Idles fine give it gas starts to cut out hesitates - S-10 Forum
post #1 of 18 Old 08-04-2006, 06:20 PM Thread Starter
User is: biggyzzz is offline
1992 s10 blazer s10 4.3 188,700 mi. Truck died going down highway. It started to run rough for about 10 miles pulled over ran very rough no power. Had it towed to work next morning would not start.
I put a new fuel pump, gas tank and fuel filter in last month due to rust. So today I installed a new CPI/nut kit from Napa also new cap and rotor plug wires while I was in there. Truck would not start. 3 or the six spark plugs were soaked in gas. Replaced all 6 plugs and truck fired right up. It drove fine for 2 miles and then started to sputter/hesitate and I can't get it going above say 20-27mph. Fuel pressure reads 52 running and when I snap the throttle it goes to 60-62psi. after sitting for 15 mins it reads 20psi. It idles fine, when I give it gas and hold it, it starts to cut out hesitates.
I checked the fuel pump ground it was good. A while back I bought a set of used sensors off ebay so I swapped them on. They included TPS, ignition module, MAP sensor, Air diverter valve, and idle air control. It runs the absolute same. No change, No codes.
My thoughts: Plugged cat converter, bad crank position sensor, bad pickup coil in distributor.
Any thoughts/help/past experiences would be greatly appreciated.
-Thanks
biggyzzz is offline
post #2 of 18 Old 08-04-2006, 06:46 PM
Driver of the Short Bus!
scott011422's Avatar
User is: scott011422 is offline
Send a message via AIM to scott011422 Send a message via Yahoo to scott011422
Re: Idles fine give it gas starts to cut out hesitates
You don't have a CPS....So its not that...........I'm thinking its your fuel pressure. I know my 92' 4.3l sonoma never ran anywhere near that hi. In fact, I just looked up the fuel pressure test for your vehicle in a Vantage, and at Idle you should have 9 to 13 psi. So I'm thinking that could be your problem!
Edit: Next time, Want to leave my sig so I know what the heck I had?!?!?
post #3 of 18 Old 08-04-2006, 07:35 PM Thread Starter
Not sure what a CPS is but this truck has CPI injection. I talked to a local shop and they said the pressure should be 55 psi at idle and when you snap the throttle it should go to 62psi.
biggyzzz is offline
post #4 of 18 Old 08-04-2006, 08:06 PM
Alrighty, Here is what My roommate said to try...........He's betting most of his money on the cat. Expecailly if the intake has an odd noise when you try to floor it. kinda described it like a roaring. Easy to test though, jsut unbolt the cat , if it runs drasticly better, there's your problem.
Also, 20 psi after 15 min either running or not is BAD. Chances are that your "Spider assembly" is going out, prolly have a leaky popet valve. Its located under your intake. Basicly you have one larger injector module called the spider that does all your injectors...
post #5 of 18 Old 08-04-2006, 09:42 PM Thread Starter
I drilled a 1/2 inch hole in the exhaust before the cat made no difference in the way it runs. I replaced the whole CPI injector today. I wonder if it was a bad part out of the box. I got it from napa it was $250. Is there a way to test the new CPI to see if it is bad? Should the pressure be staying at 50 psi after the truck has been sitting not running and for how long? Thanks for the help.
biggyzzz is offline
post #6 of 18 Old 08-04-2006, 09:44 PM Thread Starter
One more question with the new spider injector CPI does it matter which poppet goes in which hole in the intake? I remember reading that it did not matter.
biggyzzz is offline
post #7 of 18 Old 08-05-2006, 12:40 AM
I understand that removing a rusted cat is a pain in the azz, but a .5 hole isn't going to do much if the cat is blocked.
With the fuel pressure, spec is with the pump off, that the fuel system should hold that pressure for 48 hours. So in reality I would think maby 4 hours with no noticable decrease?
