need GOOD motor mounts 98 4.3 s10 - S-10 Forum
post #1 of 30 Old 11-22-2004, 11:18 PM Thread Starter
User is: corpse666 is offline
The regular aftermarket mounts suck. Is there anything else out there? All searches only bring up v8 swaps. Need something that is suitable for off-road, any help would be appreciated!
post #2 of 30 Old 11-23-2004, 02:20 AM
it looks stock.. kinda..
Teeleton's Avatar
User is: Teeleton is offline
Re: need GOOD motor mounts 98 4.3 s10
Contact Boosted Thrills. Not sure if here's got an account on here, but he hangs out on SSF a lot. He makes new frame pads that will let you use Energy Suspension poly motor mounts for a V8. They interlock, so they're strong as hell.
Teeleton
89 Dark Blue Blazer : The Hotrod : Tuning in progress : 9.32@72 1/8mi. new 1/4 times pending...
89 Black Blazer : The Daily : 16.9@82
Member of H.A.S.T.E. (Houston Area S-Series & T-Series Enthusiasts)
Get your butt to the 2007 S-Series Nationals!
Teeleton is offline
post #3 of 30 Old 11-23-2004, 02:40 AM
FAS
FAS's Avatar
User is: FAS is offline
Send a message via AIM to FAS
i have them on my truck no more broken motor mounts since
94 S-10 Reg. Cab 4.3L 5 speed
FAS is offline
post #4 of 30 Old 11-23-2004, 03:47 AM
Road Race/Auto X S10
ZR1 S10's Avatar
User is: ZR1 S10 is offline
Send a message via AIM to ZR1 S10
I also have the boosted thrills frame pads w/ Energy Poly Mounts!! They work fawking awsome!
02 Trans Am M6: A few SLP goodies
96 4.3L M5 Xcab: Comp Cams Pro Magnum lifter/roller rockers, 270AHR cam, Edelbrock 2114 intake w/ bosch 25 lb/hr injectors, Mach Performance Stage 3 Heads, SLP 17x8 ZR1's, and every bolt on
PARTING OUT THE S10. PM for details.
ZR1 S10 is offline
post #5 of 30 Old 11-23-2004, 08:02 AM
loco hombre
nater006's Avatar
User is: nater006 is offline
Send a message via AIM to nater006
Anyone got a price guestimate?
ZR1 S10 - I see you have a '96, which means they should hopefully fit my '96 also Its 4WD but hopefully that doesn't make a diff with the mounts. I never know, with that front differential in the way and stuff. Any ideas?
nater006 is offline
post #6 of 30 Old 11-23-2004, 10:52 AM
www.myspace.com/MINTSICK
jmwxtreme43's Avatar
User is: jmwxtreme43 is offline
Send a message via AIM to jmwxtreme43
Honestly I believe the pads he makes are only for 2wd but I am not sure if there are even any differences between 2 and 4 wheel. He sells the pads shipped for around $60, the energy suspension mounts go for around $40 I think.
post #7 of 30 Old 11-25-2004, 05:27 PM
Accent, what accent
TECHRF's Avatar
User is: TECHRF is offline
Send a message via AIM to TECHRF Send a message via MSN to TECHRF Send a message via Yahoo to TECHRF
Cool Re: need GOOD motor mounts 98 4.3 s10
have look at these race proven motors sells them. going to get a set for my first gen.
friends don't let friends drive FORDS | Fun=Fuel
91 JIMMY 4DR 4WD Nats 02 03 06 07 Project pics
01 Blazer 2DR 4WD Nats 04 05 08 09 sold
TECHRF is offline
post #8 of 30 Old 11-26-2004, 01:20 AM
Teeleton's Avatar
There's another guy that makes syty mounts, which are the same as 4wd mounts.
Teeleton
Teeleton is offline
post #9 of 30 Old 09-15-2012, 11:47 PM
1996 4.3 5 speed xtra cab
tommyboys10's Avatar
User is: tommyboys10 is offline
Sorry to bring this back up. I need some and these links are broken. Who makes them that dont brake?
