwr's Avatar
S15vortecpwr is on a distinguished road
Re: ruff idle
IMO JEt makes nothing but junk. If you bought a BIGGER one than that is more than likely your problem. The fact MAF can handle 500plus hp
Old 08-25-2008, 08:49 AM   #9
thecody
thecodyd21's Avatar
Re: ruff idle
so u think i should go back stock?what other bolts on would help me with performance? i see alot of people are going with the msd but i see its burning up rotors and caps? opinions?
Old 08-25-2008, 12:27 PM   #10
Yogi's Avatar
Re: ruff idle
The stock MAF is entirely adequate.
You will be replacing cap & rotor every 15-20,000 Mi. with the MSD.
Best bang for the buck mod is a custom PCM tune.
Page generated in 0.09975 seconds with 11 queries
