how to replace ignition switch? - S-10 Forum
post #1 of 8 Old 02-06-2006, 01:00 AM Thread Starter
adobo's Avatar
User is: adobo is offline
how do you replace this? i was able to remove the bottom steering wheel cover and locate the switch, but i could not get to the top bolt , do i have to remove the steering wheel and the ignition lock to do this? that sucks! i dont have a steering wheel puller.
adobo is offline
post #2 of 8 Old 02-06-2006, 04:13 AM
trixedout1's Avatar
User is: trixedout1 is offline
Re: how to replace ignition switch?
if i remember str8 yup you don't but i'm drunk right now lol what year is it that your changing it from?was thinking jus the colum cluster only .give me more info
post #3 of 8 Old 02-06-2006, 10:38 AM Thread Starter
adobo's Avatar
it's a 97. the ignition switch wire harness starts from underneath the foot panel to right under the ignition lock. there are two reverse torx looking bolts holding it in, one on the side and on the top of the switch.
I can't get to the top screw because its wedged in between the ignition lock and the steering wheel...
adobo is offline
post #4 of 8 Old 02-06-2006, 06:09 PM
trixedout1's Avatar
sound like yup you really got to take off the steering wheel .there are some parts store that rent it out or you can go to a local tool truck and buy it costing bout 20 to 50 bucks depend on what truck or your local sears.jus remember before you take off the steering wheel .make sure the wheel is str8.and if the clock spring got to come out it goes back the same way (once you take it out put tape so it won't spin)if not you'll have to buy a new one and it cost bout $100 and maybe more and reset the air bag system.take off the neg. terminal before you start!!maybe if you got some picture can tell more on how to do it .hope that helps
post #5 of 8 Old 02-12-2006, 10:27 PM
User is: zivnad is offline
I just replaced mine 1999 ZR2. No need to take the wheel of.
zivnad is offline
post #6 of 8 Old 02-12-2006, 11:30 PM
Minitrucker
CrEaPeR's Avatar
User is: CrEaPeR is offline
Send a message via AIM to CrEaPeR Send a message via Yahoo to CrEaPeR
i just replaced mine on my 00. all you have to do is pull down on the black box and remove the two clips that are by were the key goes in. Also you have to unbolt the wiring plug that is hooked to all that.
CrEaPeR is offline
post #7 of 8 Old 02-13-2006, 04:57 PM
Resident Hardhead
BlackStallion's Avatar
User is: BlackStallion is offline
i have a 97 s10 and my mom has a 98 blazer now the steering columns are different so id assume that any advice from 98 up aint so good
post #8 of 8 Old 04-05-2006, 03:52 PM
DrC
learn to die...to live
DrC's Avatar
User is: DrC is offline
Post Re: how to replace ignition switch?
looks like u got a standard steering column (not tilt)...don't look like u need to remove the wheel on a 97, just need to lower the whole steering column
<start>
For anti-theft reasons the ignition switch is located on top of the steering column assembly and is completely inaccessible without first lowering the steering column. The switch is actuated by a rod and rack assembly. A gear on the end of the lock cylinder engages the toothed upper end of the actuator rod.
1. Remove top and bottom shroud.
2. Remove the column-to-dash attaching bolts and slowly lower the steering column, making sure it's supported.
3. Remove the multifunction switch (turn/wiper/hazard) if necessary.
4. Remove the key alarm switch (if equipped) by gently prying the alarm switch retaining clip w/ a small screwdriver.
5. Make sure that the switch is in the LOCK position. If the lock cylinder is out, pull the switch rod up to the stop, then go down one detent.
6. Remove the two screws and the switch.
To Install:
7. Before installation, ake sure the switch is in the LOCK position.
8. Install the switch using the original screws. Tighten the screws to 12 in. lbs.
9. Install the key alarm switch (if equipped). Make sure the retaining clip is parallel to the lock cylinder. Rotate the alarm switch 1/4 in. turn until locked in place.
10. Install the multifunction switch if removed.
11. Replace the column. Tighten the nuts to 22 ft. lbs. and the bolts to 20 ft. lbs.
12. Install the top and bottom column shrouds.
<end>
As usual, it's never too uncool to disable the airbag system (SIR) by removing the AIR BAG fuse on the fuseblock (after disconnecting the negative battery cable) and disengaging the CPA yellow two way connector at the base of the steering column.
Hope this helps...
97 2.2 RegCab...STOCK!
DrC is offline
