Need info on odd fire and even fire 4.3 V6 ? - S-10 Forum
post #1 of 5 Old 06-30-2002, 01:34 PM Thread Starter
User is: Ed in Vegas is offline
What changes were made to create the even fire VS the odd fire 4.3 V6?
What parts are interchangeable, if any?
I'm really looking for info on the crank, cam, and distributor.
Thanks.
post #2 of 5 Old 06-30-2002, 10:42 PM Thread Starter
Anyone?
post #3 of 5 Old 06-30-2002, 10:48 PM
ZQ8 2001
DoubleDown's Avatar
User is: DoubleDown is offline
post #4 of 5 Old 06-30-2002, 11:10 PM
User is: lilscreamer is offline
this should help, this info is all directly from the Chevrolet
Power catalog from GM
1978-84 v6/90 where 200 and 229 cid, these motors had a
"semi even" firing order with a rod throw of 132degrees/108deg/132deg/108deg and so fourth throughout the firing order of 1-6-5-4-3-2.
the 4.3 was introduced in 1985 and is a true "even fire " engine.
Its rod throws are offset 30 degrees which produce 120 deg. of crankshaft rotation between cylinder firings.
Then there is a heavy-duty "common pin" crankshaft that was developed by Chevy Special Products for v6/90 racing engines. There is NO offset in the rod journals of a common pin crank.
So this design produces an "odd fire" sequence with alternating
150deg and 90deg intervals between cylinder firings. NO PRODUCTION V6/90 CHEVROLETS HAVE BEEN MANUFACTURED WITH ODD-FIRE COMMING PIN CRANKSHAFTS, however most of the v6/90s used in COMPETITION are equipped with a common-pin
odd fire crank.
Thus there are three possible firing sequences for a v6/90 engine
as determined by the crank shaft. EACH FIRING SEQUENCE REQUIRES A SPECIFIC DISTRIBUTOR AND CAMSHAFT TO PRODUCE THE CORRECT SPARK AND VALVE TIMING FOR PROPER OPERATION.
The firing order is the same on all v6/90. 1-6-5-4-3-2
91 43:comp cam,early 200/229 headsw/pocket port,headmen headers w/ true duals,edelbrock intakew/holley600 and ram air,driveshaft loop,mini-spoolw/3.42's,lakewood slapper bars and bfg drag radials.
14.91@92mph
post #5 of 5 Old 07-02-2002, 12:02 PM Thread Starter
Thanks for the help!!
I really appreciate it.
