How to set timing on 1994 cpi S10 T15 Blazer Jimmy??? - S-10 Forum
post #1 of 19 Old 08-18-2010, 03:32 PM Thread Starter
Aquatic Goat Farmer
uhlhazard's Avatar
User is: uhlhazard is offline
Exclamation How to set timing on 1994 cpi S10 T15 Blazer Jimmy???
I have a plastic timing cover. This is crazy. You can only see the single timing mark with the fan shroud removed and the air intake removed. I also don't know how anyone would have set timing without the fan removed.
Thanks to electric fans, I don't have a fan or shroud in the way.
When I white outed the 2 marks on the harmonic balancer, I couldn't see them with the timing light. I then white outed the crank pulley where the timing marks correspond so I could get a remote idea where the timing marks when cyl1 fired off.
I am getting cyl1 ignition with the timing marks about -45ish degrees off and even more so with the other timing mark.
I tried to spin the harmonic balancer with 2 hands and I didn't feel any slack or play.
The truck runs fine, just a 1-2mpg lower than my friends identical trucks, slower in a race consistently, and gets hot when under a load which I attribute to timing being off. It's been this way for years and I could never figure out exactly why.
Did someone replace my timing cover with the new plastic ones, or did the 94 just come with it? My friends 93 and 92 has the normal timing cover that we have set timing on countless times. I am waiting to see my other friends 94 to see if he has the plastic cover.
I searched like crazy and couldn't get anywhere so here I am.
94 T15 Jimmy SLE 4X4 4dr and a bunch of mods.
1984 ATC70
1999 Suzuki Bandit
"If you don't have constructive feedback, then feed your feedback back up your backside." - Unknown Author
post #2 of 19 Old 08-18-2010, 04:30 PM
Have A Nice Day
944v8indfw's Avatar
User is: 944v8indfw is offline
Re: How to set timing on 1994 cpi S10 T15 Blazer Jimmy???
As it is a cross over year i THINK it still had the connector you need to disconnect under the carpet to set the timing. Typicallt a brown connector under the right side carpet close to the firewall.
post #3 of 19 Old 08-18-2010, 04:33 PM
UN-BANNED B!TCHES!!!!!
NotaDime's Avatar
User is: NotaDime is offline
yes it does., all those 4.3 obd1's do...
WTB cowl hood near valdosta GA NOW...
Seems like there are still a few people (Imperial, NotaDime, etc...) here that still have working brains.
Originally Posted by The Master View Post
BTW last post evar on this site. cheers and.....fock off.
Originally Posted by v8lonoma View Post
everything notadime said +1.
NotaDime is offline
post #4 of 19 Old 08-18-2010, 05:49 PM Thread Starter
Aquatic Goat Farmer
uhlhazard's Avatar
Yeah I did that.
1984 ATC70
1999 Suzuki Bandit
post #5 of 19 Old 08-18-2010, 10:53 PM
goin broke but n style
S15vortecpwr's Avatar
my 94 cpi have a metal timing cover.
someone might have put a newer engine in your trk with plastic cover.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #6 of 19 Old 08-18-2010, 10:55 PM
NotaDime's Avatar
both my 92 and 93 cpi motors had plastic covers...
NotaDime is offline
post #7 of 19 Old 08-18-2010, 11:44 PM Thread Starter
Aquatic Goat Farmer
uhlhazard's Avatar
Have you ever had to set timing on them notadime? If so, how did you do it?
1984 ATC70
1999 Suzuki Bandit
post #8 of 19 Old 08-19-2010, 10:27 AM
Mine may be plastic, but it looks metal when i changed the water pump, but it has been a few years.
I know its looks different than my 99 blazer i just bought.
post #9 of 19 Old 08-20-2010, 01:54 AM Thread Starter
Aquatic Goat Farmer
uhlhazard's Avatar
I have spent about 2 hours searching and come up with blanks. I am wondering if 93 was a split year where gm started installing plastic timing covers. Does everyone have a place to bolt in the crank position sensor? I don't see that on any blocks that aren't plastic timing covered.
1984 ATC70
1999 Suzuki Bandit
post #10 of 19 Old 08-20-2010, 12:07 PM
User is: BanditS10 is offline
My 94 CPI, early 94 built in late 93 has a steel cover. I've owned for its entire life (400k miles), i know it's original. I just recently put a cam, chain, etc. in it and reused the stock steel cover. I've also never unplugged a wire under the seats to set timing.
post #11 of 19 Old 08-31-2010, 12:30 AM Thread Starter
Aquatic Goat Farmer
uhlhazard's Avatar
Well, My sadness prevails. I guess no timing for me anytime soon. Noone seems to have an answer for me. I'm going to check fullsizechevy.com and see what they say. If I do get results I will post here.
