Repair your leaking oil cooler lines!
Old 02-14-2009, 07:07 PM   #101
Huge Ideas, Tiny Wallet
sockjock's Avatar
Re: Repair your leaking oil cooler lines!
not enough room for the filter to be located under the block on an IFS 4x4 unless you have one of the 5 or 6 inch suspension lifts installed.
Old 02-14-2009, 07:09 PM   #102
forum idiot
orangesonoma's Avatar
Quote: Originally Posted by 97ls1s10
best thing is to take it off and never worry about it again. and best part is you dont have to buy anything
yeah you do.. you have to buy a 6 dollar fitting that no dealer seams to have
Old 02-15-2009, 10:09 AM   #103
I have the disease
blazerlow's Avatar
I concur.
Old 02-25-2009, 05:01 PM   #104
I just did this repair , 2 hours , $15 later , this repair is a No Brainer , if you want to save some cash .
Very easy to do.
If not , buy new lines, its up to you .
It's too bad that Hotwire is Banned from here , The Guy has alot off info to Share.
There are alot of Hotwire Mods to Both of my trucks.
Thanks Jeff !!!!!!!
Bob
Old 03-13-2009, 01:13 AM   #105
orangesonoma do you know the part number i have a lift kit and want the fipping cooler gone
Old 03-13-2009, 01:41 AM   #106
sockjock's Avatar
I did this mod to my 95 Blazer. I bought 10 ft of trans. line and I have enough left over to do my wife's Blazer now.
I'm extremely pleased with the outcome and I saved a wad of cash. And if the lines ever develope a leak in the future it's even simpler to repair. Just loosen a couple hose clamps and slip on some new hose, tighten hose clamps and you're done.
I would definitely recommend this to anyone needing to replace leaking oil lines.
Old 03-13-2009, 01:52 AM   #107
I found a part number; GM# 14081300
http://www.roddingroundtable.com/for...ad.php?id=7428
Old 03-13-2009, 02:17 AM   #108
Aquatic Goat Farmer
uhlhazard's Avatar
sockjoch, hotwire specifically states not to use tranny lines. I did however for a while with no issues but they start to feel soft/springy. Use the heavy duty oil line.
Old 03-13-2009, 10:29 AM   #109
sockjock's Avatar
NAPA didn't have any of the heavy duty oil line at the time. Were you using the red 250psi rated trans line? If mine start getting soft I'll get the HD oil line. At least it'll be an easy swap.
Old 03-13-2009, 10:46 AM   #110
JayPerpich's Avatar
just a question... How much line was used? and was it 1/2 inside diametre? aren't the old lines 3/8?
Old 03-13-2009, 12:43 PM   #111
sockjock's Avatar
I used approximately 4 to 4 1/2 feet of line and yes it was 1/2 inch. It was very tight going on.
Old 03-13-2009, 01:53 PM   #112
Aquatic Goat Farmer
uhlhazard's Avatar
My line was "multi purpose" but is extreemly hard right now and my odo reads 183ish. Yes you are right when your order of good line rolls up, you can swap it in for the soft tranny line.
I wonder what kind of real pressures that line sees because my oil pressure gauge with 5/30 puts it in the area of 70psi on the gauge but perhaps the lines come before/after a different pressure area?
Anyhow mine are rated 250psi of OIL pressure and that is the key. I also noted that the original lines were stronger than the hand of god. It is amazing how they put aluminum crimps on steel braided nylon reinforced hoses. If only they went stainless this would never even become a problem imo.
Old 03-13-2009, 05:18 PM   #113
sockjock's Avatar
My old lines were very soft and much more flexible than the trans line I used.
Seeing as so many people have problems from the factory crimped lines you would think that GM would have come up with a better line or just attached them with hose clamps to start with, so they could easily be replaced at a lower cost.
Old 03-15-2009, 05:01 PM   #114
ZQ8 Blazer
ZQ8 Blazer's Avatar
This what I need?
http://www.oreillyauto.com/EW3/ProductDetail.do?id=520657437&line=HDN&itemNumber= 112&categoryIndex=0&didSearchFor=Oil+Cooler+Line&v ehicle=1998CHEVROLETBLAZER%20(S10%20SERIES)V6-262%20%204.3L&bid=1237150204006&cycleCount=2271&cu rrentPage=0
Old 03-15-2009, 06:43 PM   #115
sockjock's Avatar
That'll work
Old 03-15-2009, 07:24 PM   #116
ZQ8 Blazer
ZQ8 Blazer's Avatar
ok thanks.
