P0140 trouble code remains. New sensor WTF? - S-10 Forum
post #1 of 42 Old 08-18-2008, 03:22 AM Thread Starter
Awww..you ain't got shit!
jimmykicker's Avatar
Question P0140 trouble code remains. New sensor WTF?
Hey guys. I have a 2001 S-10 4.3 that has a P0140 oxygen sensor code showing. I need to make sure I am right on a couple of things.
There are only two oxygen sensors on this truck? One is on the driver's side which is bank 2 sensor 1 and the other is at the converter which is bank 1 sensor 2 correct?
What is confusing the crap out of me is that last year I replaced the one at the converter for the second time at about 100K. The light would continue to come back on after the repair which was the only code showing (P0140 No activity at O2 sensor). I couldn't figure it out and I just left it on. I checked it again a couple of days ago and it was then showing a code for both sensors then as well as one for the MaF sensor. I figured the new one I put in last year might have been defective and replaced both sensors Friday. I drove about 35 miles and the light came back on and this time only for the MAF sensor AND the stinking P0140 for the converter sensor at the converter and the manifold one did not return. The MAF isn't what I am really worried about right now, but the P0140 code is really pissing me off now since I am sure the sensor is good (and so was the one I took out). I found a service bulletin for my truck (020604011) for this P0140 code. Does anybody have any info if this related to my truck?
I am going to check to make sure there isn't a bad wire, but I doubt that is the problem.
Thanks!!!!
1984 xcab s-10 3.4L GM crate engine 87 S10 TBI swap w bored intake, Edelbrock headers. 3.42 locker rear end swap. Flowmaster, shift kit, e-fan.
EFI swap http://www.s10forum.com/forum/f106/c...e-help-513616/
My build thread (3.4L)http://www.s10forum.com/forum/f106/b...stions-427168/
I had to cut my nut in half .
post #2 of 42 Old 08-18-2008, 03:41 PM
Registered (Ab) User
Yogi's Avatar
User is: Yogi is offline
Re: P0140 trouble code remains. New sensor WTF?
The code is as follows:
  • P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
AFAIK, your truck does not have a sensor at bank 1 sensor 2. I could be wrong, but from what I have seen the O2 after the cat is Bank 2 sensor 2, and sometimes Bank 2 Sensor 3.
Were you able to find the service bulletin?
2008 Saturn Sky Red Line Roadster
2.0L LNF Turbocharged Motor
5 Speed Manual Trans.
Custom made Blazer CAI (Click Here)
Yogi is offline
post #3 of 42 Old 08-18-2008, 03:56 PM
Yogi's Avatar
Looks like it has something to do with the Ignition Control Module. I would get the ICM tested at your favorite auto parts store.
http://209.85.141.104/search?q=cache:51Qlc_OKFwgJ:www.edmunds.com/maintenance/recalltsb.do%3Fstep%3Dtsb%26year%3D2002%26make%3DG MC%26model%3DSonoma%26style%3D2dr%2BRegular%2BCab% 2BSL%2B2WD%2BSB%2B(2.2L%2B4cyl%2B5M)+NHTSA+ITEM+NU MBER+-+634710+chev+4.3&hl=en&ct=clnk&cd=1&gl=us
BTW, you should have 3 O2 sensors:
Bank 1 #1
Bank 2 #1
Bank2 #2
And sometimes Bank 2 #3 (this would be for 4 sensors)
Yogi is offline
post #4 of 42 Old 08-18-2008, 08:21 PM Thread Starter
Okay, if there are 3 sensors where are they located? I replaced one on the driver's side right below the manifold, and one right behind the converter, so where is the mystery #3 (I haven't looked that hard). Anybody got a picture? I have been told by numerous people that the truck has 4 sensors, but I have not seen but two. Websites say "two required". Is this two required on each bank or a total of two? Am I crazy?? The truck runs fine since I replaced the one in the pipe below the manifold, and I just drove it 620 miles since Friday without issue.
