overflow reservior won't drain back into radiator - S-10 Forum
post #1 of 22 Old 05-15-2008, 11:11 AM Thread Starter
Navy Seabee
SD44's Avatar
User is: SD44 is offline
I've been having a mild overheating problem the past couple weeks. What will happen is.....everything will be fine for a couple days, then it'll try to heat on me (210-220 degrees) alittle. I'll let it completely cool down, and check the radiator to find out it's low. I'll fill it back up, everything will be fine for a few days, then the same cycle again.
This happened yesterday. The day before, I had flushed the whole system and put new antifreeze in. I have a 40 mile trip home from work; everything was fine driving to work and going to lunch. On the way home, after about 30 miles, the temp started slowly climbing to the 210-220 range. I got home, raised the hood,but didn't attempt to open the radiator. But I checked the reservoir and it was completely full of my new antifreeze. I waited about 3-4 more hours and let it completely cool, so that antifreeze would go back into the radiator. Not a drop had drained back in.
There are two hoses on the reservoir; a hose from the radiator neck to the bottom of the reservoir, and a hose from the top/side of the reservoir that drains out underneath the truck. I took the cap off the radiator, pulled the reservoir drain hose out from the bottom, and literally blew into it with my mouth and slowly blew the antifreeze back into my radiator through the neck until it filled back up. So that tells me my antifreeze isn't leaking out anywhere.
What the hell is making the overflow not drain back into the radiator???
1995 regular cab S-10 2WD
4.3 TBI, 5 speed, 360,000 + miles!
SD44 is offline
post #2 of 22 Old 05-15-2008, 11:44 AM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
Re: overflow reservior won't drain back into radiator
The cap.
Teamsters Local 1150
SH-60B is offline
post #3 of 22 Old 05-15-2008, 11:46 AM
Registered (Ab) User
Yogi's Avatar
User is: Yogi is offline
A bad radiator cap. The gasket around the neck flange is leaking air back into the radiator so you don't have any suction to suck the coolant back in when it cools off.
2008 Saturn Sky Red Line Roadster
2.0L LNF Turbocharged Motor
5 Speed Manual Trans.
Custom made Blazer CAI (Click Here)
Yogi is offline
post #4 of 22 Old 05-15-2008, 11:47 AM Thread Starter
Navy Seabee
SD44's Avatar
lol, could i be so lucky that it's something that simple and cheap?
SD44 is offline
post #5 of 22 Old 05-15-2008, 11:54 AM
Yogi's Avatar
Well, you've got 2 votes here that say it is.
Yogi is offline
post #6 of 22 Old 05-15-2008, 01:07 PM
Hey kids!
raider600's Avatar
User is: raider600 is offline
Send a message via AIM to raider600
its draining into your motor! OH NOES!
Cory.
05 Subaru TURBOOOOOOOOOOOOO
post #7 of 22 Old 05-15-2008, 02:31 PM
User is: MikeInCtown is offline
Bad radiator cap or sealing surface like the others have said.
post #8 of 22 Old 05-15-2008, 02:53 PM Thread Starter
Navy Seabee
SD44's Avatar
Nah, no water in the oil or coming out the exhaust.
I bought a new cap during lunch, but man my old one sure looks good and is still strong. Got a feeling it's not the cap.
SD44 is offline
post #9 of 22 Old 05-15-2008, 10:47 PM
Nice Jorb
cavymeister's Avatar
User is: cavymeister is offline
Send a message via AIM to cavymeister
Cap.
Learned that lesson when I was 17. Popped a head gasket cause of that.
Originally Posted by Shaw
"The problem with her is that she lacks the power of conversation, but not the power of speech.."
post #10 of 22 Old 05-16-2008, 10:27 AM Thread Starter
Navy Seabee
SD44's Avatar
Well it's the waterpump.
Got home and let it cool down, then topped the radiator off and got the temp back up. Some of you may have seen my other thread about having a pulley somewhere making a screeching noise, that's the waterpump too. I put the new cap on, yet was still low of water when i finally got home. After looking the topside over real good, I pulled it up on some ramps and looked at the bottom. There is actually a trail that has been washed clean from the diaphram hole in the bottom of the waterpump, down the water pump and dripping on the harmonic balancer. It's a slow weep, not pouring. It actually doesn't leak at all while running, but it starts a couple minutes after shutting it off. I guess it's from the pressure buildup. I shut it off and got back under the truck, and watched it weep, drop after drop, from the diaphram hole onto the harmonic balancer.