1984 ATC70
1999 Suzuki Bandit
post #12 of 19 Old 09-01-2010, 11:04 PM Thread Starter
Aquatic Goat Farmer
uhlhazard's Avatar
http://www.fullsizechevy.com/showthr...iving-problems.
My fsc post. Heres hoping : (
1984 ATC70
1999 Suzuki Bandit
post #13 of 19 Old 10-07-2010, 02:43 AM Thread Starter
Aquatic Goat Farmer
uhlhazard's Avatar
So I'm thinking I can use my scanner to set timing? I think it might show me current timing and I just move the dist until it reads 0? Would that be awesome?
1984 ATC70
1999 Suzuki Bandit
post #14 of 19 Old 11-19-2010, 12:56 AM
Open mouth, Insert foot!
Trip..'s Avatar
User is: Trip.. is offline
Updates?
Is it me, or do Dr. Phil's eyes look like two piss holes in the snow?
Trip.. is offline
post #15 of 19 Old 12-09-2010, 03:12 AM Thread Starter
Aquatic Goat Farmer
uhlhazard's Avatar
Diddley doo. I went to the junkyard and developed some inspiration. Turns out some tbi 4.3's with the tiniest radiators I've ever seen in the gmt400 platform also have composite covers.
After comparing timing mark locations of the tbi and older tbi with metal covers the plastic "mark" or "protrusion" seems to be in line with the 0* mark. I could not imagine how much of a PITA this would be for someone who has a fan/shrouds unlike myself.
I am theorizing that my HB slipped and thats why my marks are basically way off.
I am going to take the plunge possibly friday and buy the timing cover, HB, and try like hell to not drop the oil pan.
O and I'll be sure to rtv my cotter key on the HB because that is a stupid rookie mistake.
Then in a few weeks I'm driving to Michigan. I'll be sure to take some salt back home with me, your cars have plenty of it already.
1984 ATC70
1999 Suzuki Bandit
post #16 of 19 Old 12-09-2010, 12:39 PM
My 94' has a metal timing cover, and there isn't a plug under the floor for timing. I've had the truck it's entire life and it's the original engine with 400k miles.
If you really can't find an answer let me know, i have all of the 94 GM truck repair manuals from the dealer. It's been years since I've adjusted my timing, although i'll probably do it here in a few weeks.
-Bigmileage- Bandit Z's
94 S10, 4.3 Custom Ground Cam & ported heads, headers, 2.25" SS true duals, 3" Rancho Suspension Lift, GM 8.5 rear locked, GM 8.2 Fullsize IFS Front with custom made CV's, 5.13s, Diversified Flares on 33s
-93 GMC Typhoon
post #17 of 19 Old 12-09-2010, 12:48 PM
Electrical Mod
deathphoenix99's Avatar
what's your email, I can send you the how-to on timing.
post #18 of 19 Old 12-09-2010, 12:55 PM
Electrical Mod
Here it is.
V6 IGNITION TIMING
1. Set parking brake, block drive wheels and place transmission in Neutral or Park. Warm engine
to normal operating temperature. Turn A/C off (if equipped). Ensure Malfunction Indicator
Light (MIL) is off.
NOTE:
The location of the EST by-pass connector has been updated per
General Motors Service Manual Update number 41-65-41, dated
January 4, 1995.
2. Disconnect Tan/Black Electronic Spark Timing (EST) by-pass connector wire. DO NOT
disconnect 4-wire connector at distributor.
3. On models where engine computer is located underhood, on right fenderwell, by-pass connector
which is a single Tan/Black wire, breaks out of wiring harness near engine computer harness
connectors.
4. On models where engine computer is located in passenger compartment under right side of
instrument panel, by-pass connector which is a single Tan/Black wire and breaks out of wiring
harness where heater box and carpet meet on passenger side floor. Pull back carpet to expose
single Tan/Black wire and connector on outside of control module harness.
5. On all models, connect timing light to No. 1 spark plug wire. Check timing and adjust if
necessary. See V6 IGNITION TIMING table. Reconnect EST by-pass connector, and clear
ECM trouble code.
V6 IGNITION TIMING (DEGREES BTDC @ RPM)
Application Man. Trans. Auto. Trans.
4.3L (VIN W & Z) 0 @ Idle 0 @ Idle
post #19 of 19 Old 07-09-2012, 01:45 AM
User is: t0cableguy is offline
Thanks for this. Just put my motor back in the truck this week.
