Radiator leaking - S-10 Forum
post #1 of 7 Old 10-05-2012, 02:32 PM Thread Starter
User is: The Producer is offline
Radiator leaking
Have an 02 S10 crew cab with a trailer towing package.
I have leaking from the right side of the radiator from the second connector down an oil cooler line. I have tighted the nut as tight as possible, am I missing a washer or o ring that I can replace to fix the leak? There is not other issues with the radiator so I would hate to have to change the whole thing out.
Any suggestions or help would be great thanks.
post #2 of 7 Old 10-05-2012, 02:46 PM
burned's Avatar
User is: burned is offline
Re: Radiator leaking
Fitting looks like this:
http://www.amazon.com/ACDelco-15719697-Engine-Cooler-Connector/dp/B0049Z6Q6E
How to:
http://www.handymanlyness.com/archiv...il_cooler.html
2002 Dakota, QC 4x4, 4.7L HO Intake.
1997 S10 ZR2, Ext Cab, 5 Speed (SOLD)
How to test fuel pressure and leak down <---diagnostic help
burned is offline
post #3 of 7 Old 10-07-2012, 02:24 PM Thread Starter
It's not leaking oil, it's leaking coolant.
post #4 of 7 Old 10-07-2012, 02:41 PM
burned's Avatar
http://www.s10forum.com/forum/f107/r...-lines-494492/
burned is offline
post #5 of 7 Old 10-07-2012, 03:06 PM
Registered Hoosier
Hoosier Rick's Avatar
A radiator shop would have to take the tank off to replace the seals. Should be under fifty bucks to repair.
2000 Jimmy 4x4 4dr. 252,000 miles
2002 rcsb, 2.2 at, 253,000 miles
1967 C10
post #6 of 7 Old 10-09-2012, 10:53 AM
400ex4ever's Avatar
User is: 400ex4ever is offline
http://www.s10forum.com/forum/f17/ra...-fixed-502181/
If it's leaking from here...try tightening the lock-down nut. If that doesn't work, you should take it in to a radiator shop like Hoosier Rick said.
2003 Chevy Xtreme 4.3
post #7 of 7 Old 10-13-2012, 11:17 AM Thread Starter
So I took the lock nut off cleaned the threads reall well- cleaned the lock nut and bent the nut in a little bit, added an O-ring and some yellow pipe tape on and reassembled it and it is holding to this point. Thanks for all the input.