1996 5.7 l31 S10 NV 3500 2wd extended cab
post #10 of 30 Old 09-15-2012, 11:50 PM
goin broke but n style
S15vortecpwr's Avatar
jagsthatrun.com have good 4.3 mounts that wont break for $85. I will prob order some for my 94 soon.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #11 of 30 Old 09-16-2012, 12:27 AM
thanks bro, ill check em out. Mine keep snappin. Made in india motor mounts made from cow manure lol.
post #12 of 30 Old 09-16-2012, 12:44 AM
89sdime262's Avatar
User is: 89sdime262 is offline
yea stock 4.3 mounts were shit from the factory and factory replacements suck, i broke 4-5 mounts in less than a yr and a 1/2 along with 3-4 trans mounts till i finally got Energy Suspension urethane mounts and now 4 yrs later no broken mounts yet so they must be pretty good bc i certainly abuse them lol i got mine from Summit Racing www.summitracing.com and theyre about $40..ish a piece for the motor mounts and around $20 or so for the trans. def money well spent
post #13 of 30 Old 09-16-2012, 01:18 AM
I brake only 2 a year. You must got at leat 220 hps.
post #14 of 30 Old 09-17-2012, 02:00 AM
89sdime262's Avatar
idk what im puttin at the crank, cant be too much since its all stock internals and just a few minor bolt ons and a lot of miles, im sure the built trans and alot of meat on the ground helps out with twisting the motor and trans mounts apart tho
post #15 of 30 Old 09-17-2012, 02:10 AM
DaGuse5853Z's Avatar
User is: DaGuse5853Z is offline
JTR sell mounts that use the clamshell 2.8L mounts, the same used for the V8 swaps, for use with the 4.3. I haven't used them but I wouldn't hesitate to.
http://www.jagsthatrun.com/Pages/Par...entMounts.html
or you can get a pair of stock GM made 2.8L mounts, install poly bushings in them, and then buy JTR's adapter plates.
SS wannabe '96 Ext Cab 4.3L, 5 Speed, '98 Trans Am G80 diff swapped into an originally equipped 2.2L slush box.
post #16 of 30 Old 09-17-2012, 12:37 PM
I turn.
rentedmule's Avatar
User is: rentedmule is offline
bajacustoms.com makes some monster mounts as well.
Auto-X mule: EC 2wd 4.3 auto, XTREME80 tune, bolt ons, UBM UCAs, Spohn LCAs, tall BJs, QA1 coilovers and shocks, Torsen LSD, C5 brakes, race seats, Toyo R888's.
Daily driver: '95 Firebird Formula Ram Air, LT1/T56
post #17 of 30 Old 09-17-2012, 04:43 PM
89sdime262's Avatar
i always wondered why in the hell they made the good mounts for the 2.8 but didnt continue that design on the 4.3 i had always thought about making a plate for the motor and using 2.8 frame mounts, guess somebody else had the same idea, yea i wouldnt hesitate to run those, they CANT come apart, its surrounded by rubber thats incapsulated in metal, theyll hold 600+ hp i bet
post #18 of 30 Old 09-18-2012, 06:09 AM
yup, I was thinking the same thing about the clamshell mounts. For the longest time I assumed that all mounts were designed so if the rubber failed the mount still held the drivetrain in relative place.....then I discovered 4.3 mounts lol. Bonded rubber to a metal plate sounds like a bad idea from the start, way to go GM engineers!
post #19 of 30 Old 09-18-2012, 09:32 AM
89sdime262's Avatar
haha yea def not the smartest thing they've ever done hey had a "safety catch" on them in case it came apart... yea that worked real well i twisted that "safety catch" like a can, ive demolished those mounts after the air cleaner has hit the bottom of my hood, or you hit 2nd and it snaps motor and trans mount at the same time and ur motor is sideways in the engine bay but i do have to say the Energy Suspension has took some abuse and is still holding up pretty well, and the internal lock on those seem like they would actually be functional unlike GMs
post #20 of 30 Old 09-18-2012, 09:42 AM
Electrical Mod
deathphoenix99's Avatar
I just want to say that the 4.3 mounts aren't the first to use two metal plates with rubber bonded between them. My 77 Dodge motor mounts are like that as well, but back then, you only have one bolt holding the mount to the frame and another bolt holding it to the motor bracket. I know Dodge didn't change them until the 80's I believe.
