Removing oil pan with motor in truck????? - S-10 Forum
post #1 of 23 Old 03-12-2007, 11:48 AM Thread Starter
User is: 20xtreme00 is offline
Truck is 2000 S10 Xtreme LS extended cab Stepside 4.3 Auto 2WD
ok, from what ive read in my repair manual you have to pull the motor to change the oil pan gasket. I have my motor torn down to just the block and roatating assembly and have found my timing cover gasket and oil pan gaskets are leaking. I pulled the timing cover off forgetting the bottom went into the oil pan, I pulled the front u part of the pan gasket out. Now my question is, can I drop the pan and change the gasket in the truck. Or should I just puu the motor and change the rear main seal and all the minor stuff while I have it torn down? How much of a PITA is it to get the top bellhousing bolts in/out?
post #2 of 23 Old 03-12-2007, 12:12 PM
Gaaoooooo
MINTSICK's Avatar
User is: MINTSICK is offline
Re: Removing oil pan with motor in truck?????
You could lift it up a bit and gain maybe an inch or two to put in a new gasket, but if you have it torn down that far why not pull it out? Why is it torn down to the block?
2004 Silverado Z71 ECSB - |Silver Birch Metallic|5.3|Custom Single Exhaust|Method Standards
1993 Mustang LX Hatchback - |Reef Blue|5.0 H.O.|5 Speed|MGW Short Shifter|70MM MAF|MAC Shorty Headers|Pypes O/R X|Spintech Pro Streets|3.55's|
1984 El Camino Conquista - |Black|5.0L|Comp XE262H|Holley 570|700r4 swap|2.41 open rear|
MINTSICK is offline
post #3 of 23 Old 03-12-2007, 12:35 PM
rat
Got Fuel Rails?
rat's Avatar
User is: rat is offline
Send a message via AIM to rat
I think you would have to pull it all the way out to get the gasket in there, i don't think you could get it around the crank and mains, or the oil pump pickup with the oil pan dropped only slightly.
Rick, aim-RAT5111468
2000 4.3 auto
Custom Intake Manifold with 32lb/hr Injectors, Comp cam 260AHR, Tuner Cat Speed Density tune, Vac modulated trans with shift kit and vette servo, Bolt on's
Camshaft Tutorial-----My Truck and The Roots Blower Project ------ My Tuning Tutorial
rat is offline
post #4 of 23 Old 03-12-2007, 12:40 PM
Gaaoooooo
MINTSICK's Avatar
Forgot about that, I suppose if you didn't want to pull it out one could cut the gasket at an angle on a straight part of the gasket and give it a lil rtv in that spot to ensure it doesn't leak. I had to do that with a valve cover gasket that seemed to be stretched longer than normal that I couldn't get to fit into the groove, hasn't leaked yet.
MINTSICK is offline
post #5 of 23 Old 03-12-2007, 02:47 PM Thread Starter
I guess i'll just pull it, my buddy keeps tellin me to pull it anyway......
I have it torn down because what was originally diagnosed to be a bad headgasket turned out to be an intake gasket, but since I already had the parts and was that far I decided to do the head gaskets, and now seeing the timing cover oil pan gaskets were leaking I decided to replace all the gaskets and shizzle like that, I wanted to V8 Swap but im Pooooooor. Time is not the issue, but paying $142 a month for the truck and $310 for my Car, Plus $662 a month insurance makes me want to be able to at least drive it, who knows, Im working on getting a HEFTY raise at work, we'll c...
post #6 of 23 Old 03-12-2007, 08:10 PM
i <3 sperm
4wd86's Avatar
User is: 4wd86 is offline
Fel-Pro oil pan gasket set no. OS 30386 G
It fits GM product V6, 200, 229, (3.8L), 262 engine., 1978-95
I got mine at AutoZone. The oil pan "gasket set includes:
Qty. Part No. description
1 30328 oil pan front seal
1 30374 oil pan rear seal
1 30386 oil pan side
1 30387 oil pan " side
The oil pan gasket is a two piece gasket made from cork. There is no need to cut something that is already in two pieces.
As for installing it; My suggestion is to pull the motor unless you are without access to an engine hoist, tow truck, etc.
The oil pan won't come off without the bell housing/flywheel (or flex plate in the case of an automatic transmission) being removed first. Its not the crank that is so much the problem as it is oil pump/pick up tube that is going to block the removal. Even with the bell housing off, you are still going to have removal of the oil pan blocked by the oil pump/pick up tube. You can drop the oil pan down and get a couple of inches clearance to install all four pieces of the oil pan gasket. However, that is going to be considerably harder than doing it with the motor out of your truck. I think you will be able to do a considerably better job of installing the oil pan gasket with the engine out of the truck and it will be much easier on your back too. It is not a job that you want to have to do twice because it didn't seal right. It will take less time to pull the motor out and change the oil pan gasket than it would to try and do it with the engine in the truck. Its a PITA that you don't want to do twice. It is something that will probably outlast your motor if its done right (the first time).
Warmest regards from Florida
4wd86 is offline
post #7 of 23 Old 03-12-2007, 08:23 PM
Gaaoooooo
MINTSICK's Avatar
96+ use a 1 piece silicon gasket that fits into a channel on the oil pan itself...
MINTSICK is offline
post #8 of 23 Old 03-12-2007, 08:58 PM Thread Starter
And like it says, I have a 2000, thats works up to 95.........