BTW, I saw the bulletin, but it wasn't very helpful as to the whats or whys. Thanks for the help guys.
-j
Last edited by jimmykicker; 08-18-2008 at 08:30 PM. Reason: δ╝‼B◄╞*S╕é╨*ε│\Üûá╝≥Ω_╚¼¼₧☼·Éé
post #5 of 42 Old 08-18-2008, 11:35 PM
goin broke but n style
S15vortecpwr's Avatar
you ahould have one sensor on the pass side in the same location as the drivers. and one after the cat.
the ecm reads the front (lt&rt sensor) for your rich lean mixture and the one after the cat for cat effiency. you will have 4 o2s if your truck is equipt with 2 cats, one for each bank
MAF can also cause 02 sensor faults due to a comparison factor the ecm uses. try cleaning your maf and see what happens, also remove both battery cables and touch them together for about 15-20 minutes. This will disapate all the capacitors in teh ecm and make it relearn the sensors.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #6 of 42 Old 08-19-2008, 06:06 AM Thread Starter
Okay, the truck also reports a MAF code P0101. Is this what you are talking about? The one for the o2 sensor comes up first every time.
tnx...james
post #7 of 42 Old 08-19-2008, 01:53 PM
User is: BlazerH/O is offline
Get some MAF cleaner from autoparts store and clean the MAF. Your converter if stock may be going or already is bad. Try using a bottle of Chevron Techron in the next couple fillups. I sued the Techron in a 96' Camry with 220k miles on it that was throwing a P0420 'Bad Cat' and Bad O2 sensor codes. After 2 fillups with the Techron with Shell gas, the Check engine lights went away and so did the codes. Techron is the only additive proven to actually clean these compnents in a vehicle! Trust me, I know Exon/Mobil Engineers that use this stuff in their test engines to keep data fair and accurate!
'05' Blazer 5-Spd w/3.42 8.5" rear & 39k original miles
Michelin LTXs w/Schrader nickel-plated stems
Magnaflow Cat-back w/2.5" Mandrel Piping
K&N CAI 63 Series w/K&N dryflow wrap
Wait4Me Tuned for 93 Octane
Maxlife Blend 5W30
post #8 of 42 Old 08-19-2008, 02:04 PM
Yogi's Avatar
tnx...james
You can try cleaning the MAF but it may be a bad MAF and need to be replaced. Click here for more info.
You definitely need to get it running right without the P0101 code. That's bad.
Yogi is offline
post #9 of 42 Old 08-20-2008, 12:31 AM Thread Starter
Wink Re: P0140 trouble code remains. New sensor WTF?
Well, I took the MAF out and cleaned it. It didn't really appear dirty, but who knows and I also replaced the last oxygen sensor (it was turned towards the front of the truck, which is why I didn't see it). The code hasn't come back, but I have only drove it a short distance.
I got some bad gasoline in this truck back in 2004, which destroyed the fuel pump and I have had recurring problems since the repair. Hopefully this will fix it.
Keep you posted. Thanks again guys!
James
post #10 of 42 Old 08-20-2008, 04:33 AM Thread Starter
Sh*t! The P0140 code (pending) is back, so I am sure that the SES light will probably come back on tommorow. We'll see if the P0101 code comes back too. Do you guys think it's the MAF sensor causing the O2 code? There are now 3 new O2 sensors in the truck, so I shouldn't be getting the code. Anybody think the converter might be causing the problem? The truck has 118K.
James
post #11 of 42 Old 08-20-2008, 04:34 AM Thread Starter
James
post #12 of 42 Old 08-20-2008, 05:29 AM
briceman
User is: briceman1299 is offline
Send a message via MSN to briceman1299 Send a message via Yahoo to briceman1299
my truck had no power and was throwing the P0101 code, took the catalytic converter and mini converter out, put a "test tube" in and she runs better then new... louder then it should be though, ha ha
post #13 of 42 Old 08-20-2008, 12:33 PM
Yogi's Avatar
James
The P0140 is a false code. You have no sensor at bank 2 #2, so don't worry about your O2s.
