pcv valve? annoying buzzing sound! - S-10 Forum
post #1 of 26 Old 12-24-2011, 04:43 PM Thread Starter
s10-4-life's Avatar
User is: s10-4-life is offline
I have replaced my pcv valve multiple times and it still buzzes like a mother! do all s10s have a loud pcv valve? my truck is a 2000 s10 4.3L LS. When I have my truck in park at idle and I'm sitting in my cab it just buzzes away like there is a bee buzzing in my ear! Or when I stop at a light i can hear it buzz. It's really annoying! please help!
post #2 of 26 Old 12-26-2011, 03:23 AM
"factory freak"...
Crew Cab Sonoma's Avatar
Re: pcv valve? annoying buzzing sound!
It certainly doesnt happen on all of them, but does seem
to be a somewhat common issue
If you're certain it's the PCV valve, try putting a restrictor
in the tube near where it attaches to the manifold.
This may eliminate the rattle tendency.
The restrictor can be a piece of rubber fuel hose, but oil
cooler hose would be preferable, due to its oil better
oil resistance, but fuel hose will suffice if it is inspected
regularly for deterioration.
Just make sure whatever you use fits snugly, and
can't be pulled into the intake manifold...
95 S-10 2.2. Soon to be DD
post #3 of 26 Old 12-27-2011, 10:03 AM Thread Starter
s10-4-life's Avatar
It's the pcv valve I know that for sure. I am not understanding what you are talking about here? you want me to put a tube inside the pcv valve tube? *confused*
post #4 of 26 Old 12-27-2011, 11:29 AM
"factory freak"...
Yes. To restrict maximum flow
through the PCV valve.
It should help dampen the
the valves tendency to rattle.
This has worked for me on a
few vehicles in the past.
Also try rerouting or padding
the throttle cable if it contacts
the PCV tube, as the cable tends
to help transmit the rattle noise
into the trucks cabin.
post #5 of 26 Old 12-27-2011, 12:00 PM Thread Starter
s10-4-life's Avatar
alright man, thanks for the help! I'll give it a shot!
post #6 of 26 Old 12-29-2011, 05:46 PM
1998 S10 Blazer
2001cvpi's Avatar
User is: 2001cvpi is offline
Mine started buzzing after I got a new one. Quite common. I re-adjusted it a bit more snug and it went away. Happend awhile later at start up then stopped. I'll just replace it if it happens again with Delco. wtf... No biggie.
2001cvpi is offline
post #7 of 26 Old 12-29-2011, 07:14 PM Thread Starter
s10-4-life's Avatar
you think a delco pcv will not buzz like all of the other cheap brands?
post #8 of 26 Old 12-29-2011, 07:26 PM
"factory freak"...
It might, but IIRC, a couple of people in the past
on here have claimed their original did it as well.
But who knows...
post #9 of 26 Old 12-29-2011, 08:12 PM Thread Starter
s10-4-life's Avatar
I was going to buy a delco pcv but I never got around to it because I've been to busy trying to figure out my trucks vibration issue!
http://www.s10forum.com/forum/f107/n...ration-485083/
post #10 of 26 Old 12-30-2011, 06:37 PM
User is: jweller is offline
The buzz on mine went away when I replaced all the vacuum lines. I hasd some symptoms of a leak and just replaced all of them rather than try to find it. Costs less than $10.
1999 Sonoma Highrider SLS Stock....for now
1997 S-10 ext cab 4x4 5-spd AAL Tbar crank Upper ball joint flip 31x10.5 R.I.P. 3/18/16 part out coming soon
jweller is offline
post #11 of 26 Old 12-30-2011, 09:48 PM Thread Starter
s10-4-life's Avatar
There was a few vacuum lines I changed alittle while ago....not sure if I got them all. could you send me pictures of the lines you changed?
post #12 of 26 Old 01-01-2012, 01:35 AM
basically look at your engine bay, and change every one you see.
I didn't fiddle with the EVAP stuff
jweller is offline
post #13 of 26 Old 01-10-2012, 12:36 AM
User is: Xtreme_03 is offline
This happened to me. I replaced my oem pcv valve with a frame which was a mistake. It rattled so horribly that it was all I could hear. I replaced it with a ac delco one and it was quite as ever. That's just what happened to me but it could be something.
2003 Xtreme- 4.3 & auto, dual e fans, w4m tune, throttle plate mod, cold air intake, msd 6A, dual exhaust
post #14 of 26 Old 01-10-2012, 12:38 AM
Sorry. I meant fram instead of frame.
post #15 of 26 Old 01-10-2012, 08:04 PM Thread Starter
s10-4-life's Avatar
Well My pcv valve was rattling like crazy for the longest time until I got back from a long road trip with my truck. I think if there is to much build up in the intake it will cause the pcv valve to make stupid noises because mine doesn't make any noise anymore and I didn't do anything to fix it. I think I burnt all the built up sh*t in my intake. We'll see if it starts making noise again and then I'll have to go out and order the ac delco one.
post #16 of 26 Old 01-10-2012, 08:09 PM
Registered Hoosier
Hoosier Rick's Avatar
Sometimes the hard plastic pcv hose is touching the vacuum hose to the brake booster. This transfers pcv noise into the cab. I have fixed several by repositioning the hoses away from each other.
2000 Jimmy 4x4 4dr. 252,000 miles
2002 rcsb, 2.2 at, 253,000 miles
1967 C10
post #17 of 26 Old 01-10-2012, 08:12 PM Thread Starter
s10-4-life's Avatar
Interesting! I may have to take a look at that.
post #18 of 26 Old 05-14-2016, 11:49 AM
User is: Cleatus is offline
yep--- mines doing this now...after putting in a replacement valve (autozone)
got another one from napa--looked and marked exactly the same-- same buzzing noise
Cleatus is offline
post #19 of 26 Old 05-14-2016, 03:17 PM
User is: SmokinDan is offline
Use OEM PCV valves only. Aftermarket are garbage.
post #20 of 26 Old 05-15-2016, 08:54 PM
Banned
User is: 2002_ZQ8 is offline
Could try a fixed orifice PCV valve from GM part# 12572717
2002_ZQ8 is offline
post #21 of 26 Old 05-17-2016, 06:01 PM
tried three different ones-- still buzzes--
you can pull valve cover side out and look in the bottom and see the little pieces just shaking round in there
the three all looked exactly alike--- GM, autozone, and napa
fu@#$$@ fail on quality
Cleatus is offline
post #22 of 26 Old 05-17-2016, 06:21 PM
Banned
Do you think the one above, with no moving parts, would buzz?
2002_ZQ8 is offline
post #23 of 26 Old 05-18-2016, 11:45 AM
probably not...if they made it anymore.
autozone has (supposedly) one similar, but they want 10$ shipping for the f-ing thing.
I said F-it and ran a long screw through one (of the three) I have -- locked that beotch in place, but still lets some air through
no more buzzing, and runs perfectly.
Cleatus is offline
post #24 of 26 Old 05-18-2016, 12:52 PM
Banned
2002_ZQ8 is offline
post #25 of 26 Old 05-18-2016, 05:42 PM
Originally Posted by 2002_ZQ8 View Post
plus $9.99 shipping...no
already have three of em, and if all it takes is a restricted one...I got that covered lol
Cleatus is offline
post #26 of 26 Old 05-18-2016, 09:19 PM
Banned
Says in stock at my store. If you really want something next time walk in the store, if they don't have it they will order it free shipping.
2002_ZQ8 is offline