Old 03-25-2009, 11:25 AM   #117
arch77's Avatar
i know i am a little late to the party on this one, but this does work.
i have put on about 4000 miles with the lines this way and it works just fine.
easy enough to do as well. the whole thing cost me 16 bucks verses the 170 quoted at the part stores.
the kicker is when i talked to them about the leaking issue the reply was, "yeah but there under lifetime warranty, just bring'em back. its common for them to leak a little after time."
glad to say no leaks with the homemade method, would recommend to anyone.
thanks for the great tip.
Old 03-26-2009, 09:07 PM   #118
Not so Avg
tiresmokinV8's Avatar
Just did mine today. Very easy to do.
Old 03-29-2009, 12:39 AM   #119
Very nice sticky....
I have the same problem with my '99 dime. $70 for these stupid lines? MEH!
Also...
The A/C compressor
the fuel gauge
the front suspension
the intake gasket (fixed)
the tailgate straps on my '94 fullsize (sure the ones on my dime will go soon)
the cat
the door pins and bushings (fixed on driver's door)
Yeah, glad those engineers get paid so much...wanna bring costs down?
Fire some of those morons.
I'll be doing this repair soon and, as I'm not a COMPLETE moron and I can follow simple instructions, I think it will be a very sound repair.
Thanks hotwire...
~archi
Old 05-01-2009, 01:05 AM   #120
S10Northwest's Avatar
I just replaced my oil cooler lines on my 2000 Sonoma 2Wd today with the Dorman lines what a pain in the ass Dormans QC is the shits as the forward bolt bracket was put on ass backwards had to yard the whole set out and turn it around do get it right then getting the lines to "snap in" was a PITA as well the good folks @ Dorman just didnt make it real easy to do but I finally got it with a lil massaging with the tubing bender but they are in and no leaks on fire up either so im good to go for awhile..........
Old 05-15-2009, 11:35 PM   #121
99sonoma4x4's Avatar
I posted this on my jimmy resurrection about clamps that i found, They are called Mikalor Clamps they are 5/8 wide t-bolt stainless steel clamps 17-19 mm.They have a really great bolt to tighten with, and great clamping power.Alot better than worm drive clamps.
Old 06-02-2009, 07:37 PM   #122
Talking Re: Repair your leaking oil cooler lines!
180,000 miles on my original lines before they actually sprung a leak under the radiator support at the plastic clamp . of course this was during a long trip and I pretty much roasted my engine LOL!!!!
picked up a 1993 4.3 out of a full size truck and new cooler lines total cost so far $280 the new / used engine has 72,000 miles on it from a totaled truck .
Don't ya just love the S-10 's
just try to repair a ford ranger or dakota under the same circumstances for less ....
Old 06-04-2009, 01:24 AM   #123
Just relocate the filter straight to the block all you need is a piece from a small block, to connect the filter to the block all you have to watch out for is the drive shaft clearance, shouldnt be a problem for normal driving
Old 06-23-2009, 09:25 PM   #124
S-10rgasim
CaliCustom90's Avatar
Hotwire, im planning on using the 4x4 adapter on my 2wd s10. Then i want to run lines from the remote filter threw an aftermarket oil cooler instead of using the dual cooler radiator which I dont have in the 2x4. I am running the melling hi-flo pump. What do you think about the aftermarket engine oil cooler in this situation?
Also, Im on my 3rd 4x4 s10 and all of them had the leaky factory lines. I want to fix them like you explained in your sticky. I also wanted to do the 2x4 lines in the same manner.
Thanks for the detail about the crimp.
Old 07-27-2009, 02:30 PM   #125
this info is good shit but i have a question on the easiest way to change out the o ring on the adapter plate that bolts to the block.
Old 07-27-2009, 02:47 PM   #126
by starting a thread asking this question instead of posting it in a sticky.
Old 08-26-2009, 01:32 AM   #127
Aquatic Goat Farmer
uhlhazard's Avatar
cali90, Hotwire got banned for whatever reason and is gone. If you want a complete strangers opinion, the high volume pump is worthless and can actually be bad to have (I'll let you search on your own for the specifics) but you still should be fine with the line.
Old 08-29-2009, 12:52 AM   #128
Unregistered User
j894's Avatar
since this has been kicked up...
my 2nd set of doorman lines (warranty) also had the bracket on backwards... took 10 minutes of spinning it around and messing with things trying to get the holes to line up before I realized it. lol.
