neutral safety switch bypass - S-10 Forum
post #1 of 5 Old 04-21-2008, 11:39 AM Thread Starter
User is: juavos00 is offline
I have acquired an engine wiring harness from a '95 S10 4.3L blazer with an automatic transmission, and I am running a standard transmission. Is the wiring for the neutral safety switch that is supposed to be hooked up to the automatic going to cause problems?
If so, how would I go about bypassing it?
My Truck: '95 S10 originally a 2.2L now has '95 4.3L "W" CPI Engine, '01 Manual Transmission, Centerforce Dual Friction clutch. Crane Cams 1.6 rockers, OBX stainless steel headers with true duals; flowmasters dumped at the axle. K&N FIPK intake. Electric fan(s). Auburn posi with 3.73 gears and Cal-Tracs for traction.
juavos00 is offline
post #2 of 5 Old 04-21-2008, 12:10 PM
Bill Wheats's Avatar
User is: Bill Wheats is offline
Re: neutral safety switch bypass
I not sure if it is on the linkage or the tran. Never dealt with an s10 nuetral safety switch. if I'm right it just touches ground to tell the stater if it is in Nuetral/ park or in gear. You should be able to extend the wire to your nuetral safety location and splice it in.
post #3 of 5 Old 04-21-2008, 05:02 PM Thread Starter
I believe that it hooks up on the driver side of the transmission. But I already have my clutch safety switch bypassed; and want to do the same with this switch because I don't care about that one. All I am concerned is the engine will fire with or without that neutral safety switch being there.
juavos00 is offline
post #4 of 5 Old 04-22-2008, 01:48 PM
ssz28man's Avatar
User is: ssz28man is offline
as long as the starter wire going to and from the switch are connected together it should run. I don't know if this is the case for a 95, but in the newer ones if the p/n switch isn't connected it'll turn on the mil. worst case though you could hook the switch up and leave it in the park position and secure it out of the way somewhere.
ssz28man is offline
post #5 of 5 Old 04-22-2008, 07:18 PM Thread Starter
yeah my dad and I are going back to the junkyard to pull the switch from that blazer that we got the wiring from, and we are going to just put it in park and zip tie it away (especially from the exhaust)
juavos00 is offline
