Intake gasket leak - S-10 Forum
post #1 of 10 Old 12-28-2008, 04:34 PM Thread Starter
User is: xtremewhite99 is offline
Intake gasket leak
I am just wondering I own a 99 xtreme with the 4.3L and I see that I am looseing coolant. I think that my problem could be a intake manifold gasket if so can you loose coolant from there and if so is it a real hard fix on the s10 with 4.3L.
Thank you:
Mark
post #2 of 10 Old 12-28-2008, 04:59 PM
I AM CANADIAN
tt85_GM's Avatar
User is: tt85_GM is offline
Re: Intake gasket leak
Not real hard to do, just takes patience and time, I did mine for the 1st time, not that hard, just tight to work in some areas like the back of the engine near the firewall to get bolts, distributor, fuel line off ect.
Just make sure you torque all the bolts correctly in sequence, I forget the specs but use the search to find out, there's lots of info on here about the manifold/gasket.
Alot of us guys used the Fel-Pro Perma dry kit, comes with nice beefy metal framed gaskets, not plastic like the sock shitter.
-'02 Jimmy 2dr 4x4, 2" lift & 31's
-'08 Altima coupe
-2000 Sonoma, 4.3L, polished ZQ8's- SOLD
Polishing ZQ8's thread:
http://www.s10forum.com/forum/f14/po...roject-366831/
Leather Seat Swap: http://www.s10forum.com/forum/f26/leather-seat-swap-346677/
tt85_GM is offline
post #3 of 10 Old 12-28-2008, 05:22 PM
Captain DIY
D.T.'s Avatar
User is: D.T. is offline
I just had mine fail. I don't have a serious garage to work in so it cost me $600.00
I heard the failure is caused by the Dexcool? Is this going to happen every 6 months to a year?
I didn't lose coolant in the reservoir, but through the gasket. Didn't know it until the motor cooked on the way to work...
1997 GMC Jimmy 4 wd, 2 DR SLS, W engine, TP mod, snorkel removed - Smoky Caramel Metallic
RIP
New one!
2001 GMC Jimmy 4wd, 2 dr SLS Pewter Metallic
Quote: Originally Posted by yepitslow
Red bull gives you wings my ass!
D.T. is offline
post #4 of 10 Old 12-28-2008, 05:28 PM Thread Starter
yeah I can see mine coming I think from the intake manifold gasket right above the water pump. I was looking at getting a chevrolet dealership to look at my truck.
post #5 of 10 Old 12-28-2008, 05:30 PM
I AM CANADIAN
tt85_GM's Avatar
caused by a bad intake gasket to begin with, they used plastic with rubber like openings for the ports. Dexcool is ok as long as you flush it out far sooner than it's "expected" life span they claim to be 5 yrs. It will corrode the aluminum if air is sucked in or let in by leaky gaskets, rad caps ect. and mixed with old degraded dexcool
-'08 Altima coupe
tt85_GM is offline
post #6 of 10 Old 12-28-2008, 06:13 PM
Captain DIY
D.T.'s Avatar
Should this gasket set last me for a while or am I going to have to replace the gasket every year?? It wasn't repaired at a GM dealer. I had a 2.2L Sonoma and that thing blew the head gasket every other year for $$$$ to repair.
I noticed it when I got the thing. Coolant looked like solid waste junk. I didn't know once it gets aerated that it turns to goo. I tried flushing it, boy that Dexcool is nasty. Stains everything for a LONG time. Organic Acid Technology?
Oh well, learned the hard way.
Dave
RIP
New one!
D.T. is offline
post #7 of 10 Old 12-28-2008, 08:53 PM
I AM CANADIAN
tt85_GM's Avatar
Mines been in for over a year with no issues, I try to replace my coolant every year because of extreme temperature fluctuations the engine is exposed to especially where I live.
If you maintain your engine and have the gaskets installed properly with a good set (fel-pro), you should have no issues for many years.
-'08 Altima coupe
tt85_GM is offline
post #8 of 10 Old 12-26-2010, 10:17 PM
User is: wlsmoku is offline
many thank yous for the tutorial, this site is great and I very much appreciate having these threads before wrenching. helps the frustration when you know all the little details in advance!
wlsmoku is offline
post #9 of 10 Old 12-27-2010, 01:03 AM
Bills Dad's Avatar
User is: Bills Dad is offline
Most use the FelPro "pro" set, absolutely essential you follow torqueing exactly as called and to wait as long as possible before starting, I waited like 1 day for rtv to cure fully.
1997 S10 reg.cab/base, 4wd. L35
1997 Gmc Sonoma sl 4 banger
post #10 of 10 Old 12-27-2010, 01:16 AM
Bills Dad's Avatar
