part number FAQ
LinkBack (4) Thread Tools
Old 06-09-2004, 01:31 AM   4 links from elsewhere to this Post. Click to view. #1
Diesel Fan
zerogravity58's Avatar
part number FAQ
im starting a thread for performance part numbers. i hope these help out. the web site is listed first then the part number so just go to that site and put in the number. if you see any other part numbers you would like added PM me the part number and the website from which it came from and i will post it. I know this is not a complete list of parts but i will add to it.
www.gmpartsdirect.coms
10224877 / crankshaft part number
10134359 / 18 degree cylinder heads,
10134394 / splayed valve bowtie heads,
12480009 / 18 degree cylinders head ,
24502523 CNC 18 degree racing heads.
10134351/ Aluminum block,
1013371 / Aluminum block,
10185051 / CNC bowtie block,
14011069 / Aluminum Bowtie block
25534333 / CNC cast iron engine block,
10205294 / stock Cast Iron Engine Block
10201166 / factory connecting rods.
10051125 / raised runner intake ,
10134325(intake gaskets to go with part # 10051125)
10134390 / 4BBL aluminum intake
10185004 / splayed valve head gaskets
14097284 / cast iron 4bbl intake
www.eaglerods.com
CRS570063D / eagle "ESP" H beam connecting rods
edelbrock.com
3713 / Performer 4.3L T.B.I. V6 (EGR)
2111 / Performer 90° V6 (non-EGR) 4bbl
2114 / Performer Vortec V6 (non-EGR) 4bbl
www.summitracing.com
all of the part numbers listed are from summits website. the cams are listed under their manufacturers website. if you go to the manufactures website you can get more info on these cams just leave off the "CCA", "CRN", "ERS", "EDL" and "ISK" since they only apply to summits website.
www.Compcams.com
CCA-09-410-8 / Comp Cams Hydraulic Roller, Advertised Duration 260/260, Lift .500/.500
CCA-09-412-8 / Comp Cams Hydraulic Roller, Advertised Duration 260/266, Lift .500/.500
CCA-09-415-8 / Comp Cams Hydraulic Roller, Advertised Duration 266/270, Lift .500/.500
CCA-09-420-8 / Comp Cams Hydraulic Roller, Advertised Duration 270/270, Lift .500/.500
CCA-09-422-8 / Comp Cams Hydraulic Roller, Advertised Duration 270/276, Lift .500/.510
CCA-09-430-8 / Comp Cams Hydraulic Roller, Advertised Duration 280/280, Lift .525/.525
CCA-09-1000 / Comp Cams Install Kit Hyd Roller Lifters Chevy 4.3 V6 W/ Balance Shaft
CCA-09-1001 / Comp Cams Install Kit Hyd Roller Lifters Chevy 4.3 W/O Balance Shaft
www.Cranecams.com
CRN-10530-12 / Crane Cams 1987-2000 4.3L hydraulic roller lifters
CRN-1439721 / Crane Cams Hydraulic Roller, Advertised Duration 276/284, Lift .488/.509
CRN-1439731 / Crane Cams Hydraulic Roller, Advertised Duration 284/292, Lift .509/.528
CRN-1439801 / Crane Cams Hydraulic Roller, Advertised Duration 250/260, Lift .407/.429
CRN-1439811 / Crane Cams Hydraulic Roller, Advertised Duration 260/276, Lift .429/.430
CRN-184211 / Crane Cams Hydraulic Roller, 1987-91 4.3L, 256/266 Advertised Duration, Compucam 2020
CRN-189721 / Crane Cams Hydraulic Roller, Advertised Duration 276/284, Lift .488/.509
CRN-189731 / Crane Cams Hydraulic Roller, Advertised Duration 284/292, Lift .509/.528
