Rear end gear oil - S-10 Forum
post #1 of 9 Old 02-26-2010, 04:17 PM Thread Starter
User is: Drak is offline
Rear end gear oil
I was going to change the gear oil in the rear end but i got 2 questions.
1. Is there anyway to drain the oil without cracking the case?
2. The fill point for the rear end is it the plug which seems to accept a 1/2" drive?? I'm not sure how to get it out because it seems rusted anyone ever have any trouble getting them out??
2002 Sonoma SLS 4x4
Drak is offline
post #2 of 9 Old 02-26-2010, 04:21 PM
User is: Levinz11 is offline
Re: Rear end gear oil
If you are going to change it you might as well take the cover off. It's a good time to inspect the internals for wear and carnage. You can just loosen the bolts on the bottom half and let it drain if you feel lazy. Just get some RTV and bolt it back up. Very easy job bro.
Did you actually try to loosen the plug?
Levinz11 is offline
post #3 of 9 Old 02-26-2010, 04:27 PM Thread Starter
like the rust is built up into it and i couldn't seem to get the end of a wrench in and i'm afraid if drains the oil i won't get the plug out
Drak is offline
post #4 of 9 Old 02-26-2010, 05:10 PM
monkeytruckin's Avatar
User is: monkeytruckin is offline
Take a pick and get all that crap out. Spray some PB Blaster. Let it sit a bit, Tap the bolt lightly a few time's. Spray again and give her a try.
post #5 of 9 Old 02-26-2010, 05:17 PM
far2grumpy's Avatar
User is: far2grumpy is offline
One of my better "life-lessons" was when I learned to make sure I can remove the fill plug before removing any drain plug ... or in your case the rear cover.
I suggest you use a quality extension on your socket wrench for the plug.
Its too easy to twist the end off of many of cheaper tools now on the market.
It also helps if the extension is long enough to give you a straight shot at the plug.
post #6 of 9 Old 03-03-2010, 10:09 PM
MTchevyS10's Avatar
User is: MTchevyS10 is offline
Most axles with differential covers require it to be removed to drain the oil, unfortunately. It isn't a tough job and nothing some RTV or "The Right Stuff" gasket maker can't fix back up in no time.
'97 Stepside: D44+Aussie/9"+Detroit
'07 Solstice GXP: 2.0L Turbo
post #7 of 9 Old 03-03-2010, 10:16 PM
no longer has a 95
95 S_Trucker's Avatar
User is: 95 S_Trucker is offline
Send a message via AIM to 95 S_Trucker
and it should be a 3/8 extension, not 1/2
99 Blazer 2 Door, 4wd, NV3500, 8.5
99 K2500 LS CCSB 7.4, 4L80E
post #8 of 9 Old 03-03-2010, 10:18 PM
Extended cab or no cab.
cpolaris502's Avatar
User is: cpolaris502 is offline
Yup, make sure you can get the fill plug out before you drain the oil. Scrape it out the best you can and let it soak with some PB blaster, as said.
Cory - TWISTED KONCEPTS
1999 2dr Blazer-Bagged and V8'd {Build Thread}
2005 Silverado 2wd 4/6'd. 402ci LSx/4L80e/turbo 800whp, 20psi boost---- Build Thread
1982 2wd Chevy C30 Crewcab Dually, 454/Manual
2006 Audi A4 3.2l Quattro.
post #9 of 9 Old 03-03-2010, 10:27 PM
no longer has a 95
yea, we have all made the mistake at one point or another, and i ended up pouring 2 qts of fluid down the vent on one of my trucks, i have since gotten the plug out and replaced
