Oil Pressure Sensor location - S-10 Forum
post #1 of 7 Old 01-02-2008, 12:23 PM Thread Starter
User is: jludlum is offline
My oil pressure gauge on my 2001 Blazer 4WD is pegged. I think maybe it became unplugged or something. I can't find it. Any help would be appreciated. Thanks.
jludlum is offline
post #2 of 7 Old 01-02-2008, 12:35 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
Re: Oil Pressure Sensor location
I think it's right behind the distributor, threaded into the block.
Teamsters Local 1150
SH-60B is offline
post #3 of 7 Old 01-02-2008, 12:39 PM
User is: Tinner is offline
Mine is located at the back of the engine behind the coil paks. I have a 4.3 1997 Zr2. hope this gives you an idea.
Tinner is offline
post #4 of 7 Old 01-02-2008, 02:09 PM
Gaaoooooo
MINTSICK's Avatar
User is: MINTSICK is offline
Coil packs? The 4.3 doesn't use coil packs...The sending unit is threaded into the block to the right of the distributor (looking at the engine from the front). If it were unplugged I'd imagine pressure would read zero and not pegged but I suppose it could be faulty. When you turn the truck off does the needle return to zero? If not you may want to check your gauge cluster to see if the needle is stuck or maybe the cluster itself is bad.
2004 Silverado Z71 ECSB - |Silver Birch Metallic|5.3|Custom Single Exhaust|Method Standards
1993 Mustang LX Hatchback - |Reef Blue|5.0 H.O.|5 Speed|MGW Short Shifter|70MM MAF|MAC Shorty Headers|Pypes O/R X|Spintech Pro Streets|3.55's|
1984 El Camino Conquista - |Black|5.0L|Comp XE262H|Holley 570|700r4 swap|2.41 open rear|
MINTSICK is offline
post #5 of 7 Old 01-03-2008, 08:35 PM Thread Starter
Thanks guys. I will have to remove the dist cap to see if I can see it. I just got the tranny back in and suspect maybe I bumped it while putting the dipstick tube back in. It's tight back there! I removed the cluster and moved the needle back where it should be, but as soon as I turn the key on, it pegs again. Some gauges peg when unplugged(open circuit), some peg when shorted to ground. I will check it more this weekend. The vehicle was down since Thanksgiving, so who knows what happened. Thanks again, Later.
jludlum is offline
post #6 of 7 Old 01-03-2008, 10:03 PM
King Turd Polisher
89Chubby's Avatar
User is: 89Chubby is offline
It's to my understanding that if the ECM isn't getting any signal of oil pressure from the oil pressure switch - which would be the case, if the switch was unplugged - it cuts out fuel. Is the motor actually running differently, or is the problem limited just to your dash gauge? Sounds more like a ground issue, or a problem with the gauge/cluster, itself rather than the sending unit, to me.
Now would be a groovy time to upgrade to a mechanical oil pressure gauge. Just locate the stock sender at the back by the distributor, screw in a T-fitting, and then thread the stock switch and the line for your aftermarket gauge into that. Don't forget to wrap the threads with Teflon tape, too.
1989 Chevrolet S-10 Blazer 2WD 4.3 auto (SOLD)
1986 GMC S-15 2WD X-cab 2.8L T-5 (SOLD)
1992 Chevrolet S-10 Blazer 4WD 4.3 auto (DAILY BEATER - 235k and still going)
89Chubby is offline
post #7 of 7 Old 01-03-2008, 10:08 PM
1996S10's Avatar
User is: 1996S10 is offline
If you had the trans out you may have pinched a wire in the middle of the to.
1996S10 is offline