Mine is a 95' TBI. Looking closely from the frontside, it really doesn't appear that I'll need to take the alternator or AC loose to get the pump off. I know I'll have to remove the top of the shroud and the fan, obviously. Have any of you changed a pump that's the same setup as mine? What all did you have to take off?
SD44 is offline
post #11 of 22 Old 05-16-2008, 11:20 AM
Bill Wheats's Avatar
User is: Bill Wheats is offline
Disconnect the neg of the battery
Remove the belt
Losen the alternator and slide it out of the way
Pull the shroud as necessary
Get some carboard to cover the radiator fins
Drain the coolant...
Pull the fan and hoses, might be a good time to replace some...
Other than that. I'm no help!
Good luck
post #12 of 22 Old 05-16-2008, 12:04 PM
Yogi's Avatar
Glad that you found the problem! Good luck with the repairs!
Yogi is offline
post #13 of 22 Old 05-16-2008, 12:24 PM Thread Starter
Navy Seabee
SD44's Avatar
Wanna come over and help?
SD44 is offline
post #14 of 22 Old 05-16-2008, 12:39 PM
Ya! Sure! That's what Friday nights are all about.... Changing some one else's water pump!
I would, but I'm trying to avoid lieing to my better half and the only thing she would buy is that I'm out boozing it up with the guys down at the local pickup joint.
Good luck
post #15 of 22 Old 05-16-2008, 12:40 PM
Yogi's Avatar
I'm a real good supervisor!
Where are you located?
Yogi is offline
post #16 of 22 Old 05-16-2008, 12:40 PM
xtremefour
xtremefour's Avatar
User is: xtremefour is offline
I was having the same problems a few weeks ago and found out that it was that same thing for me. Bad cap and would not suck from the overflow tank. Put on a new cap and then all of a sudden the water pump started gushing out antifreeze.
Fixed the water pump and now my truck runs great. Two weeks ago I wanted toget rid of it, now I love my truck again lol
Matt
Matt-2000 S10 X 2.2 5-speed, 16X8 Eagles, Autometer Gauges, Cowl Induction Hood, 20"X32" Sunroof, M3 Mirrors, Type X Racing Seats,12gal tank,2 450 chrome comps, 4 3/8 fills 4 3/8 dumps, 1/2 line, switch box, cool ride in front, air bar 3-link in the rear, molded in 9" LCD screen into the dash and DVD player under the dash, full tweed interior, shaved gate, 1 off bumper.
post #17 of 22 Old 05-16-2008, 01:08 PM Thread Starter
Navy Seabee
SD44's Avatar
Matt
That's why I can't make myself get rid of it. 234,000 miles and still getting around 23 mpg. Drives me nuts the occasional little nit-pick stuff like this that happens a couple times a year, but for the most part you can repair and service these trucks yourself pretty cheaply. The water pump at the Autozone here is only $19.99.
SD44 is offline
post #18 of 22 Old 05-16-2008, 01:33 PM
LB_COOL_J
LowBravada's Avatar
User is: LowBravada is offline
I wouldn't recomend a reman water pump. I know 3 people first hand that used them, and within 2 years replaced it again for the same reason. I would suggest a new one unless you plan on getting rid of it soon
Bryan
<TubbD> I <3 the black dildo
[/center]
<Zapnoma> then yes, i suck so much black dick, it comes out my ears
post #19 of 22 Old 05-16-2008, 01:39 PM
Yogi's Avatar
Have you ever seen what is involved with replacing a water pump on a Honda? You have to take the timing belt off the camshaft to get to it! And I think that the pump alone costs $85 too!
There's a lot of advantages to this "Old Iron" that we own!
Yogi is offline
post #20 of 22 Old 05-16-2008, 01:48 PM
A water pump is a simple piece of iron, a bearing or two and a seal. There really is no reason to buy new if you buy a pump from a reputable source/manufacturer.
Oh, and at some point that "new" unit screwed up, so how good are they really if you find a need to replace it?
post #21 of 22 Old 05-27-2008, 11:11 AM Thread Starter
Navy Seabee
SD44's Avatar
This ended up being a MUCH easier job than I expected. I didn't even need a swivel joint to get to the water pump bolts. I took off the shroud, radiator, fan, and pulley, then just removed the 4 water pump bolts. I had to remove the fan bolts, but they actually screwed out with just a pair of pliers. The hardest part of the job was getting the heater hose fitting out of the old pump; I had to have someone stand on the pump while I used a wrench and a cheater bar to break it loose.
Did the whole job in about an hour.
SD44 is offline
post #22 of 22 Old 05-27-2008, 11:21 AM
Yogi's Avatar
Congrats!!
Yogi is offline
