P0155 Code... - S-10 Forum
post #1 of 34 Old 08-20-2006, 07:57 PM Thread Starter
User is: 03flstfi is offline
P0155 Code...
This is a 2002 S10, 4.3 engine. Has about 60K miles, and otherwise runs OK.
P0155 ---> 02 Sensor Heater Circuit Malfunction (Bank 2, Sensor 1)
Now, what exactly does this mean?...
Thanks, in advance... Robert
03flstfi is offline
post #2 of 34 Old 08-20-2006, 08:29 PM
Searching no more
mat1583's Avatar
User is: mat1583 is offline
Send a message via AIM to mat1583
Re: P0155 Code...
Means you need to replace the 02 sensor...
Doin' it the right way
John 16:33
mat1583 is offline
post #3 of 34 Old 08-20-2006, 09:40 PM
User is: MadMikeZ28 is offline
Re: P0155 Code...
Bank 2=right hand side of motor
sensor 1=1st sensor
If I acted like some of the people here do and ran to someone when ever my feelings were hurt I would have been called a sissy and then ridiculed for that as well. I suppose I just grew up in a time when we were all tougher and turned out to be men and women instead of staying crying children.
post #4 of 34 Old 08-20-2006, 10:05 PM Thread Starter
Re: P0155 Code...
sensor 1=1st sensor
This part I knew...
My concern is if there is any other reason the PCM would set this code other than the 02 sensor heating element being bad.
03flstfi is offline
post #5 of 34 Old 08-21-2006, 01:04 AM
Searching no more
mat1583's Avatar
Re: P0155 Code...
Originally Posted by 03flstfi
This part I knew...
I'm sure the codes are specific for a reason (at least most are). Change that 02 sensor and let us know how it goes.
John 16:33
mat1583 is offline
post #6 of 34 Old 08-22-2006, 12:56 PM
Database guy
dooger's Avatar
User is: dooger is offline
Re: P0155 Code...
My SES light is on and I have that same code, my truck is an '03 with 50k miles, i was about to just order a new o2 sensor through autozone but the guy at pep boys is tryin to get me to spend $85 on some diagnostic test, he says that just because its throwing that code doesnt mean that the sensor is bad and that this test will tell you exactly what the problem is.
Anyone else have this problem?
dooger is offline
post #7 of 34 Old 08-23-2006, 12:18 AM
Re: P0155 Code...
The guy at pep boys is just trying to get your money. O2s' were out! You could replace more O2 sensors that oil pressure sensors because they wear out. And besides that I have heard very bad things about pep boys ripping off people with unnessary work. OBDII codes are somewhat specific. All your codes will tell you a specific part and always say also lead to the computer because that is whats controling or getting signals from parts. That guy may try to convince you it needs an ECM.
post #8 of 34 Old 08-23-2006, 02:44 AM
Database guy
dooger's Avatar
Re: P0155 Code...
Thanks for the feed back, I ordered a new sensor from summitracing
http://store.summitracing.com/partde...5&autoview=sku
I'll put it on this weekend and see how it works.
dooger is offline
post #9 of 34 Old 08-21-2008, 03:00 PM
User is: lemied07 is offline
Re: P0155 Code...
I am replacing the 02 sensor for Bank 2 sensor 1 on my 2003 ZR2, I noticed in the thead above that the sensor is on the right side of the motor, is that when you are laying under the truck with feet toward the bed?
lemied07 is offline
post #10 of 34 Old 08-21-2008, 04:38 PM
Registered (Ab) User
Yogi's Avatar
User is: Yogi is offline
Re: P0155 Code...
No. It is while you are seated in the driver's seat.
2008 Saturn Sky Red Line Roadster
2.0L LNF Turbocharged Motor
5 Speed Manual Trans.
Custom made Blazer CAI (Click Here)
Yogi is offline
post #11 of 34 Old 08-21-2008, 07:29 PM
Wire Splicin Fool :-)
lesterl's Avatar
User is: lesterl is offline
Re: P0155 Code...
Just because a code comes up DOESNT mean that the sensor is bad, a leaky fuel injector or one that doesnt open will cause bad running and sensor codes, bad grounds, bad PCM all can cause false codes, but the sensors do wear out and are usually suspect.
lesterl is offline
post #12 of 34 Old 08-21-2008, 07:30 PM
lesterl's Avatar
Re: P0155 Code...
Did you have to show off your Peter in here man? Griffin that is!
lesterl is offline
post #13 of 34 Old 01-30-2010, 02:31 PM
User is: ddrii03 is offline
Re: P0155 Code...
I need to replace the same sensor (Bank 2 Sensor 1) on my 2002 ZR2. For some reason I have only been able to locate 3 of the 4 O2 sensors on my truck. Can anyone help me with pic or advice on how to access this specific sensor.
ddrii03 is offline
post #14 of 34 Old 01-30-2010, 03:39 PM
lesterl's Avatar
Re: P0155 Code...
