Intermittent Miss '95 Blazer 4.3 CPI - S-10 Forum
post #1 of 19 Old 12-24-2003, 12:37 AM Thread Starter
'95 Blazer 4X4
goldduster318's Avatar
User is: goldduster318 is offline
Hello,
I have a 1995 Blazer 4X4 with the 4.3 CPI engine and 118,000miles on it and it is behaving very strangely. When the weather changes or is damp/cold the engine misfires at idle and is very audiable. This is not a problem once it is brought off idle.
It also will just cut out for a half a second or so going over hills at about 50-60 miles per hour and it will repeat it several times and then clear up. Sometimes it will not do it at all.
The service engine soon light comes on every once and a while but not usually.
Does anyone have any idea what the problem is? This is a good blazer and I have had it since 19,000 miles and this is frustrating.
Thanks a lot
post #2 of 19 Old 12-24-2003, 08:40 AM
Bigthreefan's Avatar
User is: Bigthreefan is offline
Send a message via AIM to Bigthreefan
I have a simular problem I've narrowed it down to a leaky(driping) CPI. (i think)
let you know as soon as I change it probably around 1/2/04
95 Blazer
87 MCSS Black w/Saddle
Goodmark cowl hood. 355 w/dart heads
700r-4, Gforce crossmember, 4.10’s
1LE Brakes w/Hotchkis uppers,
dropped 2" & ZQ8 wheels.
MY Monte Pics
post #3 of 19 Old 12-29-2003, 08:32 PM
I finally got blown
99xtrm's Avatar
User is: 99xtrm is offline
check local gm dealer for recall--read in diff post about this.
the first time they look at it they try to clean the injector assy, then if that doesnt do any good then they rep the assy.
call first --if there is no recall you will have to pay for checkout.
99xtrm is offline
post #4 of 19 Old 12-29-2003, 10:50 PM
User is: xtremejimmy is offline
Send a message via AIM to xtremejimmy
CPI unit, Nut kit, and egr valve.
95' GMC Jimmy
4.3 CPI ----K&N filter, flowmaster 50 series, custom audio system, custom air vents, xenon bulbs, APC dash.
post #5 of 19 Old 12-30-2003, 12:18 AM
User is: coolram is offline
Also how long has it been since you did a full tuneup(cap/rotor,wires,plugs,filter)?Worth a try,along with using Seafoam to clean fuel system,before diving into the CPI.
'95 Jimmy SLS 4DR 4WD Auto/K&N/serviced cat
'89 Grand Am LE 2.5/Auto
'70 Monte Carlo SS454
'92 Capri XR2
coolram is offline
post #6 of 19 Old 12-30-2003, 02:43 AM
B95
Early Member
B95's Avatar
User is: B95 is offline
1995 Black S-10 X-Cab 4.3 CPI. '96 Jimmy 4dr Power-leather seats(converted to flip forward). '98/99 Bravada headlights and grille. Envoy bumper cover and fog lights. 2" drop spindles. Headlight wire upgraded with relays. Blazer floorshift. '96 Blazer leather steering wheel and air bag. '96 Jimmy leather door panels.
B95 is offline
post #7 of 19 Old 12-30-2003, 04:01 AM
revrenhex's Avatar
User is: revrenhex is offline
My 95 4x4 blazer is doing the exact same thing, i sure hope its not the CPI. Let us know how the CPI change out goes Bigthreefan!!!
post #8 of 19 Old 12-30-2003, 11:56 AM Thread Starter
'95 Blazer 4X4
A new cap, rotor, plugs and wires were done at about 102,000 (16,000mi ago).
I dumped Fuel Injector cleaner into it yesterday and drove it about 45 miles with no improvement noticed.
My service engine soon light was blinking as I was coming home and the next time I went out, it stayed on solid. After getting in the throttle to merge into traffic, it shut off but the symptoms were still there.