Hopefully the 2nd set lasts longer than the 1st; at least rockauto was kind enough to replace them under dormans warranty 3 yrs after I bought them, a definite thumbs up for that.
Having poly motor mounts sure makes changing these damn things a lot easier. Those ****in bracket cage things aren't surrounding the mounts like they are on the stock engine mounts... so I dont have to disconnect them and jack up the motor to change the lines
Old 12-04-2009, 02:41 AM   #129
stupid regular cab!!
01x.joyride's Avatar
since its been awhile...just wondering if the people that have tried this upgrade...have had their new oil cooler lines leak yet..??
i have a new motor going in my truck soon and im pondering the idea of removing the oil cooler lines completely or, if this works maybe ill just do this...
anyone with this mod, i'd appreciate your feedback and how well its worked so far!
Old 12-07-2009, 08:47 AM   #130
sockjock's Avatar
No leakage yet.
Old 12-09-2009, 11:29 PM   #131
No leakage yet.
how long has it been for you??
Old 12-10-2009, 02:22 PM   #132
sockjock's Avatar
About a year and 10K miles
Old 12-10-2009, 04:22 PM   #133
forum idiot
i still need to do mine...mine leak like crazy
Old 12-11-2009, 11:18 PM   #134
how bad? as of late, since it was 80-100 degrees all summer, and now its in 10-20 degree range at night, mine have gotten worse...
40 minute drive home, about 1/2 way home to 2/3 the way home, my shit leaks and blows straight onto my exhaust and smokes hardcore in the rearview mirror...lol...thats why ive been asking these people as of late about their new oil cooler lines mod, i need to do something fast!
Old 12-14-2009, 01:16 AM   #135
Aquatic Goat Farmer
uhlhazard's Avatar
Mine are leaking, have been for the last few thousand miles : (
Anyhow I am going to replace the line with the same stuff I had because I think it was the clamps and not the line itself. O and I have just under 201K so I think I put about 40K on the lines.
The worm style clamps need more BALLS so I'm going to look into the above posters recommendation and see whats what.
Will report back asap!
Old 12-27-2009, 05:25 PM   #136
acknowledge it.
joyride's Avatar
so as far as how bad mine were leaking...heres a pic for a general idea...lol
and after taking off my oil filter...wow...im ****ed
i was going to just delete my oil cooler lines in all, but after taking the first bolt out no problem, i managed to strip the 2nd one...so i was like wow wtf?!?! i sprayed the shit with liquid wrench twice before i even tried and let it sit for like 5-10 mins each time...
so now i just replaced my linesfor the time being, they only have to work for a good couple months and thats it, that's if my motor can even mange to keep on truckin to and back from work til i pay off my motor ...glad i got a milkshake for oil now though...makes me feel great.
and btw, this whole process was fairly easy...i actually ended up taking the oil cooler lines off completely, from the remote oil filter adapter, to the radiator, cut the bitch in half where the rubber hoses are, and replaced the hoses with new ones and double clamped those ****ers! haha....seems to be working just fine for now..
and also...if anyone ever has any trouble tryin to take off a stuck oil filter, after 2 or 3 unsuccessful tries at taking it off, i put on 2 pieces of sandpaper back to back and wrapped it inside the oil filter wrench onto the filter to get a nice good grip, came out no problem. lol...thank god too.
Old 01-03-2010, 12:15 AM   #137
Smile Re: Repair your leaking oil cooler lines!
Thanks to Hotwire. Your repair did the trick for me. I have a 95 S10 4X4 and it was next to impossible to remove the rear part of the oil cooler line. I chose to try your repair as an alternative. So far it's holding up well. Thanks again.
Old 01-06-2010, 10:24 PM   #138
King of the Hill
well worn s10's Avatar
Help a newbie out here. I'm purchasing a 98 s10 this weekend... 2wd,4.3, 5speed. This forum has been my crash course on S10's. I didn't know this problem existed, and would have never thought to look for it.
So if you guys could help me out a bit...
Is this a problem on ALL 4.3's, all years, 2wd or 4wd? or just a few specific models?
The pix are gone on the O.P. Could someone post more so I know what to look for and what this mod looks like when finished?
