If your temperature gauge is always low - S-10 Forum
post #1 of 9 Old 12-22-2004, 09:17 AM Thread Starter
Quad-Turbocharged Blazer
nystateofmind27's Avatar
User is: nystateofmind27 is offline
Send a message via AIM to nystateofmind27
I know many other s10/blazer owners have a problem with the coolant gauge showing a low reading. Lately i did a bit or research and i found the cause of the problem.
My temperature gauge always had a reading of slightly over a quarter mark. This is low considering it should be near 210 degrees. After installing electic fans my tempeature gauge show a normal reading of around 200 degrees. I checked with a laser temperature meter which matched the reading of the gauge.
This brings me to believe that the gauge does function but the coolant is not able to reach its normal temperature because of the engine fan. Don't waste your money on a new dash or sender for the gauge as it might make no difference.
post #2 of 9 Old 12-22-2004, 09:55 AM
Higher is Better
xtreme_ice's Avatar
User is: xtreme_ice is offline
Send a message via AIM to xtreme_ice Send a message via MSN to xtreme_ice Send a message via Yahoo to xtreme_ice
Re: If your temperature gauge is always low
Thanks for the info
my truck has never went more than 2 notches above the quarter mark but the heater is hot and have never had it throw a SES
Now i wont spend any more money trying to get the temp up just a tad
Does this sig follow the rules?
On one website this sig got deleted because a mod got mad at me when i pointed out one of his errors
post #3 of 9 Old 12-22-2004, 10:04 AM
loco hombre
nater006's Avatar
User is: nater006 is offline
Send a message via AIM to nater006
You might have a faulty thermostat. The engine fan (a.k.a clutch fan) won't prevent it from reaching the temp it needs to go to -- unless the thermostat is stuck open, preventing the small internal engine coolant loop that allows it to warm up so quick.
Thermostats are known to stick eventually, and hopefully they stick open instead of shut, but it will cause exactly that. In the case that it does stick open, yep, the fans will make a difference.
nater006 is offline
post #4 of 9 Old 12-22-2004, 04:33 PM
black culture thief?!
truckramrod's Avatar
User is: truckramrod is offline
Send a message via AIM to truckramrod
most factory gauges read lower then what the engine temp actually is, mostly for the customers sake. A person used to driving an older carbed car sees the car hit maybe 180. Newer vehicles with EFI can safely run at higher temps but most non gearheads don't know that. Most Ford vehicles don't even have numbers on their gauges. MY gauge will say 160 on the dash and the scantool says that the motor is 184 degrees but the computer gets it's input from a different sensor than the one on the dash.
R is for RACE right???
95 Ext cab red 4.3TBI 5spd ZQ8+2/3 drop Caddy/K&N CAI,Taurus Efan, Flowtech Afterburner/ gutted cat...
Kappa60.5cs comps (everything else was stolen)
Coming : repairs and zq8 wheels
post #5 of 9 Old 12-22-2004, 11:10 PM Thread Starter
I changed the thermostat twice, last time 2 month ago. As soon as i switched to electric fans the temp gauge started reading about 200-210 traffic and 170 highway. Before electric fans it was always at 150 or so after the thermostat opened.
post #6 of 9 Old 12-23-2004, 12:52 AM
fl member
J.Stutz's Avatar
User is: J.Stutz is offline
I have a seperate sunpro gauge on my tbi 4.3 and i never go above 180
J.Stutz is offline
post #7 of 9 Old 12-23-2004, 05:55 AM
Mike1234's Avatar
User is: Mike1234 is offline
I've noticed that will all the engine not heating up posts that a lot of people seem to think that thermostats last forever. For less than $5 and maybe a half hour of work you can replace it and rule this out if the engine is not warming up. Mine got stuck open early last winter and on cold days the engine wouldn't warm up past maybe 60°C. It would get to operating temp fine on warmer days though, so I didn't notice at first.
My temperature gauge always hits 90°C (goes a little over on hot summer days), the rating of the thermostat.
1995 Extended Cab S10, 4.3L TBI, 4L60E
Flat Black, M3 Mirrors
Magnaflow Muffler
5/4.5 drop
15x8" Eagle Alloy 63 Series
215/60R15 up front, 245/60R15 out back
Mike1234 is offline
post #8 of 9 Old 12-23-2004, 11:27 AM Thread Starter
I went through 2 different 195 degree thermostat so i think we can safely rule that out.
post #9 of 9 Old 12-23-2004, 02:05 PM
Mike1234's Avatar
Ya I didn't mean you specifically, just in general on the forum.
Although one of my friends went through two thermostats last year. He just bought the car and the thermostat was stuck open, so he put another in and it was stuck open. He returned that one and went to the dealer to get a good one.
As nater said the clutch fan shouldn't really have an effect on the engine warming up. Since no coolant is flowing through the radiator while the thermostat is closed. I find that funny when some e-fan manufacturers advertise faster warm up times. Once the engine warms up and the thermostat opens then it starts going through the rad. I could only see the clutch fan cooling too much if the clutch was bad and locked, but that would make a hell of a lot of noise.
Magnaflow Muffler
5/4.5 drop
Mike1234 is offline