CRN-189811 / Crane Cams Hydraulic Roller, Advertised Duration 296/304, Lift .539/.558
ERS-E195501 / Erson Cams Hydraulic Roller, Advertised Duration 276/276, Lift .480/.480
ERS-E195502 / Erson Cams Hydraulic Roller, Advertised Duration 276/282, Lift .480/.480
ERS-E195503 / Erson Cams Hydraulic Roller, Advertised Duration 282/286, Lift .480/.510
ERS-E195504 / Erson Cams Hydraulic Roller, Advertised Duration 282/282, Lift .480/.480
www.iskycams.com
ISK-131252 / Isky Cams Hydraulic Roller, Advertised Duration 252/252, Lift .450/.450
ISK-131257 / Isky Cams Hydraulic Roller, Advertised Duration 257/257, Lift .465/.465
www.edelbrock.com
EDL-3714 / 1987-91 90 degree V6, hydraulic roller, 272 intake / 276 exhaust duration
MAA-4770001 / Distributor, Unilite, Vacuum Adv., 1985-1992 Chevy 4.3 V6, Socket Cap
EDL-6708 / Edelbrock headers, 1996-97 4.3L CPI S10/Sonoma pickup, 2WD only
EDL-6709 / Edelbrock headers, 1996-97 4.3L CPI S10/Sonoma pickup, 4WD only
EDL-6711 / Edelbrock headers, S10/S15 Sonoma 1996-97, 4.3L CPI Only, 2WD Standard Transmission
EDL-6715 / Edelbrock headers, 1998 4.3L CPI S10/Sonoma pickup, 2WD only
EDL-6834 / Edelbrock headers, 1988-95 4.3L TBI/CPI S10/S15/Sonoma pickup, 2WD only
EDL-6835 / Edelbrock headers, Blazer/Jimmy S10/S15 1988-95, 4.3L TBI/CPI, 2WD Standard Transmission
EDL-6836 / Edelbrock headers, 988-95 4.3L TBI/CPI S10/S15/Sonoma Blazer/Jimmy/pickup, 4WD only
EDL-6854 / Edelbrock headers, 1988-95 4.3L TBI S10/S15/Sonoma pickup, 2WD only, with automatic transmission
EDL-6855 / Edelbrock headers, 1988-95 4.3L TBI/CPI S10/S15 Blazer/Jimmy, 2WD only, automatic transmission
EDL-6856 / Edelbrock headers, 1988-95 4.3L TBI/CPI S10/S15/Sonoma Blazer/Jimmy/pickup, 4WD only, automatic transmission
JBA-1842-4 / JBA headers, 1996-2001 4.3L S10/Sonoma pickup/Blazer/Jimmy, 2WD
EDL-2111/ Edelbrock intake manifold 1985-95 4.3L, dual plane, cast aluminum, Performer
HLY-9901-301 / Holley Intake Manifold, 4.3L V6 for multi-point fuel injection idle-5500 RPM
AVM-21-8005C / AEM Brute Force Intake(Silver)
AVM-21-8005P/ AEM Brute Force Intake(Polished)
KNN-57-3009 / K&N FIPK (Fits CPI only)
KNN-57-3017-2 / K&N FIPK (96-04)
AID-200-133 / AIRAID intake
CLE-CB1358P / Connecting Rod Bearing Chevy V6 262cyl
CLE-CB1358P10 / Oversized, Connecting Rod Bearings Chevy V6 262cyl
CLE-CB1358P20 / Oversized, Connecting Rod Bearing Chevy V6 262cyl
FPP-2900 / FelPro Rear Main Bearing Seal
ARP-133-3607 / ARP Head Bolts, High Performance Hex, 90 degree w/ 18 Deg Std Port
STG-8911A / Stage 8 head bolts, 1979-2001 v6 engines
THESE PART NUMBERS WERE TAKE FROM THE LISTED SITES, USE THEM AT YOUR OWN RISK.
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f107/part-number-faq-114235/
Posted By For Type Date
Trying to learn about the GM 90 degree V6's - Corner-Carvers Forums This thread Refback 12-23-2007 08:39 AM
Trying to learn about the GM 90 degree V6's - Corner-Carvers Forums This thread Refback 12-10-2007 08:04 PM
help me with my 4.3 vortec - RICEKILLER.COM FORUMS This thread Refback 10-31-2007 08:54 PM
help me with my 4.3 vortec - RICEKILLER.COM FORUMS This thread Refback 07-09-2007 01:54 AM
