#301 |
Re: my new "Wait4me performance" PCM...
Understanding driveline losses etc, but having everyone always quote at the crank. Just so you can give your friends a nice number what would you say the HP would be of a 2000 4.3L X-VIN (4X4) with a CAI, catback exhaust, and Wait4Me PCM?
I'm thinking 215HP at the crank is a reasonable to spurt out?? What about TQ? |
#302 |
-RUNNIN' A'MUCK SINCE 84-
id say thats a good estimate for crank hp. an efan and some underdrive pulleys would give back a few more so you could possible have like 218, also it depends on engine wear, too.
its quoted at 180hp for an x-vin (correct me if im wrong, i have a w) and thats brand new with only a few hours runtime on it. now its like 8 years old with prolly 100k miles on it so... edit: i also dont have a new pcm yet either... |
#303 |
Tacklin Fuel
question for those of you who have aftermarket camshafts
can the new pcm tune take this into acount? It should if jesse knows before it's programed. I want to do either some rockers, cam, or both. I know different cams will affect the engine and thus freak the pcm out. Am I better of just going with the rockers? Or should the re-programming work well with the cam? I don't like guess work. "Well, this sounds good with a cam" However, 1.6 rockers wont mess with the computer. |
#304 |
Not trying to down you but 215 would be the highest...and thats being nice...your talking 35 extra horses...I'd say more 200 205 at the crank but if you wanted horsepower at the wheels(which is what you're really getting) then knock another 25-30 hp from stock(180)....CAI and exhaust are good but together would add no more than 10 horsepower together and then PCM would only bee good for about 10 itself....it gives more torque than hp....these engines are known for the amount of torque they have, not hp.
#305 |
2006 PBM GTO
It's been a long time since I have been in this thread, but I just did some reading to catch up and had some more to say. First off to Mikz86TA...your buddys GTO does not have an LS6 in it from the factory....I also have an 06 GTO...they are LS2's, rated at 400hp/ 400ft lbs. Tuning gains on a GTO with headers are in no way indicative of what you can expect from a semi-custom tune on your 4.3 S-truck.
I had Jesse send me a tuned PCM for my Blazer several months ago. I went from a Hypertech to the tuned PCM, and could immediatly tell a difference in SOTP performance. The 1-2 shift was MUCH improved... it didn't fall on it's face anymore, and then pick up and go (after the shift kit install). Top speed limiter was gone...I've had the truck over 130mph (probably closer to 140 according to the tach). I didn't notice much af a gain in MPG, but I didn't loose any either even though the truck runs better and feels like it has more power. The truck was an 2001 X-Blazer with the following mods: K&N FIPK (worth the money also) custom y-pipe (no CAT or pre-CAT) Flowmaster 40-series CAT-back (over the axle) 3.73 posi Ford 8.8" NGK plugs/ Taylor wires Flexalite electric fans removed AIR pump and hardware removed rear O2 sensor 160 t-stat B&M shift kit PCM was tuned for all of this and to correct speedo after gear change. No SES light, and I never did the crank relearn. I did have a security light on though, and I have heard of others with this problem. Did not affect truck starting or running though???? Jesse wasn't sure how that happened. With the listed mods and 20x10's on the rear with Nitto NT555 285/30r20's, it would BAKE the rear tires off, and ran 15's. Not bad for a V6. Like I said though, I got sick of going slow and bought the GTO. 13.3's stock and 12.9's with very minimal mods. Traction is definitely a problem now. ![]() |
#306 |
Registered (Ab) User
#307 |
Will work for turbo parts
I believe his locks over 45, but I would have to look again.
#308 |
By the way I have had my W4M tune in the truck for about 30,000 miles and its been great, (before I got HPT) you can look at my post when I got it several pages back ![]() |
#309 |
#310 |
#311 |
#312 |
Sweet!
#313 |
my old snap on mt 2500 has the crank sensor relearn under the diagnostic tests menu
#314 |
heres something i thought of today...
is the abs controlled by the pcm or independently? cuz i have smaller tires on the front/big fat ones on the rear. i know i lost somewhere in the neighborhood of 8 feet of stopping distance by doing this but i'd still like to correct it. i know that he (jesse) can correct for tire sizes but can he correct them for two different sizes? right now the abs sensors are reading at different speeds. Last edited by muckRunner : 05-02-2008 at 12:24 PM. Reason: misspelled words, lol |
#315 |
No, the ABS module is separate from the PCM/BCM/CAN. I doubt any tuning software will let you edit the ABS properties because of the liability.
#316 |
ah that sucks, well i guess it comes with the territory... ill just have to hit my brakes 8 feet sooner when some stupid ricer runs a red light...
#317 |
Location: Barksdale afb, Bossier city LA User is: OffLine |
but the point is, you can program the abs for the correct tire size, im thinking that it is somewhere under the bcm settings and not the pcm. |
#318 |
I finally got blown
I would like to get my pcm done but i cant get ahold of anyone i've emailed JESSEBUBB@YAHOO.COM and tried to call 574-267-3630 nothing from either.
