Interesting marine intake on eBay
Old 06-08-2006, 04:39 AM   #1
crap
bg's's Avatar
Be nice if this bolted up to late model engines. Maybe it does..
Might be looking into for someone that knows their stuff regarding
multi injection.
http://cgi.ebay.com/ebaymotors/ws/eB...%3ASS%3AUS%3A1
Old 06-08-2006, 08:58 AM   #2
not low, not gonna be...
Crew Cab Sonoma's Avatar
Re: Interesting marine intake on eBay
it will fit to 96-up heads. and with some rewiring of the injector harness, and omitting the EGR system, i believe it will interface fine with 96-up eletronics as well.
the base is iron, and the plenum is aluminum, so you would gain a few pounds with this setup, but other than that, i think it could be made to work fine.
Old 06-08-2006, 09:44 AM   #3
Akerfeldt
MINTSICK's Avatar
I am very tempted to give one of these intakes a shot, besides adapting the fuel lines it looks like a pretty straightforward swap.
Old 06-08-2006, 09:48 AM   #4
i`ve been tempted to try it as well.
Old 06-08-2006, 09:58 AM   #5
Akerfeldt
MINTSICK's Avatar
What the hell $220 isn't bad at all, I threw a bid down
Old 06-08-2006, 10:00 AM   #6
ecir38's Avatar
subscribed
Old 06-08-2006, 11:01 AM   #7
Hell yeah looks pretty straight forward for sure. Same thing as the 2114 but probably much easier to work with because it is already designed specifically for our motor with no modification except electrical!!!
Old 06-08-2006, 11:08 AM   #8
Honest Abe's Fab Shoppe
BlackEsDime's Avatar
damn... if i knew more about engine shit i'd go for it!
Old 06-08-2006, 11:25 AM   #9
Resident Hardhead
BlackStallion's Avatar
would it really add 35hp like the guy says or is he just blowing smoke?
Old 06-08-2006, 11:38 AM   #10
Yes it will increase hp that much. That stock Mercruiser motor puts out 235hp from the factory.
Old 06-08-2006, 12:19 PM   #11
but thats not just because of the intake. the camshaft, exhaust system, and calibration differences are probably responsible for most of the marine engine`s power gain over it`s automotive counterpart.
i would say the gains, if any, with the marine intake alone would be less than 10 hp.. but thats just speculation.
Old 06-08-2006, 01:07 PM   #12
Simple Ton
stlSY's Avatar
That seems about right, somewhere in that 6-10hp range is what seems realistic, I think the biggest gain would be in cool factor.
Old 06-08-2006, 01:10 PM   #13
TrailBlazin'
SuperSS27's Avatar
Id say the biggest gain would be ultimate control of the fuel system, being able to put 60# injectors if need be. Meaning more boost from a blower/turbo and a bigger shot of nitrous.
Old 06-08-2006, 01:23 PM   #14
yeah, thats definetly it`s biggest advantage. the ability to use conventional injectors in the size of your choice, without all the fabrication and expense of an aftermarket/custom setup.
Old 06-08-2006, 01:46 PM   #15
Akerfeldt
MINTSICK's Avatar
Absolutely
Old 06-08-2006, 04:14 PM   #16
crap
bg's's Avatar
So what would be the firing of the injectors ? Batch, group or
Seq ? One thing I notice is the fact it has a manifold vacumm
controlled fuel pressure reg. That in itself would be a nice
improvement from the CPI type reg, wouldn't it ?
I read a post over at full size Chevy where a member there
came up with a mod transforming his TBI ecm to fire a TPI
system. I guess he's using an external driver box. Kind of
interesting info, though it really only applies to 93 to 95
v-8's, it seems like some of his projects ideas could benefit
the 4.3. Since this marine manifold would fit heads up
to 95, it might be something to consider.
http://www.fullsizechevy.com/forums/...d.php?t=213215
Please correct me here. Is batch and group fire the same
type of injector firing ? And would the marine cam be worth
installing with this manifold, or would an aftermarket cam
such as one from Crane or Comp be the way to go ?