2 Pre cat, 1 Post cat IIRC.
lesterl is offline
post #15 of 34 Old 01-30-2010, 04:15 PM
4 wheels aren't as fun
serpentracer's Avatar
User is: serpentracer is offline
Re: P0155 Code...
if it says the heater went out in it..it went out.
02 sonoma 4.3L auto
97 sonoma 2.2L manual
post #16 of 34 Old 01-30-2010, 05:02 PM
that guy
LBD44's Avatar
User is: LBD44 is offline
Re: P0155 Code...
ok then answer me this im haven almost the same code but mines p0101 i think but i kno it did say bank 1 sensor 1 heater circuit malfuction ive replaced it twice now and same thing after bout 2 days the code pops back up but the last time i had the codes ran 2 days ago i also had a p0135 which said somethin bout the maf or vaf sensor so im thinkin somethin else has to b wrong
2001 s-10 pickup zr2 with 6 inch superlift on 33 mud brutes on 15 rock crawlers halo/projector head lights flowmaster exhaust custom intake and a hypertech programmer
LBD44 is offline
post #17 of 34 Old 01-30-2010, 07:37 PM
Re: P0155 Code...
yeah like the wiring maybe.
btw, P0101 is the MAF sensor. http://www.obd-codes.com/p0101(no wonder it keeps comming on if you replaced the o2 sensor...lol)
P0135 is the o2 sensor heater. http://www.obd-codes.com/p0135
02 sonoma 4.3L auto
post #18 of 34 Old 01-30-2010, 10:27 PM
that guy
LBD44's Avatar
Re: P0155 Code...
i forgot wat the numbers were its been a couple days but i do remeber wat they said was wrong lol
LBD44 is offline
post #19 of 34 Old 02-21-2011, 12:11 PM
bosoxfan82's Avatar
User is: bosoxfan82 is offline
Re: P0155 Code...
Im getting the same code on my truck, but the guys at the parts store arent able to tell me which sensor is bad. Is there a way to know without taking it to the dealer for a diagnostic?
post #20 of 34 Old 02-21-2011, 06:06 PM
terrible. take a lap.
joyride's Avatar
User is: joyride is offline
Send a message via AIM to joyride
Re: P0155 Code...
if you got the same code, then browse through the thread, they already said which 02 sensor it was...the guys at the parts store should be able to tell you too, unless they're just stupid or lazy...lol
Brian
01 xtreme 4.3L 5spd 2/3 drop w/ SS front bumper|.030 over|270 comp cam|500 lift|dual valve springs|10:1 C/R|p&p heads w/ 3 angle valve job|w4me tune|shorty headers|2.25 y pipe|no cat|Spintech muffler|windage tray|LW flywheel|DF clutch|8mm wires|no ac|efan|walbro 255|MPFI upgrade|Comp Cam timing chain|ARP bolts/studs|totaled***
Now owner of a white 2002 Blazer Xtreme
http://www.youtube.com/watch?v=CO_A1IrbQNM
85 Monte Carlo SS
KCCO
joyride is offline
post #21 of 34 Old 02-21-2011, 06:34 PM
far2grumpy's Avatar
User is: far2grumpy is offline
Re: P0155 Code...
P0155 indicates a problem with heater circuit of bank 2 sensor 1 (passengers side - before cat).
There's a remote chance the code could be caused by a bad fuse (02 15A fuse - under-hood box), by VCM/PCM, or bad ground wire, but you're pretty well assured replacing sensor will fix the problem.
post #22 of 34 Old 02-21-2011, 08:57 PM
zacharyh687's Avatar
User is: zacharyh687 is offline
Re: P0155 Code...
yup check your fuses and grounds first because there is always that remote chance that the only issue is a blown fuse or a bad ground.. totally agree there i have seen people change there o2 sensor only to find out the code still keeps coming back and the fuse was blown for the o2 sensor and they spent $50+ and it was just a fuse..
96 Chevy Blazer 4.3L HO 4L60E with 291,XXXmi and 14x,xxx on a reman 4.3.. Mods: 5000K 35W hid's, K&N drop in filter, Magnaflow high flow cat, MSD coil.
09 GMC Sierra 1500 X-Cab Short Bed 4.8L auto.
Mods. Magnaflow exhaust true duals.
5k hid. Undercover se tonneau cover. Afe dry flow air filter. Diablo sport predator.
future mods. Factory fog lights with hid. Billet front grille. And stereo system
post #23 of 34 Old 08-09-2011, 05:20 PM
gchalifoux's Avatar
User is: gchalifoux is offline
Re: P0155 Code...
Afternoon guys!
I need to get your advice on this post. I replaced the 02 sensor bank 2 sensor 1. Which if I am not mistaking is the pass side sensor BEFORE the cat.