Get your ICM (Ignition Control Module) checked.
Can you post up the info in that bulletin? That might help.
Not likely that the cat is causing the problem either.
Yogi is offline
post #14 of 42 Old 08-20-2008, 02:19 PM
Banned
User is: 4x4zr2GA is offline
Send a message via AIM to 4x4zr2GA
yeah you have 3 oxy. sensors. i had a oxygen sensor code for 3 freggin years... couldnt get rid of it, replaced all 3 numerous times thinking i kept getting bad ones... well recently i got another code, it was for the coolant temp sensor... so i went to check it and all the plastic on the connector was broke off and just hanging on to the plug by the metal prongs... fixed that and my oxygen sensor code went away for good.... other things can affect the oxygen sensors, especially the MAF.
4x4zr2GA is offline
post #15 of 42 Old 08-20-2008, 02:22 PM
US Beer Drinking Team
hamagc's Avatar
User is: hamagc is offline
Send a message via Yahoo to hamagc
i believe this is the code my truck is throwing right now too. figured it was jsut the sensor. doesn't this sensor have 2 functions? tells you either the sensor is bad or the cat is bad?
Joshie
5linked and laying frame on a daily driver.
http://www.cardomain.com/ride/2557504
I need 1 18" Panther Juice
hamagc is offline
post #16 of 42 Old 08-20-2008, 05:39 PM
hamagc's Avatar
lol so i go home for lunch, come back out to goto work, turn the truck on and the code is gone. no more ses light. go figure. it likes to go on and off on me lol.
Joshie
hamagc is offline
post #17 of 42 Old 08-20-2008, 06:29 PM
Yogi's Avatar
Normally, yes, but this code does not apply to a 4.3 because there is no sensor at that location, so the code is bogus. If you are getting that same code (P0140) and you have a 4.3, it is bogus. There is another problem somewhere else.
Yogi is offline
post #18 of 42 Old 08-20-2008, 06:37 PM
hamagc's Avatar
really? this i did notk now. how can you diagnose this issue? mine comes and goes and without the code being right how can you really tell what the issue is? exp. when it goes away lol
Joshie
hamagc is offline
post #19 of 42 Old 08-20-2008, 06:51 PM
Yogi's Avatar
You need to start a new thread. Also try to get TSB# 020604011.
Yogi is offline
post #20 of 42 Old 08-20-2008, 07:15 PM
Wire Splicin Fool :-)
lesterl's Avatar
User is: lesterl is offline
The trucks with 2 cats will have 4 sensors, the trucks with 1 big cat will have 3 sensors.
lesterl is offline
post #21 of 42 Old 08-20-2008, 07:40 PM
Yogi's Avatar
Yes, but the extra sensors are on bank 2, not bank 1.
Yogi is offline
post #22 of 42 Old 08-20-2008, 07:46 PM
lesterl's Avatar
Bank 1 Pre Cat, Bank 2 Post Cat?
lesterl is offline
post #23 of 42 Old 08-20-2008, 07:49 PM
Yogi's Avatar
AFAIK, You have Bank2 sensor 1 at the exh. man. outlet. Bank 2 sensor 2 at the first cat outlet, Bank 2 sensor 3 at the second cat outlet. Nothing but sensor 1 on bank 1.
