oil pressure switch - S-10 Forum
post #1 of 17 Old 09-24-2008, 11:47 PM Thread Starter
ddg1025's Avatar
User is: ddg1025 is offline
oil pressure switch
sorry i know this has been on here before but from the search I could not find the location for my mine. i have an 88 S10 4.3TBI and im am just wondering where the oil pressure switch/sensor is on it?
ddg1025 is offline
post #2 of 17 Old 09-24-2008, 11:50 PM
Works too much!
laydout97's Avatar
User is: laydout97 is offline
Re: oil pressure switch
It's right beside the dizzy on the drivers side. It has three wires going into it. I think the colors are orange, grey, and balck.s
92 4.3/700r4 315k- ole red
2011 altima- daily ride
post #3 of 17 Old 09-25-2008, 12:01 AM Thread Starter
ddg1025's Avatar
i thought that was it, its like right behind the egr valve
ddg1025 is offline
post #4 of 17 Old 09-25-2008, 12:14 AM
Works too much!
laydout97's Avatar
yup
post #5 of 17 Old 09-25-2008, 10:03 PM Thread Starter
ddg1025's Avatar
well i put the new switch in, it was hard to find a socket to take it out I went everywhere looking for one and never found the right one. I ended up breaking the old switch so I could get to the nut. The reason I replaced it was because it was causing the "check gauges" light to turn on and off repeatedly when idling. It was also causing the relay under the hood to do the same thing. it has always read around 0 on the gauge when idling and goes up a little above 40 when rpms increase. with the new pressure switch it reads the same thing. just wondering what your guys gauges normally read when idling? I believe it is normal for it to be that low when idling just want to see if your trucks the same.
ddg1025 is offline
post #6 of 17 Old 09-25-2008, 10:13 PM
Works too much!
laydout97's Avatar
Mine idles around 35 to 40 and 55 to 60 driving.
post #7 of 17 Old 09-25-2008, 10:28 PM
Boards don't hit back
00s104.3's Avatar
User is: 00s104.3 is offline
I had the same trouble with my '89 blazer. The gauge would drop to zero and the "check gauges" light would come on while idling. I replaced the switch and the oil pressure is still low but not all the way to zero. I just keep an eye on it now. It sits around 17-18 psi at idle and then goes up to around 40-45 psi while cruising.
By the time you realize this doesn't say anything it's too late for you to stop reading it.
00s104.3 is offline
post #8 of 17 Old 09-25-2008, 10:36 PM
NTL1991's Avatar
User is: NTL1991 is offline
Mine idles at 40 and can get up to 80 at times (especially during the cold morning take offs) but usually doesn't go above 60 when driving around with a warm engine. I use only Mobile 1 5W30.
Nick
1997 Oldsmobile Bravada SmarTrac
4.3L V6 W-VIN w/ 145,000. Automatic Transmission.
Factory 3.73 PosiTrac; Z85 Suspension
NTL1991 is offline
post #9 of 17 Old 09-25-2008, 11:17 PM
94 s10 in progress
FxsX24's Avatar
User is: FxsX24 is offline
http://buy1.snapon.com/catalog/item....re&dir=catalog
1999 SAAB 9-3 SE
1994 S-10 PROJECT TRUCK 283 TBI V8
2007 YAMAHA NYTRO
Originally Posted by 2002redSdime View Post
only the most hardcore minitruckers are from canada, cuz even their milk is bagged!!
FxsX24 is offline
post #10 of 17 Old 09-26-2008, 12:02 AM Thread Starter
ddg1025's Avatar
i bought pretty much the same socket at autozone and it only worked for the new sensor that i got there. the old switch that was in my truck was a bigger size 30mm a little bigger than an 1 1/8". and the oil pressure switch socket was for 1 1/16" and 1".
about the trucks oil pressure it has always been around zero on the gauge when idling and it runs fine. im thinkin that maybe the gauge on the instrument panel might be broken since it does the same thing with the new oil pressure switch.
i use to have an 88 2.8 blazer and the oil pressure gauge on it would also read around zero when idling and it always ran fine
ddg1025 is offline
post #11 of 17 Old 09-27-2008, 11:38 AM
Registered (Ab) User
Yogi's Avatar
User is: Yogi is offline
And I thought that mine was low!
Mine runs about 18 psi at idle and 45 psi at 2000 rpm.
Try some 20W50 motor oil before you change anything else.
2008 Saturn Sky Red Line Roadster
2.0L LNF Turbocharged Motor
5 Speed Manual Trans.
Custom made Blazer CAI (Click Here)
Yogi is offline
post #12 of 17 Old 10-08-2008, 06:49 PM
User is: a ragin sparky is offline
hey yeah im havin about the same problems... my father and i just about 2 months ago put a brand new 4.3 crate into my 1989 s-10. for the first month my oil pressure never went below like 45 and was around 80 when crusing. but now when i first start it up in the morn it hops to 40 or so and falls to around 25 as it warms up.. then at every red light it falls to zero and that annoying light comes on. this seems to be exactly what yall are talking about but i need some experienced advice... i put every dime into this thing and if it goes down im done for.... please hit me back asap guys i appreciate it
post #13 of 17 Old 10-08-2008, 07:11 PM
Yogi's Avatar
If I had your problem I'd be talking to the guy that sold me the motor about getting another one. You might try a new sending unit but it will prolly read the same. If you don't get any satisfaction from the seller, try some 20W50, but do SOMETHING right away!
And welcome to the Forum!
Yogi is offline
post #14 of 17 Old 10-09-2008, 09:41 PM
Wire Splicin Fool :-)
lesterl's Avatar
User is: lesterl is offline
Does she knock when the oil pressure drops? I had water contaminating my oil and it do knock just before the light comes on and it dies.
lesterl is offline
post #15 of 17 Old 10-10-2008, 03:11 AM Thread Starter
ddg1025's Avatar
i think i failed to mention it but when i replaced the oil pressure switch it fixed the problem with the light coming on. yet when it is warmed up and idling it still reads 0 but it runs smooth and with no ticking. when i accelerate though it goes up to a around 40 and when its cold it goes higher like 60-65 even when idling.
ddg1025 is offline
post #16 of 17 Old 10-18-2008, 05:30 PM
hey guys thanks for the advice i changed my sending unit and it fixed the pressure problems. at idle its around 40-45 and driving its up around 60-65
post #17 of 17 Old 10-18-2008, 05:52 PM
Yogi's Avatar
Congrats!
Yogi is offline