Old 01-07-2010, 02:08 AM   #139
acknowledge it.
joyride's Avatar
jack up your truck and crawl underneath, the lines connected to where your oil filter is, go to the radiator, driver side. theres a bracket holding them on in the middle held on by one bolt you'll have to take off which is no big deal...i don't know how many people do it but, i completely took my lines all the way out, cut the rubber part in the middle in half on both so i could take the lines off from each side alot easier....cut them off near the clamps, put the new rubber hose on, double clamped them on both sides on both hoses, installed the ones on the radiator first, ran the hose back where they were, put the other end of the lines in on the oil filter adapter bullshit, then in the middle, clamped them together with 2 hose clamps on each and called it a job....it really wasn't that hard.
Old 01-07-2010, 04:43 PM   #140
turbovanman's Avatar
You better fix the coolant leak into your oil before you wipe out the bottom end.
2WD you could delete the oil cooler but 4x4, I wouldn't, they put it there because the engine is so cramped, this also helps the engine run cooler and the oil last longer.
Old 01-07-2010, 11:03 PM   #141
acknowledge it.
joyride's Avatar
haha ya i know huh....my new motor is almost done, it can't be an intake gasket cuz that was just replaced a year maybe year and a half ago...but my new motor is 2 weeks away from being home, im paying half of the 700 i owe left on it tomorrow, and then in 2 weeks when i get paid again ill finish that thing up...and bring it where it belongs...im just gonna run my truck til it dies i guess...i assume its a head gasket, but wouldn't my truck be running worse? and then constantly get worse? is there a slight chance i could have gotten water in through my oil cooler lines? trust me, i put them off for as long as possible and near the end they were leaking so god damn bad....i got a picture to prove it...lol....
sorry jesus that is a big pic...my bad!
Old 01-08-2010, 08:27 PM   #142
SpiderDallas's Avatar
I am wondering if you could use steel braided line just to fancy it up a little that is what I am thinking of doing and then using the blue and red hydro fittings and tap and thread the adapter for the part that goes between the filter and block.
Old 01-08-2010, 10:57 PM   #143
LT1 S10 Expert
Braided hoses and Earl's fittings? I think the OP did this to help out the po' boys like me and most of the other guys on this forum. I guess this is the "budget" repair to your leaking oil cooler lines.
But, yes, to answer your question you could definitely use braided hoses and fitting and probably won't have to worry about leaks for a long time.
Old 01-09-2010, 10:55 AM   #144
Yeah I just spent a lot of money on my motor build so don't want to go cheap on anything unless that is the only thing they make which isn't the case on oil coolers.
Old 01-22-2010, 04:19 PM   #145
Professional Douche
gmjunkie's Avatar
Hi I am intrested in preforming this repair, but I can't see the pictures, all I get is a square with an x. what am I doing wrong? thanks.
Old 01-22-2010, 04:21 PM   #146
LT1 S10 Expert
Pics are gone. Original guy who posted was banned from the site.
Old 01-22-2010, 04:57 PM   #147
Professional Douche
gmjunkie's Avatar
anyone have any idea where I could get more info (pics) on how to do this?
Old 01-22-2010, 08:51 PM   #148
acknowledge it.
joyride's Avatar
here is exactly what i did, since i dont have any pictures to show ya ill explain it the best i can...
jacked up the truck, unscrewed the 2 bolts holding on the oil cooler line to the oil filter adapter....went to the middle of the oil cooler lines, noticed a bracket holding the lines in place on the frame, took the bolt holding that off, went to the radiator...found the other end of the 2 oil cooler lines, took them off...so now i have the whole setup off the truck...leaked some oil but thats ok...can always clean it up...
then...took a pipe cutter and cut off the ends shortly after the black hose stopped, cut the new pieces of the new oil cooler hose i had for it to a lil longer than the old ones, and double clamped each on to the end closest to the radiator before installing it all back on...i then put the oil cooler lines back into the radiator, and the opposite ends of the cooler lines back into the oil filter adapter, leaving the middle section of the lines d/c, that get thrown onto the oil filter side of the lines...lubed the last 2 lines up and double clamped those onto that other end....and put the lines back through the lil bracket and bolted it back to the frame...called it a job...haven't leaked yet...its only been several weeks though....lol
hope that helps, im not the best at explaining things, but i took the whole oil cooler line setup off thinking it'd be easier to not have to work from underneath the truck the whole time...goodluck
Old 01-25-2010, 08:02 AM   #149
You can still email the OP and get the pictures. He has them up on another site that didn't ban him.
Old 01-25-2010, 08:13 AM   #150
Professional Douche
gmjunkie's Avatar
how do I get his email?