Yogi is offline
post #24 of 42 Old 08-20-2008, 08:18 PM Thread Starter
Okay, I had a code for the thermostat when I first checked it although it has failed to return. I recently changed the coolant at 100k and got that awful Dexcool stop-up-your-everything-related-to-cooling-mess and replaced it with the green stuff and noticed it running quite a bit cooler. However, I was having this o2 mess way before I did that, so I don't think it is related. THe MAF code hasn't come back yet since I cleaned it, but the day is young.
james
post #25 of 42 Old 08-22-2008, 06:00 PM Thread Starter
Update, the MAF sensor code is gone...I think for good since the cleaning. However, the 0140 code keeps coming back. Since the truck has no sensor for bank 1 sensor 2, somebody said it might be the ignition module. I saw the bulletin for this, but it was for cavaliers. Any info? The truck runs fine, and I would hate to buy a new module if I don't need it.
james
post #26 of 42 Old 08-31-2008, 08:01 PM Thread Starter
james
I am about to lose my fricking mind!!!
I just replaced the ignition module, drove about 20 miles, and there is a pending code for guess what??? P0140, which means the light will come on before too much longer! This is what I have done since I got started
  • Cleaned MAF sensor (eliminated P0101)
  • Replaced all three O2 sensors (Fixed code for bank 1 sensor 1 and Bank 2 sensor 2)
  • Replaced thermostat (Eliminated the P0128 code)
  • New rotary button and cleaned cap (runs better)
  • Replaced ignition module (which did nothing but eat $70)
Anybody have any more suggestions about what might cause this? It's really pissing me off because the truck runs pretty good now!
post #27 of 42 Old 08-31-2008, 11:32 PM
lesterl's Avatar
Have you disconnected the battery and reset the PCM?
lesterl is offline
post #28 of 42 Old 09-01-2008, 12:14 AM
MikDee's Avatar
User is: MikDee is offline
All I know is I had 4 sensors on my 96' Sonoma Vortec 4.3 V6, and from what I read, they all have 4 sensors after 96', One on each bank (left, & right downpipe), and one just before the Cat (that controls mixture with the computer) bank 1, sensor 2 Code #140! This was the one I had to replace to make my truck run good when I first got it, then clear the code, it never came back! And finally one after the Cat.
95' S-10 Teal/Silver Ext Cab 4.3 V6 Auto 2WD
Early sound clip of a Speed FX (Flow 40 Clone)
on my previous 96' Sonoma (wrecked)http://www.youtube.com/watch?v=5-yGUO3_zLQ
Cars, & Trucks, I've owned, wrenched on, & modded
http://smg.photobucket.com/albums/v2...lassic%20Cars/
MikDee is offline
post #29 of 42 Old 09-01-2008, 02:23 AM Thread Starter
I just got under the truck and looked again to make sure I wasn't losing my mind. There is one in the driver side pipe (bank 1 sensor 1), one in the pass side (bank 2 sensor 1) and one right behind the converter. I looked all over that pipe for one in front of the converter, but I couldn't find one.
I also read in my Haynes manual it confirms there are three. One on each pipe and one after the converter.
Interestingly, parts places say there are 2 required for each bank, so whaaatt???
post #30 of 42 Old 09-01-2008, 04:48 AM
hamagc's Avatar
have you tried cleaning the injectors really good?
Joshie
hamagc is offline
post #31 of 42 Old 09-01-2008, 06:35 AM
ZQ8 Blazer's Avatar
User is: ZQ8 Blazer is offline
When I put a Magnaflow converter on mine I kept throwing a code and I bought a spacer, installed them after the cat on the pipe then installed the O2, haven't had a problem since. The reason mine was throwing a code was because the new cat was hi-flow and it was tripping the sensor, maybe your new one isn't to factory specs maybe?
I think the part is called a spark plug anti-foul or something like that, here's a pic:
ℐustin
post #32 of 42 Old 09-01-2008, 09:11 AM
MikDee's Avatar
Normally, next in sucession you would have (bank 1 sensor 2) and (bank 1 sensor 3) before, & after the converter, 4 sensors. Best I can figure, is there might have been changes made after 96' on the later model trucks like yours, and it only has 3? I would suspect then maybe the extra converter replaces one sensor, because I only had one converter on my truck, and I know the newer models had a small precat.