Thanks for any info or thoughts on this.
Old 06-08-2006, 04:18 PM   #17
LS2OMFG
Ralphie's Avatar
Tons of potential there!
Old 06-08-2006, 04:33 PM   #18
Starting from scratch...
02_Black_XBlazer's Avatar
Click click...(the sound of me subscribing to this thread...)
Old 06-08-2006, 04:37 PM   #19
LS2OMFG
Ralphie's Avatar
Hey now you don't have any right to take that thing off the road any longer!!
Old 06-08-2006, 05:21 PM   #20
Unregistered User
j894's Avatar
Notice the TB doesnt have the deflector.
Im still wonder why GM just didnt give us a version of this intake, pisses ya off.
Old 06-08-2006, 05:45 PM   #21
loco hombre
nater006's Avatar
They're trying to sell refined smooth vehicles, not ones that snap your neck off the throttle. In a boat, thats not exactly a problem. In a vehicle, it is.
Old 06-08-2006, 05:49 PM   #22
Unregistered User
j894's Avatar
I know im just bringing that out on the table, because of the arguement that the deflector is there to distribute EGR gases or whatever BS reason it was.
Old 06-08-2006, 06:02 PM   #23
Akerfeldt
MINTSICK's Avatar
It's on the road don't make me go take a picture of it with the valid plates on it! I just figured down the road it would be nice to have.
Old 06-08-2006, 06:04 PM   #24
Akerfeldt
MINTSICK's Avatar
I've seen a thread on another forum where silverado vortec 350 guys have been using this same intake with great results, I forget where I saw it exactly.
Old 06-08-2006, 06:25 PM   #25
rat
Got Fuel Rails?
rat's Avatar
As far as the vacuum both cpi's, and csefi's('96 and ups) have vacuum controlled regulators. This one is just external. And it isn't prone to leaks like the '92-'95 ones were.
Depends on the year. On the '96 and up's it would be full sequential control. On the '95 and downs i don't see it being able to be used on the stock computers, but maybe with modification. A set of '96 up vortec heads would be required, but they flow better anyhow.
The difference between batch and sequential is negligable though in my opinoin. Anyone with a '96 and up can experience both. Stock they are sequential. Unplug the camshaft position sensor under the distributor and you are in batch fire. Not a real big difference that i could tell, besides the ses light. The '92-'95's were batch fire only. The only difference may be felt at lower throttle inputs, at wot the injection is longer than the valve timing event anyhow i think.
I'd just take a pick of the comp or crane offerings for whatever the goals of the engine are.
I agree with the general consensus in this thread though, it probably won't add much power on an n/a truck, but use it on a boosted truck, or something that has a "half a$$ed" fuel system that can't keep consisten air fuel ratios, then there is deffinately a lot of potential.
I kind of wish i had this manifold to start from, may have saved me a lot of work converting a stock manifold over to normal fuel injection with rails.
Old 06-08-2006, 10:56 PM   #26
2UP1DOWN
tfpets's Avatar
I saw them install that v-8 setup on horspower tv or trucks one time...the only modification from tbi to multi as far as wiring was some sort of adapter harness that spliced into the tbi injector wires....and they gutted the stock throttle body to use for the air intake throttle body...as I recall there was about a 35 hp gain and almost 50 torque gain....alot of that coming from the MUCH taller and straighter intake...all I can figure with the injector fire is they are firing 4 at a time and hoping the o2 works good enough to keep up.
Old 06-09-2006, 12:14 AM   #27
s10blaze43's Avatar
how would the throttle linkage work if it hooks up on the opposite side? unless u could bolt on a stock throttle body?
Old 06-09-2006, 08:29 AM   #28
04Xtreme's Avatar
bolt your stock TB to it
Old 06-09-2006, 12:54 PM   #29
limeade
01black4.3's Avatar
Well, I would buy it but I want to let Mint figure it out first.
Old 06-09-2006, 02:17 PM   #30
crap
bg's's Avatar
There are options for the throttle cable.
