Radiator Flush 98 Blazer - S-10 Forum
post #1 of 7 Old 05-19-2011, 09:30 PM Thread Starter
1998 S10 Blazer
2001cvpi's Avatar
User is: 2001cvpi is offline
Is GoodYear a good place to get a Radiator flush? They use a machine to completly flush. Any help welcome.
Thanks
2001cvpi is offline
post #2 of 7 Old 05-19-2011, 09:49 PM
SSRT-S10
my_nightmare's Avatar
Re: Radiator Flush 98 Blazer
Lol.., talk about memories... I used to work at a Goodyear place and I did That alot on alot of vehicles. It can be good IF and only IF your coolant system has NO leaks.., your water pump is in real good shape, and that your heater core and radiator has no blockages and no leaks. Otherwise.., it's time to break out the wallet. If they still use the same types of machines as they did when I was there, it will suck coolant out using air and force cleaner into system making it flush thru system.., then they will have to run the vehicle to get to temp. Then.., they check for leaks. Drain system with machine, then make it vacumn pump fresh coolant back into system.
Now here's the catch... Make sure YOU specify what kind of coolant goes back into system. Make sure they dont shove ANY of the dexcool crap back into it. That stuff is junk and can clog up system and even, (in a worse case senario) can make your engine overheat if it clogs up tooo much in system.
Just my 2 cents worth..
P.S. If ya got some free time.., and got a water hose with alot of pressure to it.., make a trip to autozone or advance.., and get the clear bottle with blue liquid radiator flush. You can achieve the same thing for alot less $$$ at home and get more satisfaction knowing you did it yourself. Take the old antifreeze back to advance and they will dispose of it for free. The bottle of stuff has the instructions on it and at the shop where I am at now.., it is what we use. (we got a flush machine there as well and we put the stuff into the machine....lol)
l8taz,
Allen
post #3 of 7 Old 05-19-2011, 10:07 PM Thread Starter
1998 S10 Blazer
2001cvpi's Avatar
Thanks! Appreciate the knowledge. Unfortunately I am limited on how much work I can do to my truck living in an apt. But I did talk to GY and the tech told me they will replace the Antifreeze with Dexcool because once it is used then you should stick with it. I have heard the horror stories but have had NO problems. Dexcool was put in about three years ago when the lower manifold gasket was changed. I've always wanted to change over to the good ole green stuff!
2001cvpi is offline
post #4 of 7 Old 05-20-2011, 11:42 PM
SSRT-S10
I work on 5 to 10 vehicles a day. Alot of them with cooling problems. I've seen the clogs in intakes, the corrosion in radiators, heater cores stopped up, and even water pumps clogged up from this stuff. Dexcool is like pouring sand into your cooling system or your oiling system. You can expect it to clot up no matter what. If I get a customers car in shop, and it has cooling issues AND it has dexcool coolant in it.., we (the shop) STRONGLY reccommend changing coolant to a "mix with any" type coolant...(Prestone, Advance, Oriely, Napa brand, Etc....) We usually flush the system to remove every bit of dexcool as best as we can.., then we get the customer to run the new type antifreeze.... (mix with any..)
It your option,your motor, and your preference dude.
This just my two cents....
As for me.., Never.., Never..., NEVER will use dexcool for ANYTHING I got !!! Been there.., Done that.., and FIXED it toooooooo many times!!
Dexcool =
post #5 of 7 Old 05-21-2011, 08:14 AM Thread Starter
1998 S10 Blazer
2001cvpi's Avatar
Thank you all for the advice! I APPRECIATE it and definitely changing out the Dexcool! Today!
2001cvpi is offline
post #6 of 7 Old 05-21-2011, 10:15 AM
Zeeke98's Avatar
User is: Zeeke98 is offline
Dexcool is only bad if you don't change it at regular intervals and if you have air leaks in the system. In a properly maintained and sealed system it is fine. The problem is 99% of people think you never have to do anything with the cooling system.
Wade
03 Chevy S10 Blazer 2 door 2wd Cherry Red Metallic, 3/3 Belltech drop, 18" Ridler 695 18x8 wheels with Pirelli 235/50/18 tires, SS mirrors, Bravada front clip, 6000K low/4300K high HIDs, smokey red tails, Spectre cold air intake, Hypertech programmer, Cherry Bomb turbo w/turndown, Envoy door panels and handles
02 Camaro SS SLP 345HP Black 6 speed T tops
85 Camaro IROC Z28 Silver 305 TPI Auto T tops
Zeeke98 is offline
post #7 of 7 Old 05-21-2011, 03:16 PM
JustAnSS's Avatar
User is: JustAnSS is offline
^^This. I personally haven't had any problems with it, no sludge in my radiator.
JustAnSS is offline