post #21 of 30 Old 09-18-2012, 09:54 AM
89sdime262's Avatar
Well... that is Dodge for ya, some of the earlier dodges were ok but after that they went to hell and never really stepped back up, and the new Hemi... you couldnt give me one, id like to keep my bottom end together longer than my warranty last
post #22 of 30 Old 09-19-2012, 02:53 AM
My old 4.3 mounts didn't have a safety catch lol. It was straight rubber bonded to metal, nothing else. When I had the engine on the ground the only part that was left of the mount was the plate bolted to the block.
post #23 of 30 Old 09-19-2012, 03:07 AM
Electrical Mod
And I'm pretty sure that Dodge isn't the only one to use the rubber bonded motor mounts, Ford, GM, and Dodge all used them. I was just pointing out that GM isn't alone. But to each their own. My 85 Ramcharger is awesome, but I wouldn't touch their stuff in the past 10-15 years.
post #24 of 30 Old 09-19-2012, 01:31 PM
S-Series Sucker
chcknugget's Avatar
User is: chcknugget is offline
I've installed the jagsthatrun adapters and 2.8 engine mounts and I like them... Install them and forget about the crappy stock mount headaches.
post #25 of 30 Old 09-19-2012, 10:08 PM
89sdime262's Avatar
well theyre not very fumctional but it shouldve had the little T thing that hooks the ears that come off the mount
post #26 of 30 Old 09-19-2012, 10:30 PM
Life's too short for IFS
KM346's Avatar
User is: KM346 is offline
X2... I have the JTR conversion mounts in both my trucks and will never run anything else.
On my blazer i even bought factory ACDelco 2.8/astro van mount and used just the JTR bracket ... it idles smooth, and will probably outlive the truck.
-2001 Blazer 4x4 SAS'd: Ford and Jeep junkyard parts mixed w/ random overpriced custom stuff
KM346's Build: The Refrigerator
-1999 GMC Sonoma 2wd LS swap in progress: 6.0L LQ9/ 4l60E with 3K stall and 4.10 gears.
Waggy/Rodeo D44 waiting for the Fridge V2.0 or another SAS...
KM346 is offline
post #27 of 30 Old 09-20-2012, 09:57 AM
User is: Loop is offline
I just bought some of these. They are expensive....he is charging 200 for the set now because they are not in business anymore. Plus it took awhile for them to get made.
Loop is offline
post #28 of 30 Old 09-20-2012, 12:39 PM
I turn.
rentedmule's Avatar
Didn't realize they went out of business - they made some really nice stuff
post #29 of 30 Old 09-20-2012, 12:41 PM
Mikz86TA's Avatar
User is: Mikz86TA is offline
Got the JTR ones. Very happy...not harsh like poly, and wont come apart like stock ones.
2003 S-10 ZQ8 - 262/M5 1986 Pontiac Trans Am - 355/A4
The S10 Project : http://www.s10planet.com/forum/showthread.php?t=15987
The Trans Am Project : http://www.s10planet.com/forum/showthread.php?t=15435
Mikz86TA is offline
post #30 of 30 Old 09-20-2012, 07:14 PM
no bags here
tretiak's Avatar
User is: tretiak is offline
i have transdapt mounts for my 4.3. and they havent broken yet. they do vibrate but it doesnt bother me. pretty beefy as well
2001 Blazer Xtreme
project: clean and simple < getting bagged and ls swapped
exceeding limits nepa chapter president
Originally Posted by MotorNut123 View Post
I actually should've used concrete on my fender. That way i could decorate it like pottery
you can actually really weld aluminum to steel lol friction welding
tretiak is offline