Old 06-09-2006, 02:41 PM   #31
www.Barstoolsports.com
BlkS10Kid2002's Avatar
well mike u could mock it all up on the blazer and then once u know its good to go spend a day swapin shit ova to the dime
Old 06-09-2006, 03:04 PM   #32
Akerfeldt
MINTSICK's Avatar
I ain't mocking SHIT up on the blazer, I will never turn a bolt on that truck under the hood again!
If I get this I won't be exploring it for a little while, I want to get the truck running well with the current intake on there and make sure the engine is where it needs to be. As far as the modifications needed, other than splicing wires for the injectors (will need some injector connectors) it's just a matter of adapting the stock fuel lines to the manifold. EGR isn't a real concern for me since I can edit it out with tunercat and the inspection stations don't even do a visual inspection, doubt they would know what the hell they are looking at anyways. I don't forsee forced induction in my future but I would like to mess around with nitrous at some point, I think this manifold would work very well with a proper nitrous tune.
Old 06-09-2006, 05:59 PM   #33
s10blaze43's Avatar
This looks like a sweet option instead of buying a 2114
Old 06-09-2006, 07:26 PM   #34
BeyondeXtReMe's Avatar
all the stock mercruiser 4.3's I've seen have 205 hp (same as the 4.3's in halftons)
Old 06-09-2006, 09:19 PM   #35
If you look at the sellers feedback, he just bought the thing not that long ago..I wonder why he's selling it so soon? Maybe Mint will get lucky and pay less than he did for it!
Old 06-09-2006, 09:29 PM   #36
Akerfeldt
MINTSICK's Avatar
I just took a look at that, he only paid $256 for it. Looks like he bought some other boat parts and then realized he didn't have a boat nor a 4.3L?!?
Old 06-09-2006, 09:41 PM   #37
Maybe he realized his boat had a 2.2?
Old 06-09-2006, 09:48 PM   #38
she's wearing pink undies
juddspaintballs's Avatar
lol
Old 06-16-2006, 09:01 PM   #39
Any update? Did you win the auction, Mint?
Old 06-16-2006, 09:09 PM   #40
limeade
01black4.3's Avatar
Yes, he did.
Old 06-16-2006, 09:11 PM   #41
I just looked at the finished auction...He payed $36 bucks less for it than the seller did!
Old 06-17-2006, 02:22 AM   #42
crap
bg's's Avatar
If it works that's MY finders fee...
Old 06-20-2006, 11:45 PM   #43
I cant win for loosing.
PhatBoy's Avatar
Son Of A Bitch......i Want That One.
Old 06-21-2006, 10:13 AM   #44
Akerfeldt
MINTSICK's Avatar
Haha of course it will work! The intake is being delivered today, I will get some better pictures of it up for you guys.
Old 06-21-2006, 01:02 PM   #45
crap
bg's's Avatar
I hope it pans out for ya, Mint.
Old 06-21-2006, 01:32 PM   #46
sounds good. say, how about throwin it on a scale, and letting us know what it weighs?
Old 06-21-2006, 02:09 PM   #47
Akerfeldt
MINTSICK's Avatar
Will do, I found an article on all the modifications needed for the V8 marine intake on an L31 if anyone is interested in the differences, a few of the things probably won't apply to the V6 intake but we will see.
http://www.pacificp.com/forum/viewto...?t=317&start=0
Old 06-21-2006, 04:00 PM   #48
Unregistered User
j894's Avatar
we should have a cast aluminum version of that. Not a POS
Old 06-21-2006, 05:00 PM   #49
Nice Mike that is cool. Can't wait to see this thing and hopefully in the future it is a really easy bolt on once you get it all figured out and get the wiring all done.
Old 06-21-2006, 05:54 PM   #50
I would assume the part about fabbing up the EGR wouldn't necessarily apply since you could use a custom tune to remove that issue anyway, right?
Page generated in 0.68817 seconds with 31 queries
[Output: 214.81 Kb. compressed to 195.91 Kb. by saving 18.89 Kb. (8.80%)]