#319 |
Hey kids!
give them a day
#320 |
There's another contact somewhere in this thread - I think it's melissabubb@yahoo.com. She probably does most of the customer relations stuff anyway.
#321 |
Registered Abuser
#322 |
I talked with Jesse today. I'm sending out my PCM on Wed.
Costs $75 plus $9.00 shipping. The website is incorrect. |
#323 |
Registered Abuser
#324 |
Nario
anybody in the southeast kentucky area that can do a crank relearn?
#325 |
i live about 45 mins south of louisville and i cant do one but all you have to do is look for a smaller shop or call around and ask if anyone has a snap-on diagnostic machine (the expensive ones, there are other brands too) your best bet is the smaller shops cuz no-one ever needs to have this done and since it only takes like 10 minutes to setup and conduct it should only be like $20.
#326 |
you noo get dis
w4me does not remove TM...I asked him when I had mine and he said some people ask and he said he'll tell them ok and he won't for their saftey. This is from his mouth after that things didnt set well with me ...got a nelson removed the TM and all is well...I love it!!......
this is from a full size thread i was reading on, hope that isnt true b/c i am looking at getting this as soon as possible |
#327 |
<3 redheads
#328 |
Megabyte
hasn't it been a paper weight for you for the past few months? |
#329 |
<3 redheads
#330 |
#331 |
i certainly felt a differince, i also did ask for a 80% tm reduction so maybe he did it cuz i asked....
#332 |
Registered Abuser
I asked for 50% reduction, and I can feel it...
#333 |
not low, not gonna be...
#334 |
you noo get dis
well good deal...i think i will be ordering one soon, then sending my stock one in once i receive the other to get it relearned and just have two(since apparently it cost more to have it done at a shop)...i guess i will keep the hypertech to read codes
#335 |
does anyone have a 4x4 with this tune? I am thinking of getting a w4m tune but I dont need power high in the rpm range. I want tourqe and throttle response and improved shift firmness. Im going to get one here soon, I just wanted to know how my difference you can feel turning over a larger tire.
thanks kyle |
#336 |
Registered Abuser
#337 |
Megabyte
mine is a 4x4 also.
#338 |
I asked for 80 percent torque management removal, because I have a transmission that can take well over 400 HP. I don't think he removed any. I am watching the timing drop about 20 deg during shifts.
The thing you are probably feeling is the reduced shift time/increased pressure. |
#339 |
I have a 1997 Sonoma 4 X 4-- had it done a year ago runs great, I had the Corvette shift kit put in before the tune. This tranny that I had had never been modified, it would hang up and the SES light would come on. They drilled the valve body and installed the Corvette kit then. I was reading on this forum about Wait4me tune and decided to get one done. You will really love it, I can squeel the tires in a 1-2 shift easily.
#340 |
#341 |
No need to reinstall your old pcm. I have a stock .HPT file from my 98. PM me with your e-mail addy and I'll send it to you.
#342 |
#343 |
#344 |
OK so I compared Yogi's stock file to mine and there is significant differences between the two in reguards to torque management. I think its safe to say that in my case he did remove torque management by 75% maybe a little more. Here are some screen shots of the two tables:
Yogi's Stock tune: http://i198.photobucket.com/albums/a...Factory-TM.jpg My W4M tune with TM removed 75%: http://i198.photobucket.com/albums/a..._az/W4M-TW.jpg Sorry i know the quality of the images is kinda crappy but im doing this from work with no editing tools ![]() |
#345 |
I can't even read those jpgs, but I can make an excell spread sheet comparing the TQM changes if you would like.
I was going to go to the dyno this weekend, but they are going to be at the Huckstorf show. Last edited by King_Ice_Flash2 : 05-09-2008 at 06:28 PM. |
#346 |
Enjoy
#347 |
when requested.So back to the point of this thread, he does remove TM if its asked for. |
#348 |
you noo get dis
good deal...im taking my truck to the transmission shop early this week...i have the vette servo and he has allready firmed up the 1-2 shift and he is now going to firm up the 2-3 shift....is there anything else i need to get done before i get the tune?
#349 |
yellow s10 dude
Just got my pcm in today, and it kicks ass! Feels great through out the entire power band. Shifts feel great. No SES light. All in all the best $157.xx i ever spent on my truck. With my 235's It will burn into second from a 10 mph roll
#350 |
<3 redheads
ok fellas i decided to give the pcm another try. same results as last time. at idle it spits/sputters like it wants to die. i don't get it. 96s dont need to crank relearn right? that's just for 98 and up right?
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f107/my-new-wait4me-performance-pcm-305176/
| MyS10.com - Jet or Hypertech programmers | This thread | Refback | 10-11-2007 02:15 AM | |
| MyS10.com - Jet or Hypertech programmers | This thread | Refback | 10-10-2007 11:23 PM | |