MikDee is offline
post #33 of 42 Old 09-01-2008, 10:24 AM
Yogi's Avatar
No, Mik. There is only one sensor on Bank 1 - it's sensor 1 and ONLY sensor 1. There is NO sensor 2 on Bank 1, and NO sensor 3 on bank 1. Sensors 2 & 3 are on Bank 2!
Yogi is offline
post #34 of 42 Old 09-01-2008, 10:33 AM
Yogi's Avatar
[quote=Yogi;5504169]Looks like it has something to do with the Ignition Control Module. I would get the ICM tested at your favorite auto parts store.
I said tested, not replaced.
Yogi is offline
post #35 of 42 Old 09-01-2008, 10:59 AM
lesterl's Avatar
MikDee, why would they put 3 sensors before the cat since there are only 2 manifolds feeding it (unless you have to separate cats, then you would have 2 before and 2 after), mine has 2 before 1 after (the one after is only to compare to what was going into the cat to check its performance and tattle on you.
lesterl is offline
post #36 of 42 Old 09-01-2008, 12:36 PM
Yogi's Avatar
Some have 2 cats and they put one extra O2 between that 2 cats.
Yogi is offline
post #37 of 42 Old 09-01-2008, 07:41 PM
MikDee's Avatar
To All you naysayers! My 96' Sonoma had four sensors! one on each downpipe, one before, and one after, the Cat! Look it up yourself if you don't believe me
Originally posted by O4 Extreme
"Re: 02 sensors location
Quote: Originally Posted by adobo My truck has 3 b4 the cats...one on each exhaust manifold then one on the header
on the newer trucks, bank 1 sensor 1 is drivers side closest to the manifold, bankj 2 sensor 1 is pass side closest to the manifold, bank 1 sensor 2 is the one before the cat, bank 1 sensor 3 is the one after the cat"
Here's the link where it's from: http://www.s10forum.com/forum/f107/0...cation-228016/
MikDee is offline
post #38 of 42 Old 02-07-2010, 04:36 PM
User is: harry_411 is offline
What???? No reply!!!
post #39 of 42 Old 03-05-2015, 02:51 PM
missileman's Avatar
User is: missileman is offline
Hi
MikDee
You are correct I have a 1996 S104x4 ZR2 4.3 and it has 4 sensors like you say.
Lately I have experienced a PO140 problem,I cleaned the connectors Erase the code and get a couple road trips and it's comes back on.Am I correct to say the PO140 sensor is the one in the pipe in front of the converter.I noticed on my OB2 reader that the voltage only gets to .4volts.I checked the other 3 sensors and they usually get up to .7 volts etc.Do you think the sensor is getting tired.also a O2 Hester problem would drag the voltage down would it.
post #40 of 42 Old 03-05-2015, 07:29 PM
burned's Avatar
User is: burned is offline
Originally Posted by missileman View Post
Hi
MikDee
Did you check the date of the post????
Replace the sensor if its bugging you. Its the pre cat sensor, so it has no effect on gas mileage.
2002 Dakota, QC 4x4, 4.7L HO Intake.
1997 S10 ZR2, Ext Cab, 5 Speed (SOLD)
How to test fuel pressure and leak down <---diagnostic help
burned is offline
post #41 of 42 Old 03-09-2015, 11:44 AM
missileman's Avatar
Replace the sensor if its bugging you. It's the pre cat sensor, so it has no effect on gas mileage.
Thanks for the response,I saw where the post was a little old,but didn't want to start another thread on the same subject.I have cleaned the sensor connector several times, it last for awhile and returns mostly when on wet roads,which lead me to believe it's water getting into the connector resulting in no activity.Can you confirm that the sensor, bank 1 sensor
2 in front of the Cat. is the one setting the the PO140 Code.
thank you
post #42 of 42 Old 03-09-2015, 01:31 PM
burned's Avatar
thank you
Confirm???
That code is specific to that sensor. If it was another O2 sensor it would be a different code
burned is offline