When it is running bad, the exaust pipe smells like it is running very rich.
post #9 of 19 Old 12-30-2003, 01:47 PM
I finally got blown
99xtrm's Avatar
when your engine light is flashing it means there is a misfire detected--if it smells rich then its getting too much fuel causing the misfire--call the dealer and see if you have the recall.
99xtrm is offline
post #10 of 19 Old 12-30-2003, 01:59 PM
Insane Network Engineer
rlith's Avatar
User is: rlith is offline
Send a message via AIM to rlith
More than likely it's the CPI or the nut kit going bad..This will cause those symptoms.
See my ride at
http://www.pghconsulting.net/teal
and www.s10planet.com
Support Sattelite Radio! Goto www.siriusbackstage.com
rlith is offline
post #11 of 19 Old 12-30-2003, 02:27 PM
Clean N' Dark
BlazerLT's Avatar
User is: BlazerLT is offline
I would go to Autozone or the dealer and get your codes read.
Sounds like you have a sensor acting up. Everytime the engine light comes on, a code is stored in the computer.
It could be the CPI but the CPI doesn't kick on the service engine light.
1995 Blazer LT 4 Door 4x4
4.3L CPI Vortec
Ravin Z55 Performance Muffler
K&N FIPK Gen2 Cold Air Intake
BlazerLT is offline
post #12 of 19 Old 12-30-2003, 02:38 PM
rlith's Avatar
it will if it causes a too rich condition and the 02 sensor to go nuts... I've seen that happen too many times with CPI...
See my ride at
rlith is offline
post #13 of 19 Old 12-30-2003, 02:47 PM
Clean N' Dark
BlazerLT's Avatar
True, he should get the codes read and I hope he doesn't clear his computer.
The codes will tell all.
4.3L CPI Vortec
BlazerLT is offline
post #14 of 19 Old 12-30-2003, 03:02 PM
man, not to sound all passimistic (sp?), but i was already there before and i know the symptoms. I replaced the car, rotor, spark plugs, spark plug wires, fuel filter, etc... Basically, a full tune up. heck, i even ran sea foam before all that. ran a tiny bit better. But after the next oil change, it was getting worse. so i pulled the upper plenum and saw washed gas on the manifold, thus the culprit being the CPI unit and nut kit.
95' GMC Jimmy
post #15 of 19 Old 12-30-2003, 04:14 PM
Clean N' Dark
BlazerLT's Avatar
Xtremejimmy, we are not solving your problem, we are solving the thread starters.
If he is getting check engine lights, the smartest course of action is to get the computer checked to narrow it down before the engine is torn apart.
4.3L CPI Vortec
BlazerLT is offline
post #16 of 19 Old 12-30-2003, 06:24 PM Thread Starter
'95 Blazer 4X4
The computers already been checked several times and not cleared. It has read anything from O2 sensor curcuit low (only the first time) to just the knock sensor curcuit being low. Otherwise it is not causing codes. I guess it must be the CPI unit.
1995 Chevrolet Blazer 4x4 4.3 CPI
Dynomax Super Turbo Exaust
post #17 of 19 Old 12-30-2003, 08:43 PM
Clean N' Dark
BlazerLT's Avatar
Those are codes if you are getting something read by the scanner.
Sounds like a lean cylinder bank.
Which bank was the knock sensor acting up on?
4.3L CPI Vortec
BlazerLT is offline
post #18 of 19 Old 12-31-2003, 11:19 AM Thread Starter
'95 Blazer 4X4
i was getting a knock sensor low on bank 1
post #19 of 19 Old 01-01-2004, 03:50 AM
User is: cobra1 is offline
Re: Intermittent Miss '95 Blazer 4.3 CPI
Originally posted by goldduster318
Hello,
Thanks a lot
how many miles on those plug wires?
sounds like a burnt plug wire. which will cause it to miss under load (going up hill). when my 95 did this, it wouldnt do it all the time.
cobra1 is offline