Im gonna pull the motor, just not looking forward to the upper bellhousing bolts, I have BIG hands
post #9 of 23 Old 03-12-2007, 09:07 PM
Gaaoooooo
MINTSICK's Avatar
Unbolt the tranny from the crossmember and support it with a jack under it, then unbolt the motor mounts and pull the engine forward an few inches with it on the hoist to get better access to the bellhousing bolts.
MINTSICK is offline
post #10 of 23 Old 03-12-2007, 11:24 PM Thread Starter
would it make since to pull the motor/tranny together, and then drop em back in together? Would it be fairly easy to get them out together?
I am planning on having the tranny flushed soon as I get it all back together, maybe it would be a good time to throw a shift kit in or new servos? Change the front pump seal? converter?
Im just trying to make sure I get all the small thigns that can become a PITA later fixed now since its torn down.
post #11 of 23 Old 03-12-2007, 11:33 PM
Will work for turbo parts
User is: King_Ice_Flash2 is offline
Send a message via AIM to King_Ice_Flash2 Send a message via MSN to King_Ice_Flash2 Send a message via Yahoo to King_Ice_Flash2
Too bad it's only the 4WD you can do the oil pan in the truck. You just pull the front axle out.
post #12 of 23 Old 03-13-2007, 10:27 AM
Gaaoooooo
MINTSICK's Avatar
You have to remove the core support to take it out as one I believe, once the core support is of it would be cake.
MINTSICK is offline
post #13 of 23 Old 03-13-2007, 05:08 PM Thread Starter
isnt the core support welded in?
post #14 of 23 Old 03-13-2007, 09:27 PM
Gaaoooooo
MINTSICK's Avatar
Bolted in.
MINTSICK is offline
post #15 of 23 Old 03-13-2007, 09:43 PM
Blown ex ***
Jess's Avatar
User is: Jess is offline
it is possible to put the oil pan gasket in with the engine still in. but its a PITA. take the engine out.
the bellhousing bolts are the least of your worries. with the top of the engine off, the top bellhousing bolts are easy. its the convertor bolts that can be a pita.
97, VORTECH V2 SQ / PowerStroke FMIC @14 psi, A4, 3.08
a broken down 13.88 @ 96.65
now with, 2114, 270ahr, ported heads, 1 5/8 L/T's & true duals, TunerCat, LC1 & XD-16, 3:73 Z/T
My Truck...
video = http://video.google.com/videoplay?do...55517765935057
95 x-cab, silver, tint, 4.3cpi, a4, 3/4
EDELBROCK TES & 3 1/2" exhaust for sale. PM me
Jess is offline
post #16 of 23 Old 03-14-2007, 06:47 AM Thread Starter
yea, overall I think this truck is a PITA! Also, when putting it back together, Can you put the fully assembled motor in or do I have to put the intake on after its in, I read in the manual to remove the intake before pulling it, Is that just to ease getting to the PITA ground straps and fuel line bolt on the back of the head?
post #17 of 23 Old 03-14-2007, 09:52 AM
I call her: NIGHTMARE
98 SS's Avatar
User is: 98 SS is offline
Send a message via AIM to 98 SS
the easiest way IMHO....because ive done it TOO MANY TIMES TO COUNT!
When the engine is torn down to no heads, the bell housing bolts arnt bad at all. But once you have the engine back togeather, or if you have one togeather to start with. The easiest way I have found is to undo the body mounts and jack the body up off the frame a few inches. Makes life so easy, you can use extensions and get to all the bolts no problem, makes getting the wires off the heads easy too.
98 SS is offline
post #18 of 23 Old 03-14-2007, 02:25 PM Thread Starter
That sounds like the way to go^^^^^^^
post #19 of 23 Old 03-14-2007, 02:26 PM Thread Starter
double posted....sorry
post #20 of 23 Old 03-14-2007, 07:47 PM
User is: bg's is offline
Jeeez. Lift the body off the frame a bit..Had no idea getting the engine out
was going to be that much work. I hope mine stays running and I SWEAR
I will drive MUCH easier. I don't like the sound of this at all..
bg's is offline
post #21 of 23 Old 03-14-2007, 08:04 PM
UN-BANNED B!TCHES!!!!!
NotaDime's Avatar
User is: NotaDime is offline
you DO have to pull it, to replace it, dont try to cut corners, i just did mine last week.
WTB cowl hood near valdosta GA NOW...
Seems like there are still a few people (Imperial, NotaDime, etc...) here that still have working brains.
Originally Posted by The Master View Post
BTW last post evar on this site. cheers and.....fock off.
Originally Posted by v8lonoma View Post
everything notadime said +1.
NotaDime is offline
post #22 of 23 Old 03-14-2007, 08:38 PM
98 SS's Avatar
Lifting the body up is pretty easy.....Ive gotten good at it. lol
What do you shoot for SASS? Stepdad shoots 2 vaquero? 45's One of the new really nice ones, and one of the normal or older ones.....dont know the differences for sure, but they shoot different.
98 SS is offline
post #23 of 23 Old 03-15-2007, 03:30 AM
Haven't shot a round yet, but I'll use my old model Vaq in 5.5/45lc or
my 2nd Gen Colt SAA 5.5/45lc. I hate to fire the Colt because it cost a
LOT of money and is still pretty nice considering..I'm saving for a Marlin
lever action in 45lc and an early lever action shotgun if I can find one.
Here's one of my Colts.
I better not post anymore about firearms here. Off Topic is the better
place I thinking.
bg's is offline
