po1345
ok so my truck is throwing a 1345 which is a crank, cam correlation
truck is a 98 and at idle which is about 600 it goes up and then falls down below 600 a few times then idles rite and does is again and as im in overdrive and maintaining speed it gives a little misfire i searched and i came up with its in the distributor or the crank sensor motor is just rebuilt and never had these problems before the guy that put it in said the distributor is supposed to have a locker in it and it doesnt (idk) helpl please |
Re: po1345
also forgot to mention it runs very hot and wants to keep climbing
Wire Splicin Fool :-)
Re: po1345
Is this a 1998 Model? You never verified that on your other thread.
Re: po1345
yes
Registered (Ab) User
Location: League City, TX (Houston) User is: OffLine ![]() |
Re: po1345
P01345 would seem to indicate that the dizzy is not installed properly. Have you rechecked the timing marks?
Re: po1345
no from what i understood is you can only put it in one way or it wont run
do you believe this could be causing the overheating problem Last edited by chevyistheway : 08-20-2008 at 07:24 PM. |
Re: po1345
You said it gets hot, is this what the guage says or is it being read by a scanner or by manually testing it. If it is running hot, is your cooling system good, I.E. good thermostat operation - boil the sucker till she opens and measure temperature. Hows the ignition on the beast, have you messed with it, is the dizzy a tooth off? Is the Cat plugged up?
Re: po1345
you have to align the teeth on the dizzy with the dizzy drive gear inside, also you need the crank turned to a certian spot and the rotor turned to a certian location, there are several links in the forum on how to do this, I would recheck it man.
Re: po1345
Re: po1345
i have no idea how to check the teeth, i didnt put it in nor did i ever see it out, i didnt touch this motor as it was being built so i dont know what was done
Re: po1345
If it is too far advanced it could overheat and ping also, high octane gas may run cooler.
Re: po1345
Click here for installation instructions in post #30.
The rotor need to point to the tab on the dizzy housing with "6" on it when the timing marks on the crank damper are lined up. |
Re: po1345
runs much better still stalls a lil on take off and misses when the motor is cold but still has the code on removed t stat and now no overheating probs |
Re: po1345
Moving the dizzy gear one tooth moves the timing 27* so maybe that is how he advanced the timing.
Did you reset the PCM after he moved the dizzy? |
Re: po1345
Did you cook the tstat in home with a thermometer to make sure it was running right? Was the stat in the right way when you took it out?
Re: po1345
and no i didnt reset the pcm but a friend of mine goes to college and tried to clear the code and it didnt work his teacher who just so happens to used to work for gm says he thinks my pcm needs a cam relearn ??? Last edited by chevyistheway : 08-24-2008 at 03:50 AM. |
Re: po1345
Re: po1345
The 195* stat should start to open around 185 I think and should be very smooth in operation, you can and alot of times WILL get a bad thermostat from the parts store, my father in law got 5 in a row bad, that is why you cook them on the stove with a thermometer before installation. I think you may have a problem if your stat is good and you were having those issues, I would definitely put a (known good) stat back in and try to figure out the problem, other wise that thing may stab you in the back somewhere not good.
Re: po1345
I wouldn't run without a t-stat. The stat puts some backpressure on the water pump so that the pump won't cavitate. Cavitation is bad for the pump and can cause low flow and excessive pump impeller wear. Overheating is real common on motors without the stat. If yours is now running cooler, that would point towards a bad t-stat.
Re: po1345
alright thanks guys ill check into the tstat this week but what about the code do yall think it could be a cam relearn even w/ the pcm tune or do i have other problems
Re: po1345
Re: po1345
Re: po1345
The proper gap for a '98 is .060" so that will definitely affect your low speed operation in a negative way. I would definitely regap the plugs to .060" but don't expect it to cause a dramatic difference in performance. Are you sure that the plugs are "NGK 7"? I have NGKs in my '98 Blazer and the number is TR55IX. A "7" sounds strange in NGK's numbering system. Are you sure those plugs are recommended for the 4.3? Last edited by Yogi : 08-24-2008 at 08:21 PM. |
#24 |
Re: po1345
i have the 2 stages colder than stock so i can run a 125 later down the road |
#25 |
Re: po1345
ok so today i advanced the timing as far as i could w/o moving the dizzy over a tooth and my code was still on
tonight i raced a guy up to 80 and the code is now gone i still dont think something is right, i cant spin a tire at all on take off and i could before the rebuild |