On the popits: I dunno. I'm thinking not being that the Spider fires all the popits at once. But I'll talk to my roommate in the morning and see what he says. I'll probably hop on after lunch, Central time.
untill then, If you have any more questions, fire them off and I'll ask him. FYI, hes not some bum, but an ASE certified master tech, so he knows his sh*t
post #8 of 18 Old 08-05-2006, 09:26 AM Thread Starter
I think I'm going to cut the exhaust with a sawzall when I get back to work. What does he think the fuel problem could be leaking pressure like that? The new CPI is defective or a bad fuel pump? They are both new napa parts. Checked again 52 psi idling 60-62 when throttle snapped and 20psi after sitting for 20 mins not running. Thanks again.
-Joe
biggyzzz is offline
post #9 of 18 Old 08-05-2006, 12:47 PM Thread Starter
Update: Installed another new CPI from napa still the same thing. Took a sawzall and cut the y-pipe to cat so the cat is out of the picture. Same thing. Just spitts and sputters when I give it gas idles ok.
biggyzzz is offline
post #10 of 18 Old 08-05-2006, 03:39 PM Thread Starter
Just to clarify the last post it spits and sputters and cuts out when I give it even a little gas, top speed about 20 mph. The truck will idle ok.
biggyzzz is offline
post #11 of 18 Old 08-05-2006, 03:59 PM
User is: s10_fan is offline
I had a 1994 4.3 and it was doing the same thing and finally one day it wouldnt start at all and it was the coil.
s10_fan is offline
post #12 of 18 Old 08-05-2006, 10:38 PM
User is: rawdog is offline
did you check the timing? I went thru this recently, but not as bad. Anyway, the dist. drive gear was badly worn, and as near as I could tell, the base timing was off as well. Found this after replacing the same parts you did, plus others.
I'm so happy to finally figure it out that every problem looks like the distributor now, but hey, it's worth checking out.
rawdog is offline
post #13 of 18 Old 08-05-2006, 10:51 PM Thread Starter
Didn't think of that. I have a 2000 blazer that I did the lower intake gasket on and the distributor was not adjustable, I thought this set up was the same. I have a timing light so I'll check that out too.
biggyzzz is offline
post #14 of 18 Old 08-06-2006, 05:52 PM Thread Starter
Update: I couldn't find my timing light so I'll have to get another. I took the new battery out of my wifes truck and bought a new coil for $15 . That didn't help. I dropped the gas tank and got the fuel pump warrantied. Pressure is now holding at 55psi after shutting off key for several hours. But, it is doing the same thing. Idles fine give it gas and it just starts to sputter. Is this the correct order for the plug wires 92 4.3 CPI:
_4
5 3
6 2 distributor
_1
Engine
6 5
4 3
2 1
Fan
Front of vehicle
Anyone got any ideas?
biggyzzz is offline
post #15 of 18 Old 08-06-2006, 07:30 PM
User is: adamw89_2000 is offline
what about the egr valve?? when mine went bad i know it ran like crapp when i gave it gas??? just a thought
post #16 of 18 Old 08-06-2006, 07:44 PM Thread Starter
I took the EGR out the other day and cleaned it everything looked ok no chunks of carbon or anything. When yours ran bad from the EGR problem did it severly cut out and barely go 20mph, basically not drivable. Or did it just run bad and it was still drivable?
biggyzzz is offline
post #17 of 18 Old 08-07-2006, 05:10 PM Thread Starter
Update: FIXED!!! It was the pickup coil in the distributor.
biggyzzz is offline
post #18 of 18 Old 08-08-2006, 05:30 AM
An ol Scott
SilverWings's Avatar
User is: SilverWings is offline
My, my, my. Funny how many times it turns out to be a problem in the distributor. I've just fixed a problem of poor running due mainly to a fault in the distributor my self.
95 standard cab 4.5/2 drop, all Beltech with UMI Proformance A arms with tall balljoints, Wilwood disk brakes. Energy Suspension polys, heavy duty anti sway bars front and rear, Richmond Gear locker rear with a 3.08 gear, a 300+ hp LT1 Vett and a 4L60E with Vett internals and Vett converter. HID head light upgrade and various LED lighting.
My (still, less than exciting, even after updating it) Cardomain site
http://www.cardomain.com/ride/856839