After roughly 300 miles the ses went off....THEN CAME BACK ON the next day.
checked the sensor connections, but will double check.
your experience with return codes would be appreciated!!!!!
g
sensor 1=1st sensor
post #24 of 34 Old 08-09-2011, 07:14 PM
gchalifoux's Avatar
Re: P0155 Code...
also checked the fuses, all good there....
Originally Posted by gchalifoux View Post
Afternoon guys!
g
post #25 of 34 Old 08-10-2011, 03:17 AM
whitelowereddime's Avatar
User is: whitelowereddime is offline
Re: P0155 Code...
Same thing happened on mine and it was the maf sensor...
post #26 of 34 Old 12-13-2011, 11:50 AM
01_S10_4.3L's Avatar
User is: 01_S10_4.3L is offline
Re: P0155 Code...
Guys...just to be certain, because I saw two different responses in this thread....is a P0155 code for the O2 sensor closest to the exhaust manifold, or furthest away? TIA
2001 S-10 LS, Ext. Cab, 4.3L, 4L60E, 3.42
2011 Camaro SS 2SS/RS
6-Speed Manual
Victory Red w/White Rally Stripes
Flowmaster Outlaw Catback
C.A.I. Intake
post #27 of 34 Old 08-28-2012, 01:01 PM
User is: GlennSr is offline
Re: P0155 Code...
Hey guys, I have a 2004 S-10 ZR5 4x4. Had a code of P0155, changed O2 on passenger side. Then got a PO135 code, replaced drivers side O2. Was good for a day, now P0155 code is back. Checked voltage and have 12 volts at both sensors. Any help would be greatly appreciated.
GlennSr is offline
post #28 of 34 Old 11-18-2014, 11:30 AM
User is: joeg2268 is offline
Re: P0155 Code...
Hey guys.02 s10 4x4 4.3l had ap0155 bank 2 sensor 1 . I replaced the sensor.then the code returned.i erased code and disconnected the battery. then my temperature sensor went bad and I replaced it. then I get p0 155 again heater circuit malfunction bank 2 sensor 1. I replaced the sensor again and have the same code. Does anyone know how to check the heater circuit at the sensor do you know what voltage and which wire I should check any advice would be deeply appreciated. I have been told the pink wire is the heater circuit wire and the Black is a common ground but I don't know what voltage I should be looking for. truck is making me crazy please respond.tia.
joeg2268 is offline
post #29 of 34 Old 11-18-2014, 12:07 PM
burned's Avatar
User is: burned is offline
Re: P0155 Code...
The heater inside the oxygen sensor is controlled by two of the four wires that come out of it. One provides 12 Volts, and the other is the ground circuit that the PCM provides internally. So, when the heater is functioning correctly, these 12 Volts and ground are what get it to heat up.
Around 98% of the time, you can assume correctly (without any specific testing) that a new O2 sensor is in order and will solve the problem. In the other 2% of the cases, the oxygen sensor heater fuse has blown because the O2 sensor's wires have shorted and melted together (usually because they've come into contact with the exhaust pipe).
2002 Dakota, QC 4x4, 4.7L HO Intake.
1997 S10 ZR2, Ext Cab, 5 Speed (SOLD)
How to test fuel pressure and leak down <---diagnostic help
burned is offline
post #30 of 34 Old 11-21-2014, 02:31 PM
User is: s10fan262 is offline
Re: P0155 Code...
i have this same code on my 02 s10 4.3....changed correct 02 sensor 2 times and still throwin code...anyone solve this prob ? fuses look ok also
post #31 of 34 Old 11-22-2014, 12:23 AM
burned's Avatar
Re: P0155 Code...
Did you read what I wrote? The sensor requires 12v and ground.
burned is offline
post #32 of 34 Old 11-22-2014, 12:48 AM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
User is: 1fast4by is offline
Send a message via AIM to 1fast4by
Re: P0155 Code...
...so much dumb
Check Key on power to heat circuit, if no power check fuse, if power present check ground side....Electricity is f*cking simple. Diagnostics are easy.
...and quit using Autozone parts you dumb bastards
"The police cannot protect the citizen at this stage of our development, and they cannot even protect themselves in many cases. It is up to the private citizen to protect himself and his family, this is not only acceptable, but mandatory."
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #33 of 34 Old 12-17-2014, 08:55 PM
User is: Gladstone is offline
Red face Re: P0155 Code...
Don't do a wrong-site-surgery. That's is when a surgeon has to remove a kidney or leg and they cut off the wrong one. Right and left is always from the driver sitting in the driver seat.
or
post #34 of 34 Old 12-17-2014, 11:56 PM
Registered Hoosier
Hoosier Rick's Avatar
Re: P0155 Code...
Originally Posted by 03flstfi View Post
This part I knew...
If you do not have power and or ground to the heater, it would set the same code. It is usually a burned out heater, but I have been fooled before.
2000 Jimmy 4x4 4dr. 252,000 miles
2002 rcsb, 2.2 at, 253,000 miles
1967 C10
